DIY: How to remove and replace Oxygen Sensors | Page 2 | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 8, 2015.
  1. eecsdude
    eecsdude Rookie
    Mar 23, 2009
    17
    Karric
    No worries, I'll try to figure it out. Seems like the other folks in the thread didn't run into much trouble and were able to follow your DIY instructions without problems. So I must be missing something.
  2. eecsdude
    eecsdude Rookie
    Mar 23, 2009
    17
    Karric
    Success! I was able to finally figure out the connector. Basically for the pre-cat O2 sensors, the electrical connector is secured to the car via a sleeve. You must move the connector assembly in the upward direction to release it from the sleeve. For me, the right side O2 sensor wire was a bit tight, so the tension made it harder to release the connector than the left. Once free from the small metal rail, you can move the connector out in the open for a better view of how the O2 sensor is mated to the car connection. The attached photo shows the car-side connector. To release the O2 sensor, pull the gray clip outwards.
    Thanks for the help everyone, the rest of the replacement process was more or less what the PDF shows. A few notes:
    - You may want a breaker bar that matches the O2 sensor removal tool drive size. My breaker bar is 1/2" drive and the tool was 3/8" drive, so I had to get an adapter and the extra distance made it hard to maneuver. Alternatively maybe get a universal joint type connection to get more freedom.
    - If you are short and have short arms like me, be prepared to lay across the rear fenders of the car to reach these components. Yes, you can do everything from the top of the engine bay, but it's a pain. I braced myself by holding onto the aluminium engine frame, so basically it was one-armed push-up for the entire process.
    whatheheck likes this.
  3. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Excellent! Glad to hear you got it figured out. Thanks for sharing additional info. [emoji106][emoji106]
  4. Walt Gamble
    Walt Gamble Formula Junior
    May 22, 2014
    425
    Dan... I'm trying to follow your DIY instructions.. unfortunately the links to the Removal Tool is DEAD - I can figure out the rest of the links but that one looks like a key... PM? [email protected] This is a winter project so its not like I've got it torn down... Thx
    Walt
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Walt,
    Looks like the link no longer works. Sorry about that.
    Here you go:
    It's a 22mm Oxygen Sensor Removal Tool, 1/2" Drive. It has a slot for the oxygen sensor wires.
    Here's one currently for sale at Amazon:
    22mm 1/2" Drive Heated Oxygen Sensor Socket | ARES 70323 | Wire Gate Accesses Sensor from the Side, Preventing Damage to Wires. Direct link below.
    https://smile.amazon.com/Heated-Oxygen-Sensor-Accesses-Preventing/dp/B073WHFBVZ/ref=sr_1_10?s=automotive&ie=UTF8&qid=1515120979&sr=1-10&keywords=oxygen+sensor+socket+22mm
    Hope that helps.
    Dan
  6. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    When installing my extenders, it was a pain for a simple job. Getting the connector unplugged and the wire routing.
    Then it was easy. From memory there were wire clamps hidden by the air boxes too.
  7. Paolobellini
    Paolobellini Rookie
    Oct 19, 2019
    1
    Paolo bellini
    Having difficult time unplugging the front o2 sensor from the connector .... any tip?
  8. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Just a few points worth raising...
    Some people many not even know they have reduced or degraded engine performance but it can be caused by old o2 sensors. Why? Well o2 sensors as they age get slower respond. They may still be within programmed tolerances before a CEL is illuminated too.
    If your primary o2 sensors are aged and never replaced it will be reducing performance of your engine as they are used to trim fuel and precisely adapt to Lambda requests (programmed air fuel ratio targets.
    At the age the 360 is now I would expect coil packs, plugs and o2 sensors to all be done or the performance will be degraded.
    Secondary o2 sensors post cat aren't so important on 360 as they are only used to measure catalytic performance and decide if the cats are working efficiently. In fact those limits can be reprogrammed by my Ferrari SAK tool or you can disable the secondary o2 sensors completely and fit bungs, again using SAK tool.
    clean512 and kes7u like this.
  9. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,208
    Shorewood, MN
    Kevin
    Thank you for the info. I love coming to this forum and getting info from you guys with such a high level of knowledge and experience. Just so you guys know how appreciated you are!!!!
    Kevin
    Walt Gamble and 360trev like this.
  10. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
  11. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    is it just me, because anything thats happened to my f430 is usually a bosch part
  12. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Lots of German parts in Ferrari's!
  13. priericky128
    priericky128 Formula Junior
    613
    St. Louis MO
    Rick
    Old thread here but wanted to ask a question about this if anyone is still around. I have a '01 euro car with a P0432 code and since I don't get a slow down light and the cats visually look fine, I am thinking it is worth a shot to replace the post cat lambda/o2 sensors. It seems likely to me that the sensor would fail before the catalytic converter itself. Question would be - should I replace the pre-cat sensors as well while I am in there working on it or just do both rears and do the fronts later? I have the shop manual for the 360 and combined with this guide, it looks pretty straightforward so I am going to DIY this and then clear codes and see if it fixes the problem.
  14. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,070
    Josh @jtcarprojects
    When was the last time they were charged. If its been awhile I definitely would do all. Its cheap insurance
  15. priericky128
    613
    St. Louis MO
    Rick
    They look original to me. No record of them ever having been changed. Given that the tires were 10 years old when I bought it, I would be surprised if the previous owner would have changed o2 sensors if you get what I mean.
  16. Trackjunkie1
    Trackjunkie1 Karting
    Aug 2, 2017
    52
    I just changes my fronts about 2 weeks ago. only suggestion is to spray PB Blaster and let soak overnight. Also get the Oxygen sensor tool, makes the work so much easier. probably 30 minutes for both.
    kes7u and clean512 like this.
  17. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,100
    Calif
    Brett
    Mine easily unsrewed, both the front and back. Interesting to read people needed breaker bars, etc. Mine weere easy. Replaced fronts at 44,000 miles. Rears still going at 46,000 but I did add extenders a few thousand ago.
