DIY: How to remove and replace Oxygen Sensors | FerrariChat
Discussion in '360/430' started by whatheheck, Apr 8, 2015.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #1 whatheheck, Apr 8, 2015
    Did a search and there were various threads about the subject and not one DIY write up that can help someone when its time for them to replace their O2 sensors so I thought I'd create one.
    So here you go for sharing:
    Situation:
    Check engine light came on. Pulled fault codes using OBD Facile Android App.
    Fault codes thrown were:
    - P0030 (Heated Oxygen Sensor, Heater Control Circuit, Bank 1 Sensor 1),
    - P1135: (O2 Sensor Heater, PreCat ECU1).
    Summary:
    Removed and replaced Pre-Cat O2 sensors.
    Result:
    Check Engine Light gone.
    Attached is a DIY. Hope this helps some of you.
    Dan
    AquaVelvaMan, hessank and billy.gif like this.
  2. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    7 page doc! Whew. Nice to do. I just got to the connection, unplugged so it didn't twist, and then used a normal wrench to take off the sensor. The connector is a little bit unique.
  3. rizzo308
    rizzo308 F1 Rookie
    2,748
    Perth, Australia
    riggio
    Hey u da man Dan! we 360 owners will one day need to tackle this job so great info Dan thanks for sharing.
    Cheers
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #4 whatheheck, Apr 8, 2015
    Youre welcome!
    I forgot to mention, my car is 11 years old with 21K miles. Seems a little too soon for the O2 sensors to go bad but it is what it is....
    Dan
  5. rizzo308
    rizzo308 F1 Rookie
    2,748
    Perth, Australia
    riggio
    #5 rizzo308, Apr 8, 2015
    Yeh it never ends with these F cars, bad tensioners, heat exch, weak headers, blah blah blah
    that's why we love them so much. One more PDF to add to my DIY folder. Gotta love F/chat and the good folk on here.
    My 360 is new to me I stepped up from a 308GTB 6 months ago always wanted a 360 she was a bit neglected so im layin bit of TLC on her got a wee bit outa control.
    Cheers
  6. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Whooooaaa! Dayum! I wish I had your talent and guts to work on cars at that level of detail!
    I bow to you.
    Dan
  7. London
    London Karting
    Aug 29, 2009
    189
    London
    Thanks - I didn't know you needed a special tool to remove the oxygen sensors!
  8. 360ian
    360ian Rookie
    Mar 16, 2014
    32
    UK London
    Ian
    Brilliant article Dan, well done - I'll have to get ready to do mine soon then as your car has done 1 mile less than mine :):)
    thanks again
    Ian
  9. London
    London Karting
    Aug 29, 2009
    189
    London
    Incidentally my 360 is at 41k and still on the original sensors with no problems...
  10. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Or a wrench.
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Well, my dad raised me always saying "the right tool for the right job".
    You dont really need a special tool. You can use an open end wrench 22mm or 7/8.
    But if the O2 sensor is frozen tight and the penetrating oil didnt do much help to loosen up the rusted thread you will have a difficult time removing the sensors as you dont get very much leverage out of the normal open end wrench.
    With the tools I listed above it literally took me less than 2 minutes to remove each sensor. No hardship no struggles.
    I just like to do things the easy way. Why suffer or have a hard time if there are better options?
    Plus it gives me reason to buy new tools :)
    Dan
    cavlino likes this.
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome Ian.
    Thanks for the appreciation.
    Dan
  13. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Good for you!
    Thanks for sharing great info.
    I really dont know what causes them to go bad. Luckily they are very easy to replace.
    Dan
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    By the way, the O2 electrical connector may be difficult to figure out how to unmate for the not so electrically inclined. I can take photo and provide instructions if anyone has a hard time figuring it out.
    Dan
    AquaVelvaMan likes this.
  15. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #15 whatheheck, Apr 20, 2015
    I forgot to mention that the Ferrari parts diagram and the diagram also shown in Ricambi as far as location of the O2 sensors are inaccurate.
    The Pre-Cat sensor is not located forward of the catalytic converter. its actually located way more forward, on the outboard side of the headers as shown on the photo below.
    Dan
  16. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,152
    Wash DC area
    Robert
    Thread added to DIY sticky thread.
    Thanks for the info!!
  17. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome!
    I'm always happy to help.
    Dan
  18. eecsdude
    eecsdude Rookie
    Mar 23, 2009
    17
    Karric
    My mechanic also informed me that I need to replace pre-cat O2 sensors. He was gonna charge me 1 hr labor per side. It'd be great if I can DIY. I looked through the PDF and it looks straightforward, but I wasn't sure whether you can do all of this work without lifting the car. Can you do all of this with only top-down engine bay access?
    Thanks!
  19. mello
    mello F1 Veteran
    5,432
    CA Bay Area
    Steve
    I replaced all fours without lifting the car. And within 30 minutes.
  20. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    I replaced one of the sensors in my F430. Was getting lean and rich fuel mixture errors when the CEL came up. The precat sensors are easier to replace due to accesssibility. I used a household adjustable spanner and the handle from my car jack. I used the jack handle as a lever against the engine frame and the spanner which freed up the sensor. I had to remove the large engine panel prior to doing this
  21. eecsdude
    eecsdude Rookie
    Mar 23, 2009
    17
    Karric
    Thanks for the info folks. I'm gonna give it a shot.
  22. mkzhang
    mkzhang Formula Junior
    544
    Philadelphia
    When my 02 sensor on the header seized, I just took off the wheel and wheel well, stuck a 4 foot pipe on my wrench and got it off in a jiffy
  23. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Yes, you can do all of the R & R from the top of the car.
    No need to remove the bottom panel.
    Dan
  24. eecsdude
    eecsdude Rookie
    Mar 23, 2009
    17
    Karric
    I finally got around to attempting this and I'm stuck at figuring out how to unmate the electrical connector. It looks like the connector is attached to a mounting point via a sleeve-like groove (which I was able to undo by pushing the connection up), but that doesn't help me much as now it's in an even more awkward position where I can't get my fingers around things.
    Did you remove the side covers before doing this work? I'm here trying to reach in from the side and using an inspection mirror to actually see the connector...
    Thanks.
  25. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi. I'm sorry but it's been a while since I did the O2 replacement that I can no longer remember the details.
    I'm also here in Las Vegas (I live in Seattle) and I don't have access to my photos stored in my home PC to check.
    Sorry I can't help much....
    Dan
    Sent from my SM-G955U using Tapatalk
