DIY Ferrari 360 key rejuvenation | FerrariChat
Discussion in '360/430' started by Bonefingah, Feb 25, 2019.
  1. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    If you're anything like me, it bugs the bejesus out of you to have hideously worn keys with a nice car. I hope this easy project will motivate you to make them look amazing again.
    One of my keys is plastic and the other is metal. I removed the cavallino from both with an Exacto knife (easy) and sanded the plastic one. I masking-taped the recessed portion (where the cavallino came out), in order to later be able to glue it back in, without gluing onto paint (read: I kept the to-be glued part clean).
    I masking-taped the actual key part large enough to be able to hold on to the tape when the key was wet. Once sanded, I gave it a few coats of a silver metallic paint that also includes a clearcoat (in German, it was called metallic effect paint). I'm sure normal metallic paint followed by clear coat will work fine. Once to my liking, I clear-coated it a few times and then super glued the cavallino back. Done and looks amazing!
    The metal one was a lot easier still. Dremel + Polishing compound and bit = matted, old key to mirror-like finish. Looks awesome!
    See pics starting with the plastic key...
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    ChrisBR, fotostars and tifosi101 like this.
  2. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
  3. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    552
    SW Suburbs of Chicago, IL
    Lawrence P.
    Look great. A new winter project for me
    Bonefingah likes this.
  4. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
    Excellent work! I polished my spare key last week and the results were brill! I will be doing my main key when I get my car back from its major.
  5. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Nice!! Do you have a pic or two to share? :D
  6. LP360
    LP360 Karting
    Jun 12, 2016
    169
    Lee
  7. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Nice job LP360!
    Please share the main key project when able!
    - Pete
    LP360 likes this.
  8. BDubbs
    BDubbs Karting
    144
    WA State
    B Dubbs
    Inspired by this thread I decided to refinish my key. I removed the cavallino, and stripped the paint. I then sanded the edges with a high grit paper on my belt sander and polished it on a rouge wheel. Once I got a good polish I masked off the sides and bead blasted the front and back surfaces. Very happy with the results, it almost looks like the original paint...
    Sorry for the poor pic quality... tough with a cell phone in bad lighting. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Sent from my SM-N960U using FerrariChat.com mobile app
  9. one4torque
    one4torque F1 Veteran
    5,118
    Houston
    One4torque
    Looks better than oem....... can I send you mine :)
  10. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    VERY well done indeed! Looks awesome!!
  11. BDubbs
    BDubbs Karting
    144
    WA State
    B Dubbs
    One4torque, If you are serious, I'd happily refinish your key. It was a very quick process and surprisingly satisfying. The only thing I don't know is how it will wear long term, so I cant make any guarantees, but it's a heck of a lot better than the crappy painted mess that you end up with after years of ownership. Shoot me a PM for mailing info if interested, no charge.
  12. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,645
    Silicon Valley
    Performify likes this.
  13. one4torque
    5,118
    Houston
    One4torque
    B dub - pm sent. lmk your favorite drink or smokes.
  14. one4torque
    5,118
    Houston
    One4torque
    while buying an f car in itself is a rewarding experience....... I must say I'm taken back by the interesting and generous people I've met with this marque.....
    I just had my beat 360 key restored by Mr. BDubbs...... and it looks so good I shall put it aside for presentation and use my minty spare key..... thank you fellow car enthusiast.... you give me hope for this hobby..... there are good guys out there. Jeff
    check out the polished sides..... which will be more durable polished... then the blended painted top/btm. reminds me of a guitar finish........ you really should do a blue-burst or silverburst finish..... that would be really special..... do a burst with the color of the actual car......
  15. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Wow that is indeed amazingly gorgeous and generous! High-fives all around guys!
  16. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
  17. Sergio66
    Sergio66 Rookie
    Nov 29, 2020
    1
    Italy
    SERGIO PANIZZA
    Veramente un bel lavoro!
  18. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Grazie mille!
  19. sportdevices
    sportdevices Rookie
    Sep 17, 2011
    26
    Alistair PArker
    just picked up my 1st 360 (I've still got a Mondial that I've had for 15 years), the key pissed me off straight away so this thread is excellent, my key doesn't have a Cavillno see pick, where can I get one? will post picks once polished and restored
  20. Bonefingah
    Bonefingah Rookie
    Sep 10, 2018
    27
    Cologne, Germany
    Peter Linch
    Nice! Congratulations!
    Darn, I KNOW 100% you can get replacements. I've seen them for SURE but I'm trying to remember where...
    Lemme look around as see if I can re-find where that was.
