DIY - Door Felt Weather Strip - Seal Repair
Discussion in '360/430' started by moritz55, Oct 2, 2015.
  1. GordonF355
    GordonF355 Formula 3
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    great write up but man this is alot of work!
  2. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Looks great. I will start working on my seals this weekend and report back. Thanks.
  3. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    #28 moritz55, Oct 10, 2015
    Kevin Rev'n .. I will repost some photos after some usage , maybe in 1month or so. In the "DIY Felt Trial Repair " file posted above look at pages 9 & 10 where I did some durability tests after 6days. I put the samples under Hot and Cold water, Heated it with a blow dryer to soften them up and bent the vinyl sample where the 3 areas were "Flocked" !!! These "Flocking" samples held up quite well ... :) :) :)
    Although this was day6 (vs day7) .. the adhesive is >85% cured. Only thing I noticed was that on the sample where I had the adhesive run because of applying too much - no scuffing up of that local area was done because it was outside of the sample region, I saw that a minimal amount of fibers came off.
    - This was the bottom sample lower right edge on page 10.
    I promise to post photos in the future after usage...
    Note: "GordonF355" ... doing both car doors took about 2hrs... from start to finish. Prepping the doors took the longest time. Then leaving it sit 24hrs before vacuuming the excess and cleaning felt off the car .. took about 30minutes the next day. It was not a long time. it took me longer to document all this material.... :)
    Many thanks..... and to all good "Flocking" luck on bringing your Felt Seals back to a good looking state!. .. Remember ... "Flock It" .... :) :) :)
    Mark
  4. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    #29 moritz55, Oct 11, 2015
    Well as the instructions indicated the curing is 72hrs to 1week for Full cure. The door Felt was very dry and hard so I decided to close the door and see how it held up after 72hrs. I would not wash the car or drive in rain until the 1week full cure passes. But after 72hrs it's tough enough for use.
    Here are the photos of before and after(72hrs) of the driver door which was the worse. I opened and closed the door 4-5times ... I am pretty satisfied and the "Flock It" Felt is pretty hardened. In the close-up photos you can see the New Black versus the compressed original, but without the flash from a camera I can't really tell. The lighting makes it noticeable.
    My OCD is very satisfied not that "My Eye Sore Crappy Felt" is GONE ..........!! :) :) :) :)
    Please let me know how yours turns out with photos as you attempt the repair.
    Good "Flocking" Luck to you all...:)
    Mark
  5. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Just completed mine. Will post pictures soon. Not too bad, actually not time consuming at all. The material does go everywhere and I tried to clean up after I was done. Even this time of year, the humidity is high, so I don't want the material to "settle" while waiting the 72 hours.
  6. GordonF355
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    That looks pretty damn good I must say! Well done!
  7. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Thanks "gordonF355" ... the joke is ... It looks "Flocking" good !
    "ncjetskier" - I have left my windows down and closed my doors after 72hrs. I went out Sunday cruising and between the sun/heat beating on it I noticed that the glass going up after closing the driver door was cutting into the adhesive slightly. Thus I lowered the windows ... closed the door and cleaned up the class letting it sit for the full week now without use.
    Overall it looks significantly better than the eye sores I had. I am sure the doors will reshape the New Felt similar to the way the original one has warn. So it will be interesting to see how yours look.
    Many thanks ....
    Mark
  8. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Thanks for the heads up on the cure time. Did the Flock it mess up bad?
  9. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    #34 moritz55, Oct 14, 2015
    Not too bad of a ware mark on the Flock IT. Here is a photo ... there is a a "shiny" crease where the window edge runs up and down. Some of the Felt and small amount of adhesive was sort of rubbed off onto the window sharp edge. The loose Felt I would expect but the adhesive was not fully cured as it was 3days cured vs the full week.
    You can see I have my door closed to 1 click (not fully closed) and the windows down while I wait the full week for cure.
    I am still happy with the results... it will be interesting to see how long term the durability will be.
    The photos make it worse because of the shiny texture differences.
    Mark
  10. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    "ncjetskier" - any pictures yet?
  11. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Yes, but I need help on how to post a picture (I never have posted a picture before). I did a search and it came up with 500 responses without any stating "how to post a picture". Thanks for any help.
  12. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    #37 ncjetskier, Oct 15, 2015
    The first picture is after removing the remaining velvet up to the bend in the seal using Goof Off. After the removal, the seal was lightly sanded with 400 grit sandpaper.
    The second picture is after applying the Flock It. It came out looking really good, but it is on day 4 of curing.
  13. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Wow "ncjetskier" ... your job looks great! Be patient on the full cure .. 7days .. :)
    I's 200% better than it was .. real nice job!
    It was worth the investment ..
    I am thinking even if I have to touch up spots every 3-4years if the new Flock-It doesn't hold up it's not a bad job to do compared to the eye-sore of having the felt look so crappy.
    Great work .... thanks for trying this ..
    Mark
  14. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Ok, finally the seven days of curing has been completed. Window went up no problem and did not affect the flocking. I opened and closed the door several times without any coming loose. Seems to be doing well.
  15. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Great Chris ... and nice job doing this repair. Thanks for taking the time to try this.
    We'll have to post some Pics in a month or two after we use tour cars more. Especially the driver side.
    Good luck ...Mark
  16. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Bump .. will post picks in about 2-3weeks .. will have been about 1month of driving...
    Anyone else give this repair process a try?
    Should we move this thread to the DIY section of the chat forum...?
  17. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    #42 moritz55, Nov 3, 2015
    I thought it was good time to post some durability photos of the overall Flock-It repair process.
    With cooler weather (in North America) it is a great time to line up projects that take some time for our cars.. :) Especially this Flock-It Felt repair for door seals which requires 1week to fully cure.
    In general I am very happy, however it is not perfect as new ..
    Passenger door is great ... no ware marks or degrading so no photos necessary. Maybe in 2-3months...
    Driver door has some ware along the window edge only which is identical to the original 12yr old felt ware mark. I have included photos showing the ware mark which is normal... but the razor edge of the window appears to have cut through the Felt and thus into the rubber adhesive so a very small amount of dried adhesive is observed on the glass edge. Not a biggie as it's still much better than the eye-sore it was, plus I clean my windows after every cruise anyway (OCD kicking in!) and it comes off easily. It's only observed when the door is open .. when closed it's perfect and I don't get air leakage noises while cruising any more!
    Otherwise overall I am extremely pleased ...
    One other note is that the camera flash highlights the thicker/lush New Flock-It felt vs the original. In normal light or sunlight you really can't see any difference between the new Felt and original Seal....
    3 weeks of Durability Use photos (narrow ones from my phone) compared to the Before larger photos ... the very last photo (red circle) shows some rubber dried adhesive rubbed off onto the window edge and it correlates to the repair section that is right under the window edge from the Before photo.
    Good luck... and next update will be in several months.
    I hope others give this a try for the Holiday Season !!
    Cheers.. Mark
  18. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I have driven my car several times since using the Flock It repair. So far, it is doing very well with no problems. I am REALLY happy Mark posted this. My car window looks much better.
  19. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Glad it's working out Chris ...
    I have put about 300+ miles on my car since doing this repair... plus a lot of open & closing of my driver door because of also doing some interior work in my garage.
    I showed my car last week at a local cruise and shared this repair with folks locally and they could not tell it was repaired when looking at it in direct sunlight.
    Good luck.... Mark.
  20. metaldriver
    metaldriver Formula Junior
    Apr 6, 2015
    631
    Houston, Texas
    Andy Vecsey
    #45 metaldriver, Dec 31, 2015
    I flocked the bottom of my driver's door seal last weekend (before it got cold) with great results. It cured for thirty-six hours at 75 degrees F inside the garage before a cold front arrived. Results are fantastic, and if I did not point it out, one can hardly tell where the old-new fuzz ends-begins.
    Eager to begin this project, I was remiss in not taking a "before" picture. Use your imagination to picture a 14" section of the factory fuzz being partially abraded away from the seal. It was half-fuzzy, half-bare along the bottom from near the fuel valve to about the mid-point of "Ferrari" on the door sill.
    Unlike Mark’s car where the abraded fuzz was visible where the glass makes contact above the door, my abraded fuzz was visible only with the door open but 100% concealed when the door is closed. My OCD compelled me to make it right … just in time for our local Supercar Saturday this weekend. ;)
  21. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    Thanks for posting, ordered a kit to repair the fuzzy felt by the door will.
  22. moritz55
    moritz55 Karting
    Oct 14, 2011
    64
    Raleigh, NC
    Mark Morizio
    Great looking job "metaldriver" .
    My window edge has stopped rubbing off. I think it has created a nice edge into the weather seal fuzz. Since I have done all my original repairs months ago - I have put over 800miles on the car and it has not come off.
    I am pleased as well... I will post picks at the 4month stage after I did all my repairs.
    Happy New Year all !!!
  23. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,104
    South Florida
    Greg S
    Did you take the piece off or did you do the new flocking while it is still installed?
  24. metaldriver
    Apr 6, 2015
    631
    Houston, Texas
    Andy Vecsey
    I left the door seal weather-strip in place ... taped off both sides (carpet and sill) with blue painter's tape ... peeled right off afterwards with no mess.
  25. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    After a month and several drives mine still looks really good. The OP of this thread has my nomination for "tip of the year" thread. Thanks for sharing.
