Disconnecting bypass muffler valves? | FerrariChat
Discussion in '360/430' started by Jagbuff, Apr 1, 2011.
  1. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Has anyone disconnected the vacuum line to the muffler bypass valves? Do the valves stay open? Any adverse effect on the way the car runs?
  2. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Which car? 360? 430? I invite you to make a search as this subject has been covered so so many times on both models ;)
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Search will reveal a number of threads with comments and "how to" detail but yes, lots of people do it, you can either pull the vacuum pipe off (and plug it) or pull the electrical connector off the valve control solenoid or you can interrupt the wire controlling the solenoid and wire a switch from the cockpit to turn on and off factory setting at will.
    Yes they stay open.
    Adverse effect? They don't sound great at tick over with valves open (in my opinion) but once you're rolling they're fine. Perhaps a very marginal loss in low torque. Downshift heel and toe a little more satisfying. No adverse effects, no CEL, no louder above 3k than standard.
  4. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    ..yes, haven't had my morning joe - I am a little slow - sorry :)
  5. F1.360.LOVER
    F1.360.LOVER Formula Junior
    Dec 12, 2009
    476
    Central Florida
    Nate
    I just unplugged the electrical connection to the valves on my 360 yesterday. Sounds great. No issues. Wish I would have done it sooner.
  6. TheMayor
    104,835
    Vegas baby
    I had the dealer do it. They just plugged the tubes with a large bolt. It did nothing to the drivability or the emissions. It just sounds louder at low RPM's and no longer is schizophrenic (soft.... LOUD!..... soft.... LOUD!).
    The biggest disadvantage is your neighbors may object when you start up and roll out past them.
  7. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    No problem ;). The best solution I can advise you is to install the Capristo Remote Control so that you can decide yourself when you want to have the exhaust valves open. it's a good solution also for your neighbors ;) and when the engine is still not entirely warmed up, it's much smoother to drive the car with the valves closed. Then when the car is at the right temp, a simple press on the remote control button, and there you go.
    Here is the DIY guide which may help : http://www.ferrarichat.com/forum/showthread.php?t=310472&highlight=DIY+remote+control
    Stef
  8. Gh21631
    Gh21631 F1 Veteran
    8,968
    East
    What tubes? Your are only disconnecting the electrical connection. What am I missing?
  9. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,809
    Yes and No. It depends on the type of muffler you have.
    If you have the factory sport CS muffler on the 360 or the factory F430 muffler and you disconnect the vacuum line to the muffler bypass valves you will have a louder exhaust sound during idle and at lower rpm but you will lose some noticeable power at lower RPM's. This is documented by the factory per my service advisor and I even was able to notice the negative effect on my 360.
    But if you want to try, you can. The way to avoid the CEL is to simply plug the vacuum lines with small pins.
    I can not say about the effect on power with the standard factory muffler on the 360.
  10. arizonaitalian
    arizonaitalian Two Time F1 World Champ
    Oct 29, 2010
    20,451
    Wyoming
    Vacuum tubes. See other posts. Mine has screws inserted into the two (now disconnected) vacuum hoses.
  11. testdrv321
    testdrv321 Formula Junior
    Oct 31, 2010
    259
    Long Island, NY
    Edward Newman
    I just ordered two small shut off ball valves, hose barb to hose barb to insert inline with the vacuum line to the diverters. This way I should be able to quickly change without having to plug or unplug anything. I'll take pics when done.
    Ed
  12. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    Guess you meant 4K right? That's when the valves open. I can tell you it drones like crazy from 3 to 4K, so this mod is an acquired taste. Valves were removed when car was bought (FabSpeed pipes and tips), so don't have an easy way to try both modes. Have stock pipes, but tips are just awful, so will stay off. Need to attend a large F430 gathering to personally listen to different options.
  13. alcc
    alcc Karting
    Sep 2, 2010
    183
    Santa Barbara, CA.
    I am (or the seat of my pants is) reasonably certain unplugging hose causes slight loss in low end torque. Worse, it causes constant over-run on lift throttle. Some may like that added rawness. Me, I think that makes the drive "unflowing."
    Now am content to leave things as factory intended it.
  14. tazandjan
    39,019
    #14 tazandjan, Apr 2, 2011
    ELP- It varies where they open, and 4000 rpm is actually less correct than 3000 rpm. Here is a plot from Stef from the factory data.
    So he meant 3K rpm.
    Taz
    Terry Phillips
  15. Gh21631
    Gh21631 F1 Veteran
    8,968
    East
    Do yo have a pic?
  16. Gh21631
    Gh21631 F1 Veteran
    8,968
    East
  17. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    #17 ELP_JC, Apr 2, 2011
    Well, 4K is A LOT more correct for me :). In fact, it's well above 4K if you're not on the throttle, like when cruising. At 3K you have to basically be at WOT. Interesting find; learned something new today. But what the heck 'hysteresis' means in this case???
  18. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I was referring to a 360 as it happens and unless you're on a very light throttle the valves open up pretty much on 3k rpm.
  19. Logical1
    Logical1 Karting
    Apr 14, 2007
    167
    CA
    Dave
    Disconnected and plugged on my 430 two years ago. Sounds better. Great deep growl at low RPM. No noticeable loss of power. Frankly, it cost zero and I haven't heard anything better.
  20. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    I did mine a while ago. It's super easy and should you ever want to keep things quiet, it's easy to simply plug the tubes back on the valves.
    Takes 1 minute per side.
  21. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    JC, the hysteresis range of my table are the areas where the valves are in "transistion" from closed to open. As the exhaust solenoid and valves are very slow to react compared to a computer or even the engine response time, it represents the delay they need time to open. Hysteresis is very usefull here as it prevents also having the exhaust valves opening and closing when you're close to the decision points where the valves must open (hunting).
    Hysteresis is a lot used in electronics as many components have this natural property.
    Cheers,
    Stef
