Disconnected oxygen sensor | Page 2 | FerrariChat
Discussion in '308/328' started by chrisbinsb, Oct 11, 2012.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Again, can't say re the 308 HP/Ferrari figures but for the 328, the 1/4 mile times in the US road test of 14.2 pretty much agrees with the HP (260 flywheel) and weight spec from Ferrari.
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The point that I was trying to make and appears to have been missed is that the fuel economy you achieve is significantly lower that what is typical. With a properly set-up CIS system, running in closed loop, both performance and fuel economy will improve. So to get back to the BASIC, yes...the car will run with the O2 sensor disconnected. However, better overall performance and fuel efficiency will occur when it is connected.
  3. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Whoa, whoaaaoao. Relax guys. We're all friends here.
  4. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    You are 100% correct.
    Problem is you can spend 4 figures trying to get it perfect and STILL have a surge with an O2 hook up. For those that do, dont be afraid to just unplug it. I went through this a few years ago myself. I spent the first 15 years with it unhooked and tried to go a
    different direction with it. I ended up just unplugging it again and got my old silk smooth performance back.
    It is what it is I guess.
  5. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
  6. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I'm reviving this old thread as I think it's time to unplug my O2 sensor. Back when I first wrote this, the sensor was found to be unplugged and I was wondering what to do. My mechanic did hook it back up and there was no apparent effect positive or negative so it was left plugged in.
    Recently, the sensor was replaced while trying to pass smog (didn't help, new cat was needed). Since I got the car back, I noticed the distinct surging. Seems like I have two choices - spend loads of time (and $$) trying to tweak the surge out or disconnect the sensor and drive on. With Tommy's advice above, I'm leaning toward the latter.
    Assuming I do that, where and how is the sensor best disconnected? I will presumably need to reconnect it again for the next smog test.
    Thanks!
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Just unplug it - depending on the brand of sensor, it might have a plug somewhere on the wire from the sensor itself, the wire could plug directly into the end of the sensor, OR it could plug into the control box. Disconnecting it at whichever plug it uses will do the job.
    However, I'm one of those who believe you should sort out the issue as opposed to disconnecting the sensor… ;)
  8. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    If it is just a subtle issue that you (like me) cannot deal with , just unplug it. It isn't worth the expense to "fix" that little problem.
    As I have said before, mine has been disconnect for 16 years and almost 60,000 miles (I have 115,000 or so on the car now). Runs fine. Always has without it.
  9. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,128
    SanFrancisco BayArea
    1983 US 308 GTS QV
    This thread is very interesting to me. Chris, you are in Santa Barbara, so presumably you are subject to the same SMOG test stringency as I am in the San Francisco Bay Area.
    Have you passed SMOG with the O2 sensor unplugged? If you have, it is interesting. That means that the car can stay within SMOG's tolerance of the stoichiometric point without the lambda feedback.
    I have a 1983 QV so I am running K-Jetronic Basic with an air pump. If you can pass your newer car in Basic mode, it begs the question as to whether the air pump is overkilling the emissions. I bought the car last year just after the license was renewed, so my first SMOG will be early 2015. It passed spectacularly in 2013 and I am now wondering if there is a benefit of having an air pump (there's gotta be something!).
  10. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I just passed smog with a new cat and new sensor attached. Not sure what the numbers would look like if I tried without the sensor. Can't really speak to the value of the air pump, but if it passed easily, that is good news! I suspect the mine may have needed some creative testing to pass prior to my purchase a couple years ago.
  11. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I think it's just going to make me more and more crazy and I'm not really in the mood to send my mechanic on a fishing expedition to find the right tweaks to perfect it so disconnection is my current choice. Where physically did you disconnect it?
  12. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Generally I agree - my preference would be to sort it out but at the moment, if it does no harm, I just to have the car up and running and being driven. Got plenty of other things to pick away at anyway...
  13. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Just to wrap up this thread (for the 2nd time :)) - I unplugged the sensor and sure enough, the surging disappeared immediately. For now, I'm going to stick with that - the next time the car is in for related work, maybe I'll have them try and plug it back in and see if they can smooth it out. For now, I'm going to drive and enjoy. That surging was making me nuts!
  14. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    I made an attempt back about 7 years ago to run mine with it hooked up. I bought a new one and went to the shop. Nothing we did would eliminate that subtle surge and it drove me out of my mind. It wasn't that bad probably to someone else but I am super sensitive to these things. For example, if my steering wheel is even a 1/4 inch off center, I can barely drive it. Has to be perfect.
    Finally I was driving to work one morning and had enough. I pulled over and unplugged it before I got there and I was only about 3 miles away. I just could not stand it for another second.
  15. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Uh oh. My steering wheel has always been about an inch of center, guess I've for another project to look at......
  16. Saabguy
    Saabguy Formula 3
    1,783
    Shreveport, LA
    FOR THE LOVE OF GOD .. DON'T pull over on the way to work and disconnect your steering wheel!!!!
    .. sorry.. I .. I just couldn't help myself.. someone had to say it..
  17. spiderscott
    spiderscott Formula 3
    1,661
    Ratarossa HQ UK
    Ratarossa
    Hi guys sorry for resurrecting this thread. Ive a related question to the 02 sensor.
    Ive recently imported a US 85 QV 308 GTS into the UK and in the process of doing a Euro look conversion to the car. having fitted the rear lower valance the US exhaust system is so different it cannot work with the Euro rear body work and protrudes out of the car much further.
    I now looking into ways of fixing the exhaust issue and part of this is converting the best part of it to euro spec: exhaust box, rear manifold and exhaust inlet pipes.
    My question is, to do this i need to remove the CAT as its not part of euro spec, however i have both an O2 sensor and thermocouple plugged in.
    Reading this thread it looks like i could lose the o2 sensor without causing any knock on issues, but will this also be the same for the thermocouple if I remove that completely ?
    Cheers
    Scott
  18. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    The thermocouple is there to trip the "Slow Down" light if your exhaust goes rich and causes the CAT to overheat. If you are removing the CAT... you can lose the whole SlowDown system
    If you decide to remove the CAT ECU in the trunk... let me know... they are NLA and mines been broken for months.
