Dino Saga index 060311 The first Dino Saga thread was posted on July 24, 2005. A couple of days after posting I realized that year-month-day was not sortable so switched to yymmdd on the second installment. Now that there are over 30 threads it is obvious that an index of the subject matter would be useful. New threads will include subject matter in the title. Here is an index by date with subject noted. Hope it helps. John Dino Saga 072405___Intro of car and driver, steering wheel, tires Dino Saga 050731___Broken head stud, radio Dino Saga 050807___Windows, gaskets, wipers, dash cover Dino Saga 050814___2nd gear fixes, shift gate Dino Saga 050821___Front shock brackets, lifting tools Dino Saga 050828___Essential tool kit Dino Saga 050904___Removing smog gear & AC, fan motor, oil hoses Dino Saga 050911___Ignition switch, alternator, regulator, starter, flasher Dino Saga 050918___Carbs, air filters, idle stop Dino Saga 050925___Alternator junction box, carb air duct Dino Saga 051002___Door window lip seals Dino Saga 051009___16 wheels, tires, wheel repair Dino Saga 051016___How to shrink digital pictures and keep them sharp Dino Saga 051023___Door latches, locks Dino Saga 051030___Water pump repair Dino Saga 051106___Stuck caliper, bad brake line Dino Saga 051113___Rebuild rack and pinion, tie rod ends, ball joints Dino Saga 051120___Alternator shaft and bearing re-work Dino Saga 051127___Engine rebuild, taking apart, grisly finds Dino Saga 051204___More horribles, workmanship, UPS, GT Car Parts Dino Saga 051211___Starting back together Dino Saga 051218___Need new head studs, found same, Maranello Parts Dino Saga 051225___Heads on, cams timed Dino Saga 060101___Gearbox on Dino Saga 060108___Starter Bendix repair Dino Saga 060115___Engine back in car Dino Saga 060122___All hoses, wires back. Ready to fire Dino Saga 060129___200 miles and no smoke! Motor mounts, clutch, 1-R shift Dino Saga 060205___Fine tune clutch, discuss 2004 rebuild Dino Saga 060212___Adjust forks in gear box Dino Saga 060219___Stone guards, bolt supplier Dino Saga 060226___Rebuild reprise, car pics in mountains Dino Saga 060305___Piston and cam suppliers, transmission oils Dino Saga 060312___Distributor rebuild
John, Your posts are just superb and make me itch to get my hands on my car, Ive owned it nearly a year now and have actually driven it 180 metres up and down my drive the day it was delivered in April and after that i put it in the garage and couldnt stop myself from taking more and more of it apart! My wife couldnt believe i had done this to what now appeared the biggest most expensive heap of junk she had ever seen! ( what the hell do they know?) however it is gradually all coming together and i hope to have it back from the shop to reconstruct in the next two months. Your posts are invaluable to me as i intend to do most of the day to day running repairs myself as i like yourself get great pleasure putting my own stamp on things. Thanks John keep em comeing! Graham Paske
More Index Dino Saga 060319___Distributor rebuild Dino Saga 060326___Spark Plugs, Wires Dino Saga 060402___Instrument Lights, Dimmer Dino Saga 060409___Heater water valve
