Any updates on the availability? I have a need of one for early an E series (Italian Market built)
As of yet Superformance do not stock this item. I'm not sure if the M series firewall is different to the E series so perhaps an M series owner can help on that score?
I had to place mine around 20 years ago, and used a vinyl, foam composite like that referred to by the link "passenger engine fire wall foam " Synchro at #7 viz, then Niccry #2 viz: After much searching I am replacing my rotten foam with a product from a company called 'Foam Techniques Ltd.' Foam Manufacturer, Foam Convertor UK - foamtechniques.co.uk They will make an 8-9 mm thick reconsituted NBR foam that is very similar to original in density (FT80) with a 2-3mm neoprene facing bonded to it (Ft-CPN) which is quite firm. The vinyl surface was black and textured and the material would be more effective than simple foam, with the added advantage that it would take up water - and its stood up well for the 20 or so years. Only negative is a tendency to delaminate a little at the exposed edge
Tom Yang finds original firewall foam has disintegrated http://tomyang.net/blog/2020/05/23/crumbling-foam/?fbclid=IwAR2bXsZXhEnYZm14oFq6zI8HqPEpnqDpgIn2ktRsLTYpt1--qQR2TNZBbaQ
