Dino 246 window motor mounts. | FerrariChat
Discussion in '206/246' started by JAMES NICHOLSON, Dec 8, 2019.
  1. JAMES NICHOLSON
    JAMES NICHOLSON Karting
    May 22, 2019
    91
    JAMES NICHOLSON
    Can anyone help?
    Reference:- 1973 Ferrari Dino 246.
    This maybe a stupid question but is there a difference between left and right hand electric
    window motor mounts?
    Regards,
    James.
  2. racerboy9
    racerboy9 F1 Rookie
    2,671
    I installed mine a couple of months ago and I couldn't see any difference.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The mounts are the same adjustable slots in both doors, final position dictated by cable tension sum.
    As in either side cable routing, the topmost cable out of the motorwind starts upward and over the closest top pulley.
    That will set the order of your cable routing
  4. JAMES NICHOLSON
    May 22, 2019
    91
    JAMES NICHOLSON
    Synchro,
    Thank you for your reply and explanation regarding Dino 246 wndow motor mounts.
    Much appreciated.
    Regards,
    James.
