Differences in Ferrari 360 Model Years | FerrariChat
Discussion in '360/430' started by nsortor12, Aug 8, 2013.
  1. nsortor12
    nsortor12 Formula Junior
    Feb 1, 2013
    436
    Louisville
    Are there any visual differences that were made during the Ferrari 360's run? Been trying to do some of this research by myself but I have yet to find any differences by myself. :)
  2. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Not really.
    The major difference between earlier and later model years have to do with the software controlling the F1 system (if the car is equipped with the F1 gearbox). These can also be updated on earlier cars at a reasonable cost.
    I have a 2001 Spider, and regular people can't believe it when I tell them the car is 12 years old. Ferrari people still have to ask me for the model year when they see it because, generally, you can't visually tell a difference between earlier and later model years.
    That pretty much carries over to the F430 as well, save for the CCB feature on later model year cars.
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,152
    Wash DC area
    Robert
    No difference in body design, except, some later models you could order small sunroof "holes". Externally, you could order with standard "starfish" wheels or pay extra for challenge style wheels. You could also upgrade front and rear challenge grills as well. Oh, and you could order with or without Scuderia Shields on the fenders.
    Thats about it, for the external body look/design.
  4. BSU
    BSU Formula 3
    Mar 30, 2008
    1,012
    TX
    This is a reach. On Modenas the cap to the power steering fluid reservoir (at the front of the engine) can either be silver like the oil and gas caps or black. Not sure if this is a model year difference.
    I had my 99 parked next to Cozfcar's 04 and this was the only difference I noticed.
  5. daflk
    daflk Formula Junior
    Jan 27, 2013
    257
    Hong Kong
    there are plenty of part differences, including f1 software. get a 2002 and up which has most of the issues sorted, 2003 if you want the latest f1 software (2002 and up, especially spider, which has access compartment so you don't have to remove converitble top every time you need access to engine bay). plenty of threads on about this here.
  6. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    The early 99s and euro cars do not have pre cats.
  7. Skidkid
    Skidkid F1 Veteran
    9,478
    Campbell, CA
    John Zornes
    This isn't correct. No need to remove the top to access the engine. Maybe to change the clutch on the very early Spiders but not to do most everything else.
  8. mikegr
    mikegr Formula Junior
    Jul 3, 2012
    414
    Europe
    i think 2003 and up models are upgraded in some parts like wiring and more, so they can be a bit more reliable
  9. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,152
    Wash DC area
    Robert
    Guys the OP asked about "visual" differences.
    I believe I got them all in the 3rd post. Maybe someone wants to check that and see if I got them all. Thanks.
  10. Skidkid
    Skidkid F1 Veteran
    9,478
    Campbell, CA
    John Zornes
    Yep, I think you got them all. No real visual changes that don't bolt on/off.
    They changed a battery cable but I am not aware of any wiring harness changes. Oh yea, they added a GND pin to the OBD port but I don't know what year they finally fixed that. It is ridiculously easy to do and there is a campaign for earlier cars.
  11. Mikestradale
    Mikestradale F1 Rookie
    Jan 25, 2006
    2,599
    Netherlands
    What about the headlights? I thought 1999-2000 models had normal headlights and 2001-2004 have xenon headlights? Or was it an option for the 1999-2000 cars and standard for 2001+??
  12. SnowmanUK
    SnowmanUK Karting
    Dec 11, 2010
    174
    London, UK
    The 'Ferrari F1 World Champions' badge on the glove box appeared from 2001 onwards, I believe.
  13. nsortor12
    Feb 1, 2013
    436
    Louisville
    Thanks for the responses! Very useful information! :)
  14. tazandjan
    39,007
    John- The wiring harness changed in about Nov 2003 to fit a new 50 amp F1 pump relay with a different connector from the old 30 amp relay. Same for the CS and 575M.
    Visual differences, no.
  15. jpk
    jpk Formula Junior
    #15 jpk, Aug 10, 2013
    Interesting, I see my power steering fluid cap is black. My oil cap and (what I think is) my F1 fluid cap are both aluminum. Is the newer power steering cap identical to those aluminum caps, or is it different?
    Edit: Nevermind. I answered my own question. Ricambi lists the same cap as the F1 cap for the power steering reservoir. So they are the same.
  16. Jonkheer
    Jonkheer Formula 3
    Aug 29, 2010
    2,250
    The Netherlands
    Christiaan
    Yes, first it was a option and 2001+ it was standard.
  17. PurpleHaze
    PurpleHaze Karting
    Jul 25, 2010
    84
    Berkshire, UK
    I think the air boxes changed colour at around 2001 too. Earlier cars seemed to have gloss black ones then they changed to brushed aluminium-looking.
  18. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,582
    super soft shift pattern introduced.
  19. M. Brandon Motorcars
    Sponsor
    Sep 4, 2007
    1,827
    Houston, TX
    Michael Foertsch
    Can you elaborate on this? Are you talking about a change in the F1 programming? (I can't imagine how the 6-speed gated manual would have changed)
    I just haven't heard anything before about a change related to the F1 in 2005.
  20. sparetireless
    Nov 2, 2003
    1,582
    it seemed about as fast as the other years, just a lot less jerky, I liked it the old way in the 2003 and 2004.
    The 2001 was super hard to take from 1st without bucking.
