Detailing engine bay - how to maintain shine? | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Feb 17, 2006.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    After I wash/clean my engine bay, the plastic looks a bit dull. You can spray with detailing spray, but after a couple of drives, its dull again...
    Any products out there that actually last a bit? Thought about clearcoating some bits, but with the engine heat it would likley just flake off...
    How do you guys restore the shine to plastic, permanently? Buff it? Coat it? Silicone sprays???
    Also, the cloth covered hoses in my engine bay are grimey...how do you imrpove those, short of replacement???
    I love how my engine looks after a clean. But withing 2 weeks its back to baseline...
  2. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    try 303aerospace..... Awesome stuff. Pricey. Should be able to find at RV places.
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  4. ferraristyle
    ferraristyle Karting
    Jan 7, 2005
    63
    MD
    Sean
    I use a product called Trim Shine by Stoner for all the shows/concourse I participate in.
  5. bpu699
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    How long does trim shine last??? If its like armor-all, it fades in 1 week. Is this stuf better? I also heard about product called engine-kote (or is it motor-kote) that is supposedly a thick acrylic coating of some sort that lasts months. Anyone use it?
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,021
    Groton, MA
    Verell Boaen
    Other than the headers themselves, the engine compartment temperatures aren't high enough to hurt most paints.
    For a glossy black finish, try RustOleum black vinyl paint from Home Depot. Clearcoating should also work. A urethane clearcoat would stand up to just about anything you'd use to clean the engine as well.
  7. Eric308gtsiqv
    Eric308gtsiqv Formula 3
    Nov 26, 2001
    1,956
    Orange Park, Florida
    Eric Eiland
    #7 Eric308gtsiqv, Feb 17, 2006
    Believe it or not, I've had the best and quickest results simply taking a shop rag, spraying it with WD-40, and wiping everything down in the engine bay. It is especially effective at removing grease and grime off of plug wires, etc. and renewing the shine to rubber items like air cleaner hoses, etc.
    For a very long-lasting facelift to the aluminum / metallic surfaces (like valve covers), apply a small amount of "Rub-N-Buff" in the matching color. Works great on door lock/latches too.
    I use other various products as well for the applicable surfaces, including touch-up paint, when doing the initial detail -- products like Mother's Back-to-Black (for black painted metal / vinyl / plastic surfaces) and assorted Griot's Garage products. Also, you might try experimenting with different methods like using fine grade steel wool, wire detail brushes, etc.
    Once the thorough detail is done, then I simply maintain it with WD-40 for the most part. A good spray on "shine" product, like the one's mentioned by other F-Chatters, are great too...especially for shows.
    Here's a pic of my ex-308 engine bay after detailing (I've posted this pic in the past, but it must have been lost in the old server crash):
  8. bpu699
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    Nice Eric...
    How do the top restorers in the country deal with plastic bits? I find it hard to believe they just clean it off and spray it with a dressing...
    Do they buff the plastic? Clearcoat it?
    Melt it down, mix it with shredded 100 dollar bills, and remold it?
    Seems to me, any new car engine bay looks sharp for a year or two then fades. I have had good luck with some dressings, but I hate doing it every couple of weeks...
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,057
    Dumpster Fire #31
    SMG
    i'm with Eric, WD-40 has worked great for me for yrs. the properties of WD-40 keep the road grime and dust to an minimum and keep the parts nice and shiney or buffed if you rub them down after letting the WD-40 dry a bit.
  10. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    I have heard Pledge does a great job although the poster was not specific as to which Pledge product my guess is furniture polish?
    303aerospace or even 303Marine is a good general cleaner irrespective of bling it keeps electrics from arc risk.
  11. RedFireDragon
    RedFireDragon Rookie
    15
    Under a Rock
    Angela B
    The shine to get is by using Stoner Trim Shine. It lasts more than a couple of weeks and doesn't turn your engine "brown" or attack dust like other products. Also to the clean and maintain plastic Novus Plastic Polish works GREAT! A good web site is www.autodetailingrus.com. They have both products and more. Plus they have some good detailing articles that is helpful.
  12. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    #12 sparky p-51, Feb 17, 2006
  13. GordonF355
    GordonF355 Formula 3
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    I also use the 303 aerospace stuff and it works awesome... It doesn't just seem to put a layer of gunk on top of the surface, but seems to penetrate somewhat as well and looks great!
    It is also great to use for the leather dash as it is 100% silicone free and also blocks out 100% uv rays!
    gordon
  14. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Check Spasso's postings. He has a great engine. I think it's in the showroom section. It's also in the tech and someplace else. Go to the Spasso profile or members listings and see what he's posted. It's gotta be the best engine I've seen on here.
    Bob Wassam
  15. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    I have always been worried about getting WD40 / 330 / etc overspray on my exhaust headers. Do you guys find that it either smokes like crazy or leaves a burned-on residue?
  16. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    Have not noticed anything. I try to keep spray away from that area as much as possible. Have not noticed any smoke. WD is a kerosene based product and evaporates quite readilly without leaving any resedue, but odly enough, it makes things shiney. Check out SPASSO. Cleanest momo out there.
  17. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    Eric,
    Nice engine. Your air plenum looks too good to be original paint (meant as a complement) . Did you remove and repaint it? I have tried to remove it but gave up after not being able to remove the back retaining nuts - no clearence to turn a wrench and no room for a socket. I'm looking for a clue....
    Carl
  18. Shark49
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    You know WD-40 is a great all around product but I just remembered something from days gone by. When I was really hardcore into RC Hobbies, mainly RC cars and planes, WD-40 was always mentioned as the worst product to but on your bearings etc. because the oil in it actually attracts more dirt, essentially lowering the life of your bearings and possibly slowing your car down during racing... We used a silicone based product that names escapes me. I of course wouldnt use that on my engine. So I wonder if using WD-40 on the engine is just asking for more frequent cleanings? I still use it but just putting that out there for opinions.....
    -Nate
  19. Eric308gtsiqv
    Nov 26, 2001
    1,956
    Eric Eiland
    Thanks Carl...
    Yes, I did remove, strip, repaint, and reinstall the plenum. Those forward bolts are a bit of a pain to get at and unbolt. I recall spreading a protective quilt over the rear of the car, laying across the rear, and sort of hugging the plenum while feeling for those bolts -- then slowly working them loose using a combination of open end and socket wrenches. Sometimes I had to take small turns, oftentimes flipping the wrench between turns, due to all those fuel injection lines in the way. IIRC, it took about a half hour or so to pull the plenum. BE VERY CAREFUL WHEN DOING THIS, as the washers on the underside of the rubber gaskets between the plenum and the intake can (and will) fall off and easily end up falling down in the intake openings! Thankfully, I noticed the washers in time to prevent this.
    While you can probably reuse the gaskets, I'd suggest ordering a new set of gaskets for all the items that attach to the plenum from the dealer or elsewhere. Here's a link to a past discussion on this topic (sorry about the missing pictures...they were lost in the infamous "server crash"):
    http://70.85.40.84/~ferrari/discus/messages/256120/4741.html
