Dead battery | FerrariChat
Dead battery
Discussion in '360/430' started by Forcefed, Oct 15, 2015.
  1. Forcefed
    Forcefed Karting
    Aug 14, 2009
    203
    United Arab Emirates
    Hello everyone.
    I have searched this issue and most threads discuss which replacement battery to buy. I have a 2009 Scuderia that hasnt been driven for over 8 months. The battery is completely dead. The issue I am having is I cant get the doors to open so that I can get to the battery to replace it. I can turn the key manually (driver side) and I can feel it unlocking but I cant open the door. I am assuming I cant open the door because the window isnt dropping down a bit to clear the weather strip. I tried to push down on the window with one hand and pull on the door handle with the other still no go.
    any advice or help is appreciated.
  2. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Maybe the rubber got stuck. Will have to pull harder I'm afraid as I don't know another way..
  3. ph12
    ph12 Karting
    Jun 28, 2015
    178
    Los Angeles
    It probably doesnt have anything to do with the battery. The handle mechanism is control by a cable. That cable rust over time. Once it does you cant open the door. Its a pain in the ass but basically you need to disaseemble the door panel and replace a $85 cable that probably cost $5 to make.
    How do you get in with the door closed? I dont know if you could..
  4. SCEye
    SCEye F1 Rookie
    Aug 28, 2009
    2,950
    Norcal - Peninsula
    Scud does not have passenger side key hole?
  5. blackbolt22
    blackbolt22 F1 Veteran
    Sep 25, 2007
    5,752
    Boca Raton, FL
    Mr. Anderson
    #5 blackbolt22, Oct 15, 2015
    Ugh. What a dilemma. I would call the dealer. Good luck.
  6. Forcefed
    Forcefed Karting
    Aug 14, 2009
    203
    no the scud doesn't have a passenger side key hole. I just left it alone for the time being. will update you once figured out.
  7. treue
    treue Formula Junior
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    FF,
    The door window inserts about a centimeter into the upper rubber seal at the top of the window. Unfortunately, the rubber gasket is made rigid by a piece of metal trim that is inserted into a groove in the outside of the gasket. This is why the door cannot be opened without breaking the glass, absent the window drop. Until this trim is removed, the gasket cannot be moved out of the way to allow the window, and thus the door, to swing open.
    You can try to remove the trim strip yourself, but, not having done it myself, I cannot predict how well or easily this will work. I think that damage of the trim strip in removal, absent previous experience, would be likely. Of course, a new trim strip could be purchased and installed after you correct your problems.
    You could always be a sissy and get a body shop guy to visit your car (assuming the car is in gear or has the parking brake set) to correct the problems.
    Also, suggest you keep the car on a battery tender in the future to prevent a repeat of this little scenario.
    Tom
    2007 F430F1 Coupé
  8. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
    Is it possible to remove the rear under tray and put 12v cables to the starter connection to reverse power the car just to allow the window to drop?
  9. treue
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    #9 treue, Oct 19, 2015
    PS FF,
    I looked at the 430 Workshop Manual, Section M2.10, and it said the trim strip along the outside of the upper window seal was held on with several screws. I verified this on my own car. You have to pull the seal out from below and beneath the trim strip to expose the screws. After the trim strip is out the seal should flex out of the way allowing the window and door to swing open.
    Having said all of the above, I think Fred might have a point. There is a big, fat hot wire going to the starter and you can ground on the starter motor body. All you need is a 12VDC source, like the new battery you will be installing in the car when you can get the car open, and that should allow the window to drop for easy access to the old battery.
    Tom
    2007 F430F1 Coupé
  10. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
    My S mbz decided to lock me out one day because the battery was dead. That is how the tech got the trunk opened to allow a new battery to be installed
  11. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    576
    North east, USA
    8 months? Scud abuser.
    Most likely the seal is stuck to the window - you will need to separate it with a make your own tool, small piece of wire hanger is ok if your careful not to damage the seal or window, something thin, plastic with a sharp 90 bend is better.
    you can carefully pull the door open a bit if the key unlocked it, while pushing slightly on the top rear of the window, the door should open about 1/4-1/2", push the rear top window into the seal while pulling the door open with your finger tips (not with the flimsy door handle that will break). Slow and careful, it will open without power and you wont break anything.
  12. hessank
    hessank Formula 3
    1,742
    Canada, Florida
    Fred
    To the Op: Can you give us an update on how you managed to open the doors to enable a battery change?
