Dead battery. How long should I Drive to recharge it? | FerrariChat
Discussion in '348/355' started by ready321now, Dec 12, 2014.
  1. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    484
    New Jersey
    After a week of non-use, all I heard was clicking when I tried to start the car. I jump started it off of a 6 cylinder Ford Ranger from the terminals in the engine bay. Curious how long I should be driving it to recharge the battery fully? I'm going to an event tomorrow and plan on bringing the car but don't want to wake up to another dead battery...thanks guys
  2. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,943
    St. Louis, MO
    Eric
    Usually a 30 minute drive will do the trick. Or, just let it idle in your driveway for awhile.
  3. FerMaz
    FerMaz Formula Junior
    Feb 11, 2007
    355
    So Cal
    Mel
    If your battery is dead dont try driving to recharge it. This sometimes puts too much of a burden on your alternator and burns it out. Get a battery charger and fully charge the battery before you take of.
    Mel
  4. cuneo
    cuneo Formula 3
    2,454
    A week isn't that long at all to drain that much, you might just put a new battery in. How old is the current battery?
    As someone else said, alternators aren't cheap.
  5. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Correct answer !!!
    " serenity now "
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,631
    And don't remove the battery charger until the battery reads 14.2 V.
  7. ready321now
    Jan 5, 2013
    484
    New Jersey
    Well I drove it for a total of about 45 minutes. I brought the car home and restarted it and it was fine. my voltmeter showed 13.75 volts constantly while driving. That is the same reading I always get. when the car is off the voltage meter reads 12.94 all of the time...Comments? the alternator was recently rebuilt. About 1500 miles ago
  8. Eric C
    Mar 20, 2009
    10,943
    St. Louis, MO
    Eric
  9. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    421
    H-town...TEXAS
    you have a drain somewhere..
  10. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,605
    VA
    Brendan
    I highly recommend removing the front right wheel and inspecting the battery terminals and cables for corrosion. When my car was having battery trouble, I decided to inspect and my ground cable was so corroded it needed replacing. I also replaced the battery and now keep it on a tender at all times. A bad ground will end up ruining your battery even if you keep it on a tender.
  11. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    I also think there is something else going on....Mine sat for a month and fired right up. I often go more than a week or three without driving it with no problem. I just got a battery tender because it will be sitting for 4 or 5 months. If its going to sit for extended periods you might want to consider that option.
  12. ready321now
    Jan 5, 2013
    484
    New Jersey
    I think all 355's have a drain correct? Isn't that why we are not supposed to let them sit for periods of time without being on the tender? How would I know if mine has a drain? I don't even know where to begin. It was in the thirties when I tried to start it very cold out. I am definitely going to get a battery tender. I've paid very close attention to the voltage meter i have in the lighter socket. ... the car is running at 13.75 pretty much constantly like it always does but the voltage meter goes down to 12.56 when the car is off. Any feedback? Thanks guys I appreciate it.
  13. ready321now
    Jan 5, 2013
    484
    New Jersey
    the battery is less than a year old. Is 12.56 voltage when the car is off a low reading? Do I simply need a new battery?
  14. NoSpeedLimit
    NoSpeedLimit Karting
    Sep 6, 2013
    185
    My two cents: At the first glance 12.56V is ok. However, the battery should be testet under load. To charge a battery the voltage should be a little higher than 13.8V. For me that voltage eems to be a little on the low side.
    A battery that is not completely charged contains leadsulfate. First there are only small cristals which will dissolve when the battery is charged completely. However, over time the small cristals will grow. Larger cristals will not dissolve if you charge the battery. I bought a Ctec charger and charge my batteries every one ore two months. Even if I have driven my cars for some hours at higher speed the Ctec needs some hours to completely charge the batteries.
  15. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
    I plug mine into tender everytime I park it. I think a well kept battery is better on an alternator. My 2 cents.
  16. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    i would suggest taking the battery out charging it, then load test it. Most auto parts stores will do this for free, or you can buy a load tester. They aren't very expensive. All they do is simulate a heavy load (like starting) for a period of time. Batteries can read good voltage and fail a load test.
    To test parasitic drain. Charge battery. Turn everything off. Remove the negative battery terminal and place a test light light between the negative cable and the negative battery post. If it lights bright, then current is flowing and something is drawing. Using a voltmeter is of course better and more accurate. Cars should draw some depending on the type of electronics. If you do have draw with everything off, then you can start checking circuits by pulling the fuses until you see a change in the voltmeter.
    In my experience, if you have run the battery dead, its days are numbered. Car batteries don't deep cycle well. HTH
  17. ready321now
    Jan 5, 2013
    484
    New Jersey
    Good info....much thanks. Im thinking my battery got chewed on by my blown alternator x2. Might just try a new battery after I load test the old one.
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,816
    Richmond
    Pete
    Mine makes it 2-3 weeks before it needs a charge.
  19. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    The alternator charges around 14 volts.
    If you were driving the car for 30 minutes or more and shut it off
    the voltage should be about 12.75 volts across the battery terminals.
    As the car sits.....over days... the voltage will drop (due to the load from the ecu).
    Is your reading of 12.56 volts immediately after shutting the motor? If so then the
    battery is suspect. If its after several days then this is normal.
    I would never charge a dead battery by using the alternator....you can burn out the alternator by doing this.
    Buy a real heavy duty battery charger for recharging dead batteries and a ctek charger for maintaining good batteries.
