Daytona Dinoplex Swap for 6A MSD | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 365GTC, Mar 20, 2021.
  1. 365GTC
    365GTC Rookie
    Dec 29, 2003
    30
    Lexington, Virginia
    Have a ‘72 coupe and a 72 246 GTS, with Dinoplex ignition. Has anyone successfully swapped the MSD internals for the Dinoplex electronics to retain the stock appearance? How to achieve the best results?
    Thank you, Chuck
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  3. TTR
    TTR F1 Veteran
    5,137
    Riverside, CA
    Timo
    I’ve seen and helped finalize Pertronix conversations to Daytonas by bypassing 103 Dinoplexes and wiring everything to OEM appearance.
    Currently in the middle of a job removing an older MSD system and converting/returning the ignition back to OEM points system. Did a similar (reverse conversion ?) job last year by deleting/removing an older (failing) PermaTune system in favor of OEM points setup.
  4. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
    Did you have any joy swapping the MSD into your dinoplex? If it's any help to you or anyone else in the future, these Dinoplex boxes come with modern internals as well. https://www.exoticautospares.com/inventory/ferrari-246-daytona-dinoplex-ignition-module/
    Sent from my SM-G935F using FerrariChat.com mobile app
