Daytona/400 Engine? | FerrariChat
Daytona/400 Engine?
Discussion in '365 GT4 2+2/400/412' started by Kalidengas, May 28, 2007.
  1. Kalidengas
    Kalidengas Formula Junior
    Dec 29, 2003
    599
    Lisbon, Portugal
    J.Santiago
    The Ferrari Daytona and the Ferrari 400 engine have some conection?
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Similar
  3. Kalidengas
    Dec 29, 2003
    599
    Lisbon, Portugal
    J.Santiago
    Can whe say that is the same engine?
  4. ed_and_tonny
    ed_and_tonny Karting
    Aug 4, 2006
    94
    Pawleys Island, SC
    Ed Quillian
    No, I beleive they share the same block but the heads on the Daytona are different. I beleive the piston crown is also different to accomodate the Daytona heads. I'm sure the experts will weigh in soon on this one.
  5. lazaruslong
    lazaruslong Karting
    Aug 9, 2006
    86
    I quote from the british magazine "Fast Lane" March 1988: "...since the similarities in the upper cylinder areas of the Testarossa and 412 extend even to identical piston, fitting TR heads to the V12 would make a very interesting car, with an extra 50 hp and 28 lb ft of torque."
  6. dstacy
    dstacy F1 World Champ
    11,995
    GMT -5 & GMT +1
    Dave
    Ok but the 412 pistons and heads are DIFFERENT from the 400.
  7. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Similar design, probably some interchangeability of parts but I wouldn't try to list which ones without comparing them.
    Colombo gets credit for most of Ferrari's engines but they aren't like "small-block" Chevys. The 250, 330, and 400 (just to pick a few) look similar but are in detail quite different. The Testarossa (flat 12) has a Colombo engine. It is not too similar to any of the others (except Boxer).
    Is this an academic question or do you have a purpose in mind?
  9. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,666
    Romulus, NY (Finger Lakes)
    Ken Battle
    Didn't the Daytona have central downdraft carbs and the 400's went to outboard side drafts for the purpose of lowering the hood profile. That is the description I read in one of the books of the "period Ferrari's". This would make the heads and cam carriers distinctly different.
    Ken
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #10 2NA, May 31, 2007
  11. Fritz Ficke
    Fritz Ficke Formula 3
    2,259
    Tucson, AZ.
    Fritz Ficke
    So, just the exhoust cam is chain driven on the Daytona and the intake cam is gear driven off of that, as opposed to the 400 which uses a chain to drive all four cams. That explains why the chain cam drive chains would fail sooner on the 400. Thanks for the pictures.
    The Daytona is also dry sump, so it can be lower in the car which gives the car a better C. G. and allows the use of a cross flow heads = more power.
    but obviously we can see that a 400 is a modified (detuned?) Daytona engine. Many parts are interchangable.
  12. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    This particular article is what gave me a case of the 'gots to have' with a 412...good pics, too :)
    One o' these days, gonna happen...
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Testarossa heads on a 412?
    Am I missing something?
    Different ports, chaindrive cams vs belts probably a lot of other differences. Anything is possible but there are probably easier ways to get horsepower.
  14. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    not the heads, the 412...
  15. sjvalin
    sjvalin Formula Junior
    Aug 31, 2004
    724
    Nevada County, CA
    Steve Valin
    Actually, the timing chain on the Daytona goes around an idler sprocket located in between and below the intake and exhaust cams. This idler sprocket than directly drives the cams via gears. It looks like it was an expedient way to convert the SOHC Colombo engine into a DOHC engine. The timing chain arrangement then is practically the same between SOHC and DOHC engines. The 365GTC/4 and related engines has the chain around both cams, which makes it a lot longer.
    I know the Daytona and 365BB/4 shared pistons, valves, cams, etc. I wouldnt' be surprised if some of these parts were common to the 365GTC/4 and 365GT/4 2+2.
    -steve
  16. Fritz Ficke
    2,259
    Tucson, AZ.
    Fritz Ficke
    Steve,
    I see it now, Thanks.
    I have been wanting to know the diffrence for some time now, you really helped.
    Great forum,
    Fritz
