Dashboard top | FerrariChat
Dashboard top
Discussion in '360/430' started by 993man, Oct 14, 2012.
  1. 993man
    993man Formula Junior
    877
    New Zealand
    Graham
    The leather has come loose in a couple of areas. Looks OK, but in some light it looks shocking.
    Short of pulling the dash has anyone found a way to repair this?
    I was thinking (bad, I know) that I could maybe get a needle/syringe, fill it up with glue and poke a few little holes and see what happens. It sounds rough, but it could work!................in theory. The holes would be really small.
    I did search and found some threads on taking the dash top off, but would rather not.
    In fact, I would rather have a root canal with no anesthetic than pull the dash top!
    If it's the only way then I guess I have no choice.
    Cheers
  2. HighandDry
    HighandDry Formula Junior
    Jul 24, 2012
    447
    Seattle
    Steve
    I had that happen on one of my Porsches. Took it to an car interior shop and they repaired it. Looked good, but they did have to remove the dash.
    Also happened on my Aston under warranty, but they just re-glued and pulled it tight (not sure how).
    Before you start injecting, take it to a professional and see what they say ;)
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,437
    Charleston, SC
    Curt
    In my 99, the dash has shrunk pulling it out of the front depression and making it tight and smooth on the top. In other words, there should be a depression at the front of the dash below the window. On mine the leather is so shrunken, no amount of glue can stretch it back and stick it into place.. the dash needs to come out to get new leather fit to the dash.
    If you just have loose leather (bubbles, lifting areas, etc.) I might use the syringe trick.. but if it's shrunken in size so the leather can be made to fit, then you just have to bite the bullet. If they remove my dash.. the time and effort involved means that if this is done I'm just going to get it recovered in leather or buy a replacement refurb.
  4. rob4092xx
    rob4092xx Formula Junior
    Mar 8, 2010
    570
    Phoenix, AZ
    Surgeon and 993:
    I am real concerne about my dash eventually shrinking as I live in Phoenix.
    My front windshield is clear tinted so this should keep some of the UV rays off.
    Can you please share with me how you cared for your dash? Did you apply leather conditioner and if so, how often?
    Did your car sit in the sun much?
    Any other info you can provide would be greatly appreciated!
  5. 993man
    877
    New Zealand
    Graham
    I just gave mine a treatment of Leatherique to keep it soft.
    However, from what I've read here that's not the issue. I think the glue they used at the factory was rubbish and just doesn't hold up well.
    Much like the sticky buttons.
    I think I will take off the dash, but only when it looks really bad.
  6. 993man
    877
    New Zealand
    Graham
    I do just have bubbles actually. Give it time and no doubt it will shrink.
    In the post I read the dash comes out quite easily. One day I will find out!
  7. rob4092xx
    Mar 8, 2010
    570
    Phoenix, AZ
    993:
    How often did you apply Leatherique?
    Did you notice if the stretching got worse after applying the Leatherique? I ask since I wonder if the Leatherique breaks down or affects the glue.
  8. Spider360Matt
    Spider360Matt Formula Junior
    Mar 14, 2012
    595
    California
    mine has come loose at the front vents. The dash hasnt shrunk at all, but of course this is causing some lift. Are these vents simply glued down too, or are the clipped in?
  9. 993man
    877
    New Zealand
    Graham
    Theres a full write up somewhere that explains all this. I read it before. Search it.
    By the sounds of things it's not as bad as what we think it might be to pull the top off.
    I'm still kind of liking the idea of a syringe filled with glue personally.
    Rob
    Leatherique can only be a good thing. It softens the leather and from all the reading it wont harm anything. It takes a long time to soak in though.
  10. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    If it hasn't started shrinking yet, I've heard that using a sunshade is a good preventative step.
  11. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    perhaps....
    lightly soaked sponge (leatherique) placed on the leather with a plastic wrap on the top to prevent evaporation....
    then place a sandbag on the sponge/ plastic wrap.....
    then put it out in the sun to bake for a few hrs...
    leave the weight over an extended time period to slowly stretch the leather back down.
    might be worth a try.
    Rgds,
    Vincenzo
  12. Fearless Shifter
    Mar 1, 2009
    98
    Laurens, S.C.
    "Brother" McDaniel
    I have a small bubble on my air bag plate/front cover. Would the needle and glue work there or can I remove the cover and have it redone ?? Any ideas ? Thanks
  13. 993man
    877
    New Zealand
    Graham
    Hahaha, my needle and glue idea might be a disaster, so let me be the first to try.
    Last night I had a good look and I do think it can work. As long as enough glue gets under the leather. I will try and buy a needle today but that's not as easy as you think it might be.
    Might have to ask my friendly vet. I'm thinking a needle they might use on a horse.
  14. vrsurgeon
    16,437
    Charleston, SC
    Curt
    Some tidbits from my experience...
    - Try to put the needle through a stitching area to hide the hole.
    - the smaller/finer the needle the harder it is to push the glue through it
    - draw it up without the needle on it then put it on once drawn.
    - alternatively, remove the plunger, pour it in the top, put the plunger in the top then flip it 180 degrees to get the remaining air out.
  15. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Also,
    avoid sticking yourself with the damn needle!!! :)
  16. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    How did the needle glue injection work out? Any issues?
    My 993 with a custom leather cover has detached it's self in the depressed area.
    The glue injection was my thought too. The seam stitching is far from the bad area.
    I will search rennlist site on dash removal next.
  17. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    I like the idea about trying to stick the needle through the stitching holes, that should be completely invisible. If you have to shoot it through the flat part of the leather, maybe a needle that the dentist uses for novacaine would be the thinnest available?
  18. Alxlee
    Alxlee F1 Rookie
    Apr 8, 2002
    3,697
    Wilmington, DE
    Alex Lee
    #18 Alxlee, Oct 15, 2012
    Visual aides...
  19. Fearless Shifter
    Mar 1, 2009
    98
    Laurens, S.C.
    "Brother" McDaniel
    Ijust had my bubble fixed by professional interior restoration man. It took about an hour to do. He took a leather hot iron, heated the area, shrunk the bubble, and it reheated the old glue Behind the leather, and it is back in place like new and perfect. His name is Jerry Noone, Noone Fine auto Restorations, Piedmont, S.C. 864-991-8168. In his shop he was doing restorations on a Ferrari, Rolls Royce, Austin Healy, and a couple of Mustangs.
  20. rob4092xx
    Mar 8, 2010
    570
    Phoenix, AZ
    Outstanding! Photos please?
  21. 993man
    877
    New Zealand
    Graham
    Now there's a thought. I just managed to get a nice long needle from our vet to try the prick it through the leather trick and inject some glue.
    But now I am thinking I might get our iron and use a wet towel. That would work I reckon.
    Or should I say, could.
    Makes sense to reheat the glue.
  22. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yes. Also makes sense to go see an upholstery specialist. I can't imagine that a heating repair would be much money and experimenting with an expensive car isn't my idea of a good risk/reward balance on something that could look worse for your efforts if not done right. Of course if the nearest is hundreds of miles away, I would feel differently.
  23. 993man
    877
    New Zealand
    Graham
    I hear you.
    One of my customers left a pot plant on top of a speaker and the laminate lifted a bit. I called the guy that made the speakers and he said to get a wet towel (must be wet) and pinch the wifes iron and just sit it on the towel over the top of the lifted laminated wood.
    He told me this would reheat the glue without any damage. So I did as he said and it worked well.
    I know this is leather, but I really cant see the harm in trying. But I will talk to an upholsterer tomorrow and see what he says.
    The problem with NZ is that all the good guys are hundreds of k's away, so that's why I have the, 'I'll give it a go" attitude.
    It's a Kiwi thing :)
  24. Spider360Matt
    Mar 14, 2012
    595
    California
    My dash cover has shrunk as well. Thankfully there are no signs at all around any of the forward facing vents and overall the leather still looks and feels new. It did all of its pulling away at the forward defrost vents and actually broke the vent cover tabs in the process (rather than tearing the leather).
    The front windshield is getting removed today. The repair will involve a glue, some heat, and new vents (sourced from back east). Disaster averted...hopefully! Thanks to Rob Roselli over in San Jose CA!
  25. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    Interested to hear how this turns out! Fill us in when complete
