dashboard removal | FerrariChat
dashboard removal
Discussion in '612/599' started by Melox2, Jun 1, 2020.
  1. Melox2
    Melox2 Rookie
    Apr 4, 2015
    34
    United Kingdom
    Mark warden
    Hi , As anyone got any Knowledge or instructions of how to remove the dashboard on a 612 , and how difficult it is ? got a bit of leather shrinkage just creeping up from the vents but i think the vents are screwed from underneath .
  2. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
  3. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    It takes a lot of time and attention. No specific advice for you because this work was done by a friend who has since retired.
  4. Melox2
    Melox2 Rookie
    Apr 4, 2015
    34
    United Kingdom
    Mark warden
    wow so many parts to it although you removed the complete interior ,looks daunting but the pictures help to see how parts look separated
    thank you
    m5shiv likes this.
  5. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    You have to pick your battles on what you are going to do yourself or have a professional do it. This is one of those ones where I would leave it to a professional. I had mine replaced a few years ago and I think the cost was around $5K.
  6. Jonny English
    Jonny English Formula Junior
    Jun 14, 2017
    416
    Poole, Dorset
    Jon
    all that just to retrim a dashboard! surely there is a shortcut method
  7. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    #7 m5shiv, Jun 4, 2020
    In this case, the rear seats and the roof trim was removed to fix the sagging quilted leather headliner, so it looks way more intense than just the dash. However, I am not aware of any shortcuts to remove the dash entirely. We also removed the driver's door panel to fix a persistent rattle. The reassembly was also quite tricky because there are compression marks on the pieces based on their factory alignment and the newer leather on the dash was a little thicker and the exact headliner alignment was also very tricky. Will have to do the dash on the 550 next.
  8. Melox2
    Melox2 Rookie
    Apr 4, 2015
    34
    United Kingdom
    Mark warden
    mines only just started to creep out about 5mm from the vent and only a 25mm section at the moment and its just half covered the light sensor so its not that bad , if the the vents were just clipped in i think it could be possible to get it back but i think there screwed from the underneath ,
  9. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    They are screwed in from the underneath
