Cylinder head and exhaust flow | FerrariChat
Discussion in 'Technical Q&A' started by Artvonne, Jan 16, 2007.
  1. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I thought maybe we could start a new thread about this subject that was not model or head type specific. We presently have Mark getting his QV heads ported, and Russ is trying to build a better exhaust system for a Mondial and he even has a thread over in the V-12 area on the same discussion.
    I am presently working to create and build an air flow bench so I can watch and understand the airflow rates of a 2V 308. But the amount of material to read and understand can become quite absorbing. The more you read and learn, the more your eyes become glassed over. I didnt intend to make it any more complicated than I thought I needed, but once I started reading I found that to do it correctly you really need to know what your supposed to be watching. Air is wierd stuff.
    For example, lets discuss exhaust flow and how it pertains to engine performance. When you begin, you assume its like flowing air, that just like the intake you need things smooth and well shaped. But start reading and you soon realise there are many other factors.
    I have read some articles claiming that as the exhaust is leaving the chamber, a shock wave, approching, or possibly exceeding the speed of sound (1100 feet per second) precedes the main flow charge as it travels down the primary tube. This rapidly exiting shock wave "pulls" a vacuum that helps to draw the main gas flow from the chamber. There is a point during the overlap phase where pressure differentials between the exhaust port and intake port can exceed 6 psi. I dont know what that equates to in W.C. yet, but some articles I have read are eluding to the idea that the exhaust flow creates enough vacuum draw through the intake, that the downward speed of the piston is negligable to filling the cylinder. That the pressure differential created by the exhaust flow is what allows the cylinder to fill to a volume exceeding it capacity, actually "boosting" the engine.
    Additionally, I have been reading that to find proper air flow, and to observe combustion chamber turbulence, some are flowing cylinder heads with pressure differentials exceeding 50 inches W.C.. That in some case its been seen that real life airspeeds in the intake port can cause seperation of the air flow and cause it to stall. There is discussion that fuel added to the airflow does not behave the same way as dry air, and that in some cases porting can cause a dramatic drop in flow once the heads are on the car, because the fuel in the air totally destroys the flow and causes the flow to stall.
    For these reasons, I am questioning if cylinder head flow shouldnt be tested at super high flow rates, something more approaching real life WOT at full RPM, and if the flow shouldnt be tested at the exhaust port with a piston at the correct height of overlap in the cylinder and with the air entering the intake, carb and all, to mimic the true valve overlap phase. Secondly, I am trying to find a way to introduce a non flamable fluid mixture that would mimic fuel density and behavior as well as a vacuum source that wont be destroyed by it. I guess what I am questioning is if its possible to create enough flow at the exhaust port to reach realistic engine speeds.
  2. DGS
    DGS Six Time F1 World Champ
    69,668
    MidTN
    DGS
    Fluid dynamics. Triple integrals. That brings back memories.
    Painful ones. ;)
    (Turbojet exhaust nozzles: choked, unchoked and boundary. Arrgh.)
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    Now you understand…..
    There are a lot of theories about a lot of things. The conservation of energy is no doubt what allows a cylinder to be filled to about 140% of it’s capacity. The exhaust flow starts the intake charge moving while the piston is still going up, then the energy in the intake steam keeps air flowing into the cylinder after the piston starts going back up.
    The velocity of the steams are critical to making all this work. Also, the length of the runners/tubes and volume of the plenum/collector will tune the rpm where it all works best.
    Back to the heads. There are quite a few ideas about what vacuum to flow at and why. The fact is though that I have seen success in equal proportions from all of them. That makes me think the true variable is the talent of the person shaping the port and is why I am not doing my heads personally. I have had some pretty good results over the years, but my buddy Vic’s have always been just a bit better, as much as I hate to admit it. I like 10” H2O because it represents the vacuum that has been measured on race type engines, but I think you will be fine with any number you settle on. As a reference, a big V8 running a 2 barrel carb runs about 28” H2O, I don’t know what would run at 50” and 6 psi is something like 162”-168” H2O off the top of my head.
  4. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    There are more than a few books on the theory of ports and their flow characteristics. Smith's book (don't recall the name, but I'll see if I can find the actual book, which I've got somewhere around the house) talks about flow. I've seen the Ferrari 2 valve heads, and belive that in order to make a head flow properly, you've got to d shape the ports. The distance between the valve seat and the bottom of the port is too small, making the intake, and to some degree the exhaust, make too tight a turn. By welding up the bottom of the port, and then expanding the sides, you keep the area the same, but increase that distance, thus making the turn more gradual. The net effect is that you use more of the valve diameter. We had those same problems with the Ducatis I used to race, and the difference was substantial.
    There are manufacturers of port flow measuring devices, but I think most of them are for bikes, I haven't seen one designed to work on a car's cylinder head, but I'm sure that they are around.
    Hope this helps. If you need more detailed info, I can point you towards some of the people that I know that make a living porting heading, and although they're a bit strange, they do have some talent.
    Art
  5. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I was once told by a world-class porting specialist....
    "You can sum porting up with one sentence:
    Air can go fast, or air can turn, but it can't do both."
    All I can tell you is that even if you are sitting there, at a working flow bench, at 11:00 at night, not drinking a beer for the 5th night in a row because you need a clear head.....then you are just getting started.
    Its a LOT of work. Good luck, and drink beer now because you can't later!
    JM
    (world-class as in world champion team "consultant")
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    So what your really telling me is that I should direct my energies into beer making? Oh wait. Probably cant make good beer if your drinking it a lot I suppose, eh?
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    One thing I always heard on exhaust valve sizing was that there was an ideal ratio range with the intake for optimum performance. I forget the number right now, but the intake was proportionally larger to generate the velocity and pressure wave dynamics to allow good cylinder filling.
    Everything's connected.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    about 80% will do just fine
  9. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I wanted to discuss Ferrari's 308 headers. Presently I am blessed with both a stock US set, as well as a euro set. The euro set being far better condition have taken to residence in the driver, and the crummy holy US set are resting up in the garage attic waiting for me to figure out what to do with them.
    Both sets have what to me appear to be a problem, although the present phrase probably applies : that everything a reasonably intelligent person should intuitively believe to be right, will probably be totally wrong.
    Each header, all four of them, have the prescribed 4 into 2 into 1 setup. What bothers me is that at the outlet of all these headers, the outlet is a straight section of pipe that extends several inches into the cone of the collector. So in my mind I am picturing this nice well behaved exhaust flowing out into the collector, and it being gently ramped down by the cone, but here is this stove pipe sticking into the cone screwing up that nice gentle flow.
    And I cant tell you guys how many times I started to pick up tools to go after them to cut that pipe out and smooth it out inside. I havnt simply because I told myself I dont yet know why Ferrari did it that way. Was it done because the company making them was cheap and didnt care, or was there a philosphy behind it that we dont yet understand?
    When I get to a point where I can start blowing some air, I want to first, simpy see what realigning the manifolds will do to the airflow. But when it comes to the header, I really dont yet know what to do. I could use the US pair and cut the inner pipe out after flowing it and see what it does, but it seems right now that I dont know what that would tell me.
    Does anyone know what Ferrari did with other models of thier cars headers?
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    The best I can tell, as they learned more, ferrari realized that the exhaust port was too big. The race cars used the 208 heads for that reason when they came out. On the street car, they misaligned the header to effectively reduce the flow cross-sectional area. Aligning the port will probably make more flow, but less hp.
  11. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    I did some reading on ram tuning some years ago. From what I understand, once the primary joins with another pipe the ram effect ends. The rest is just about eliminating resistance to bulk flow. If you look at the 1958 Chrysler 300D longram intake compared to the later 300 shortram intake, the only difference is the length of the divider wall between a joined pair of runners. It was just the length of the divider that was used to tune the peak torque value. It is also a practice to use different length runners on different cylinders to give a varity of peak torque values. This flattens the torque curve (ie equal vs. unequal length runners).
    I hope this helps some.
  12. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    But regarding the headers themselves, are any other models stovepiped like these 308's ?
    My thinking has me strongly questioning why Ferrari did any of these things. They didnt build some of the greatest racing engines by not having a clue how to build a performance engine. If anyone back in the early 1970's would have known how to make a cylinder head, one couldnt imagine Ferrari not being at least close to the top.
    I understand what your saying about the port size, but why then didnt they correct it? Why didnt they just use the 208 heads, or whatever. I look through the parts from the Ferrari website and there are miriad part numbers and cam part numbers, so they obviously made many different castings. The Michelotto cars were in the 77 and up range, yet Ferrari kept putting the large port 2V heads on the 308 until the QV.
    Is it more possible they wanted the cars detuned for some reason? Could they have upstaged the bigger cars from Ferrari had they been massaged better? Was it simply to pass emissions? Who knows. I just cant imagine these stovepiped header collectors are doing anything but robbing power. But I dont know enough yet.
  13. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Do you have a photo of the pipe in the collector? It would also be interesting to see the pipe diameters, both primary, secondary and collector pipes. That should give us some idea of the hp they were looking for. Any other comment of differences between Euro and Ameican header characteristics?
    I've a set of tubi headers on order to arrive in Feb at Carobu, and will be interesting to compare collectors, tubing sizes and ports. Tubi is supposedly Ferrari's oem for racing headers and has access to factory engineering data, so will be interesting to compare measurements.
    Great thread, thanks.
    Russ
  14. Bob Downing
    Bob Downing Karting
    Nov 7, 2003
    62
    BobD
    Your first choice for building a flowbench should be with Audietech.com
    Secondly, A wet flow bench has been developed by Joe Mondello and fine tuned by Joe & Reher & Morrison. It basically introduces a fluorescent liquid into the port which causess the liquid to be visible to the naked eye. The wetbench has changed some perception about airflow, fuel wetting, etc.
    Ferrari, McLaren don't mess around with eyeball flowbenches as they use computational flow dynamic software to design their cylinder heads.
    If you are really into it, Joe offers a week long Head Porting class which teaches the basics of head porting. Mondello.com
    At one time Joe had 19 head porters working for him and he figures he has personally finished 275,000 combustion chambers. He can cut a straight line in metal with a grinder equal to any CNC program.
    Reher & Morrison has a yearly goal of gaining 10hp on their top fuel motors as they are always pushing the limits. Visit their website as there is alot of good info and Darryl will answer any email you write him. Remember one thing, bigger isn't better. Velocity, Velocity, Velocity.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    I'm willing to wager it was emisisons. If they messed with the head they would have to re-qualify the engine and it may not have passed.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    There are a couple basic engineering expressions, one is "FEA or CFD will make a good engineer fast and an average engineer dangerous". The output is completely dependant on the inputs, which are far from obvious most of the time. Also, the computer will only analyze the port design you give it…it can’t design anything. You can spend days optimizing the design, but if it was a poor design to begin with, it will still be poor once you have it perfected.
    There is just no substitute for talent. You'd be surprised I think how much hand work probably goes on.
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I was reading some literature regarding CNC machined ported heads. Something along the line of it first needing to be created from a hand created port. The CNC can make absolutely precision cuts and make every port in a particular head exactly the same time and time again, although some ports are actually impossible for a CNC machine to get into and machine all surfaces. But at any rate, if the port they build the program off of isnt a well flowing port, you will just have a head with a bunch of equally exact ports that dont flow very good.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,567
    The twilight zone
    The Butcher
    Exactly. Finish is also important and the CNCs have trouble with that around all the curves.
  19. whturner
    whturner Formula Junior
    Nov 25, 2003
    315
    Western Pennsylvania
    Warren Turner
    The books by Smith are:
    Scientific Design of Exhaust AND Intake Systems (ISBN: 9780837603094)
    Philip H. Smith
    The Design and Tuning of Competition Engines (Revised Fourth Edition)
    Philip H. Smith
    Scientific Design of Exhaust and Intake Systems (Engineering and Performance) (ISBN: 0837603099) Philip H. Smith, John C. Morrison
    They are good basic reads - even though out of date with respect to the cars. A good place to start for a non-specialist.
    Cheers
    Warren
  20. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I still havnt gone out and bought a decent camera, and its not worth using the one I have, so no pics. :)
    I finally crawled up in the garage and dug out the rear US header to look it over. I have to admit my ignorance as I never really looked it over very well before. But compared to the "euro" header that I have on the driver, its "appears" to be far better made. I had somewhere along the way taken comments people had made to concur the US header was crap and the euro header was superior. But I now believe the reverse to be true.
    While the euro header has wrinkles in all the bends, the US header appears to be mandrel bent, but without those tell tale reliefs you see in some pipes. More like it was hydraulically formed? Looking inside at the collector end, the pipes fit tightly to the walls, and the collector flanges are deformed around the primary tubes for a tight fit, the euro's are just a sheet metal can welded around a pipe. The exit pipe is short, and fit snug to the walls of the cone, not at all like I had seen on the euro header. Again, the collector cone is actually deformed to fit around the exit pipe. The euro header had the exit pipe extending several inches inside the cone, and it was nowhere near the walls of the cone. Think of a hose crammed into the neck of a funnel, and standing up an inch or two inside the funnel bowl. Wouldnt flow very well would it?
    On the rear header, from what I can measure, the primary tubes appear to be 34mm ID, the exit pipe is 46mm ID. Primaries vary in length from about 19 to 22 inches. I will have to remove the rear header off the car to get measurments from the euro header, but I would assume simular sizes. I havnt measured it yet, but I believe the front header uses the same 46 mm ID pipe for the two long secondaries. Guess I have to go up there and dig some more, lol.
  21. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    With further rummaging I retrieved the front US header. Same construction, except the secondaries have that tell tale rounding in the inside bend from a mandrel, but still no wrinkles anywhere. The secondaries are approximately 47mm OD, exit pipe equal size to rear header. Because all the pipe (the rear header has a broken primary that allows me to measure wall thickness there as well as each end) appears to be 2mm wall thickness, I would assume the ID of the secondaries to be about 43mm.
