CV axle rebuild anyone? | FerrariChat
Discussion in '348/355' started by Joshieburger, Dec 20, 2015.
  1. Joshieburger
    Joshieburger Karting
    Aug 21, 2015
    162
    Oahu, Hawaii
    Josh
    Has anyone rebuilt their axles? Replacing the rubber boots, and refurbishing the whole unit? If so does anyone have a quick reference link to a step by step? My boot is torn and im leaking grease down the shaft which is also getting onto the headers.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Remove axle from car.
    Remove snap ring from end of axle.
    Remove clamps and old boot.
    Remove axle shaft from CV joint.
    Clean up the mess.
    Fit new boot with additional grease.
    Reassemble.
    Drink beer.
  3. Joshieburger
    Aug 21, 2015
    162
    Oahu, Hawaii
    Josh
    #3 Joshieburger, Dec 20, 2015
    Its that easy??? Theres no internal parts that have to be replaced? Theres just a bunh of grease under the rubber boot and i just need a new boot and snap rings?
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,391
    San Carlos, CA
    Mitchell Le
    Tim means you clean up the balls and races, reassemble with new grease and boots.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's not really difficult but you'll want to wear rubber gloves.
    The hardest part is removing the snap ring.
  6. Colin Angell
    Colin Angell Karting
    Jun 17, 2004
    116
    #6 Colin Angell, Dec 21, 2015
    I found the best way to clean the joints is to take them off the shaft and drop them into a tub of regular heating oil, then wash with a stiff brush. Obviously you need to make sure that no road grit has got through the split in the rubber boot. If you want to you can take the joints apart and wash everything separately, but make sure you reassemble in the right order.
  7. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
  8. GTO Joe
    GTO Joe Formula Junior
    997
    Charlotte, NC
    Joseph Troutwine
    Great idea! I have to file that away in my "way back machine" (my brain). :)
  9. jssans
    jssans Formula Junior
    Jun 1, 2005
    839
    St. Louis
    Josh
    Do they make a silicone boot? Cause we all need them.
  10. yelcab
    Nov 29, 2001
    13,391
    San Carlos, CA
    Mitchell Le
    Is it not expensive enough for you?
  11. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Easy, but messy!!! It's the same as every other CV joint really.
  12. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,749
    Boston, MA
    John E. Kenney
    I had axle work done at the major. Not sure what all that entailed.
  13. jssans
    Jun 1, 2005
    839
    St. Louis
    Josh
    The heat man, the heat.
  14. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    I did this jobs few months ago. My boot had just torn so the grease inside was not gritty or contaminated.
    I still cleaned all the old grease out but did not disassemble the joint. Took a case of brake cleaner lol. Then packed with new grease and new boots. This was the trans side.
    The wheel side was intact so I just added more grease and new boot.
    Topped of with gothspeed cv boot shields.
    Not difficult but messy as hell.
    If you don't want to fiddle with the joint, you can r & r the shaft and have a shop do the refurb.
    Recommend AW Italian for the boot kit.
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    +1 on AW Italian very good company.
