CTEK Battery and adapter for 458 | FerrariChat
Discussion in '458 Italia/488/F8' started by Mfreak, Feb 8, 2022.
  1. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    932
    San Diego
    Rob Barry
    In five years with my 458, I would highly recommend:
    https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y/ref=sr_1_3_mod_primary_new?crid=2XKQ84A8LB17V&keywords=ctek+7002+battery+charger&qid=1644382054&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=ctek+7002%2Caps%2C160&sr=8-3
    https://www.cccharger.co.uk/product-page/ctek-ferrari-4-pin-charger-adapter-cable.
    I have several CTEK 7002s and use them on all my cars, with the various cables.. One of the great things with the CTEK is you can add 8' extension cables: https://www.amazon.com/CTEK-56-304-Comfort-Connect-Extension/dp/B00ADIHUVG/ref=pd_bxgy_img_1/135-0256143-7726263?pd_rd_w=Cx4oZ&pf_rd_p=6b3eefea-7b16-43e9-bc45-2e332cbf99da&pf_rd_r=Z8SKQ1NGS3M0NXQEQA2W&pd_rd_r=f6e532d2-2219-46c9-ae66-c1b1637e4d6f&pd_rd_wg=3xCou&pd_rd_i=B00ADIHUVG&psc=1.
    Need4Spd likes this.
  2. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    582
    SW Suburbs of Chicago, IL
    Lawrence P.
    I have been using a CTEK MUS 4.3 with the adaptor you listed on my 2015 458 Spider with excellent results. What I see as a difference to the 5.0 is an AGM indicator light. Mine does not have that light. But the 4.3 works on wet cell, Gel as well as AGM batteries. I do not see the MUS 4.3 listed on the CTEK website and suspect the 5.0 is an updated version.
  3. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    #5 up4speed, Feb 9, 2022
    I also like the 5.0 because it has an automatic winter setting. It senses the ambient temperature and automatically adjusts the setting, and amount of charge.
    Also, the AGM setting is not supposed to be used on ALL AGM's. I think it is really just a proper setting for those cylindrical style AGM's.
    I know it doesn't make sense, but out of memory, I think you have to look at the battery specs for the proper charge rate for the battery (printed on the battery, or web site specs) and look in the Ctek owner's manual to pick the correctly matched charging setting. I know that my car with the Interstate AGM battery required the standard charge setting, not the AGM.
    The standard lead acid wet batteries (and a lot of AGM's) call for a bulk charge (charging step4) of 14.4v. Certain AGM's (I believe Optima and Odyssey) require 14.7v
    Widebody_Don and bball16 like this.
  4. Mfreak
    Mfreak Rookie
    Apr 20, 2013
    40
    I have not bought the CTEK yet but looking at the picture of 5.0 model (4.3 amp) only setting that can change is the mode motorcycle, car, AGM.
    Speaking of AGM, Do I need battery maintainer to charge everyday if I replace with AGM battery?
    up4speed likes this.
  5. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    And I think that AGM setting is specifically for the Optima and Odyssey lines.
  6. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    The car mode is the correct setting for a regular battery, or many AGM batteries as well (not the optima or Odyssey, those need AGM setting).
    Yes, you still need a maintainer on the battery all the time with an AGM battery. You won't need a charger every day if you go with a lithium battery, but they are VERY expensive, and you will need to buy a charger designed for lithium batteries, if you leave it parked for long periods of time.
    bball16 likes this.
  7. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    Yes, that's pretty much what the Ctek's owner's manual states. But with other brand batteries, you would have to look at the specs (printed on the battery sticker), to see what the proper current for the charge is. In my case, I have the Interstate battery, and it specifies a 14.4v charge, which is the setting with the picture of the car (not the one that says AGM).
    I don't remember how I figured that out, but if I didn't, I would have improperly selected the AGM setting on the charger. I asked Ctek tech support how big of a problem the wrong setting would be, and they said that it wouldn't be too much of an issue, if I messed up, but it probably wouldn't charge the battery to full capacity and may decrease the battery life over time.
  8. Mfreak
    Mfreak Rookie
    Apr 20, 2013
    40
    Now, i have a stupid question as make me wonder the CTEK 4.3 AMP 5.0 is a battery charger and also a maintainer.... I am just wondering what it is actually doing when plug in to the propriety plug right under the passenger side compartment? Is it keeping the battery charge in full or maintain the battery not being drained by after leaving the car for long period of time?
  9. rob5819
    Dec 12, 2017
    932
    San Diego
    Rob Barry
    STEP 1 DESULPHATION
    Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START
    Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK
    Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION
    Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE
    Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND
    Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT
    Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE
    Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
    https://www.ctek.com/storage/28170E5A4DF8DDE255F2544A55F5C421179A3398C557729443D3E9C908F0382E/d4c71f1fcf354b37bdfb3841d00adafd/pdf/media/01d8e64db81c4259bda89213323dad93/MXS_5.0-manual-low-UK-EN.pdf
    Mfreak likes this.
  10. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    Yes, it essentially charges, then maintains the battery (it is a very slow charger). Plugging in to the dashboard with the proprietary connector is the same as just using the clips, or pig tail directly onto the battery. The difference is that using the cars connector makes it clean and convenient, and when it's plugged in, it will prevent the car from starting, so you can't mess up and try to drive away with the battery tender still connected to the battery.
    The Ctek units are considered a "battery tender", they keep the charging voltage/amps low, and will reduce the power as the battery fully charges (as Rob5819 explained in detail). Then it will cycle as needed. In other words, it is safe to leave it hooked up indefinitely. If you leave a standard "battery charger", or even a cheap "maintainer" (the ones that continue to charge at a very low rate without properly sensing the battery and adjust) on for long periods of time, you WILL ruin the battery.
    turbokraft, bball16 and Mfreak like this.
  11. 56 Spider
    56 Spider Rookie
    Jul 25, 2010
    30
    My 488 that I just got came with this Ferrari branded one. The manufacturer's markings on it say TEK Automotive from Italy, and FixAndGo.com.
    I have used the CTEK on my California T and liked having the sequence of lights as it goes through its checks, but this one has just a single green light. The Ferrari dealer tells me this is the preferred one for the 488.
    Any thoughts on this unit versus the CTEK one?
    56 Spider
  12. BigJay2050
    7,191
    My 488 came with the Ferrari Branded CTEK, which I think is a 7002.
  13. 56 Spider
    56 Spider Rookie
    Jul 25, 2010
    30
    So I was at the dealer today and noticed that the Roma in the showroom had the same large black Ferrari charger that my 488 has. I am told that this is the new model that Ferrari uses.
