So I have the CTECK charger and want to install the dongle direct on the battery to be able to condition it ... Now the negative terminal is easy. Just hook the black lead to it. For the red lead, how the hell do you connect it when the positive terminal looks like this? Image Unavailable, Please Login Sent from my iPad using Tapatalk
When I say dongle, I mean the connector. Like this one.... Image Unavailable, Please Login Sent from my iPad using Tapatalk
You see a minimum of 10 possibilities to put it on Just choose the one with the easiest acces. Verstuurd vanaf mijn G3121 met Tapatalk
And those colorful fuses will not affect the charge or get affected by it? Sent from my iPad using Tapatalk
It seems to be connected all with the same metal plate. So I don't think so. Verstuurd vanaf mijn G3121 met Tapatalk
Have not you the factory socket near the battery for this use? https://www.ebay.fr/itm/Ctek-Ferrari-Battery-Charger-Conditioner-Adapter-Cable-4-pin-Type-/182967556284
I didn’t know they do that !! Thank you but I already installed the connector that comes free with the charger. Works fine. Sent from my iPhone using Tapatalk
