crush washer size | FerrariChat
crush washer size
Discussion in 'Technical Q&A' started by stevepaa, Jan 8, 2024.
  1. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    762
    san jose, ca
    steve
    I have two bags labeled 10261560 one bag has M18x22x1.4 the other M18x24x1.4 which is correct and what is the other?
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    For what?
  3. Steve Magnusson
    26,507
    MCP has 10261560 as the 18x22x1.5:
    https://www.ferrariparts.co.uk/part/ferrari/10261560?id=28254
    18x24x1.5 is also a standard size (but don't know if it has an official F part number -- it can probably be used anywhere the 18x22x1.5 can be used so can see how a parts dept might label both as being 10261560).
  4. wmuno
    wmuno Formula Junior
    512
    Wilmette, Illinois
    Bill Muno
    If you are going to use this washer on a drain plug, the larger OD is preferred. 1.5 mm is a nominal thickness. That 0.1 mm difference in your measurement is not significant.
  5. Steve Magnusson
    26,507
    I'm going to disagree with this a little bit. Will probably almost always work OK, but (ideally) you want all of the copper washer to be compressed evenly -- i.e., having some of the copper washer extend out beyond the flats of the hex head of the drain plug (or beyond the raised circular area on the underside of the drain plug head) isn't the best. Also, squishing a larger area of copper reduces the clamping pressure for a given clamping load. JMO, but there's more than one way to skin a cat ;).
    wmuno likes this.
  6. wmuno
    512
    Wilmette, Illinois
    Bill Muno
    I agree that it's best to have the washer not extend beyond the diameter of the drain plug. Since the OP didn't specify where the washer is being used, I felt that the OP should use the largest washer that is still within the diameter of the drain plug. The same is true if the washer is being used for a banjo fitting.
  7. Rifledriver
    36,750
    The standar
    The standard Ferrari oil drain plug seal for many years was 10261860 and was 22 x 1.4 x 27. Ferrari changed the design on the 348 using a helicoil as standard and the opening had a slight counterbore to it. The 27 OD washer would squish down into the counterbore causing a leak. Everyone switched to a 22 x 1.4 x 29 to prevent that. 29 was slightly larger than the plug head. 10257060 is both a block drain and an oil drain on many models and the OD is larger that the bearing surface of the plug. So is 10280060, another block drain. All perform flawlessly. While in theory you are correct, the very narrow surface area of many of the plugs combined with the shape of the threaded hole dictate we use a seal with a larger OD.
    Supernaut likes this.
  8. Steve Magnusson
    26,507
    #8 Steve Magnusson, Jan 9, 2024
    That I can more agree with ;). That 18x22 size has very unusual proportions IMO -- almost more like a copper o-ring than a washer. The banjo bolt that it uses has a smallish 22mm hex head (for a 18mm thread size):
    https://www.ferrariparts.co.uk/part/ferrari/155448
    so that 18x24 substitute would hang out some (but probably still work OKish).
  9. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
    thanks What is MCP?
  10. Steve Magnusson
    26,507
    Maranello Classic Parts:
    They are the official F part supplier for the older F models.
  11. Rifledriver
    36,750
    Maranello Classic Parts. Based in England it is owned by Roger Penske and is Ferraris official parts distributor for all parts but those for current or very recent models.
