Critical 355 F1 DIY Tools for Personal Garage
Discussion in 'Technical Q&A' started by Uberpower, Feb 26, 2024.
  1. Uberpower
    Uberpower Formula 3
    1,115
    I joined this site around 20 years ago as a young man without a Ferrari. I am now a middle aged man who has owned four (held on to one).
    Owning a Ferrari is everything I ever dreamt it would be, and I consider it an honor to be entrusted with a machine like this; however, I'm always just a little bit scared of it. Like it might immediately and without warning threaten to either bankrupt my family or just become some expensive garage art because it has some part that is either impossible to find, or incomprehensibly expensive to procure / install.
    Which leads me to think: "There isn't anything to be afraid of. I should just buy the proper tools and a lift and begin learning how to assemble and disassemble this car myself. It's not a spaceship. It's a 25 year old vintage Ferrari, and all of the components have been mapped, and there probably isn't anything on this car that hasn't been replaced by someone, somewhere in the last quarter century."
    So, instead of thinking of what NEXT Ferrari I can buy, or "upgrade" to... I feel like I really want to make THIS ONE special, and approach / drive it unafraid. (I have a few other vintage cars that I'd like to do this for also).
    I do have fairly large hands, and am a tall person... and this might be somewhat problematic... but so long as time and patience are in ample supply, I don't see why I couldn't learn this car just like any other "system" I have self-taught with help from others.
    Then I could be of help to others here on the forum as well.
    Now, I suspect I'll still need to get help for certain procedures that are complex- and will likely send it out for these types of repairs / service / mods, but over time my confidence will grow.
    So, the question is:
    If you had an ample size garage, where you could install a lift and have every or nearly every tool available to wrench on an F355 or 355 F1, what would those tools be? Obviously, I'd prefer to spend less money than more money- but lets say for the sake of argument that there is an adequate budget to outfit this garage.
    How would you build your own personal 355 home garage / repair / service bay?
    Thanks in advance for the time and expertise, as always.
  2. sfcarguy
    sfcarguy Formula Junior
    524
    Earth
    Service manuals and the all timing/locking tools for the major are the first to come to mind
    Diagnostic software would be helpful but every option is prohibitively expensive for a DIYer
    Uberpower likes this.
  3. Qavion
    Qavion F1 World Champ
    13,884
    Ian Riddell
    Then buy tools when you need them. There's no point buying, say, a slim 22mm spanner if your oil pressure sender never fails. You may need a couple of torque wrenches to cover often removed big things (wheel nuts) and little things (oil drain plugs). Perhaps an allen key set. I have engine side covers which have weird 3.5mm allen headed bolts. Your car may have regular phillips screws.
    There are aftermarket spark plug boot removal tools (which protect the rubber).
    Since a lot of problems are electrical, perhaps some wire cutters, wire strippers, contact crimping tools, multimeter, jumper wires, contact cleaner, etc. Perhaps a couple of rolls of Tesa tape as the black cloth tape loses it's stickiness and falls off the wiring harnesses. 3M adhesive remover spray is great for removing the old glue residue.
    One of the most useful tools can be a cigarette lighter voltmeter to see what your battery and alternator are doing.
    Maybe a smart phone boroscope kit and a magnet on a stick for when you lose things.
    Most of the computers can't be interrogated by standard OBD2 tools. As sfcarguy says, not everyone can afford a Ferrari SD1 tool or a Leonardo.
    Some 355s are too low to go on lifts. You may need some low ramps/speedhumps to get the car high enough.
  4. fatbillybob
    Aug 10, 2002
    28,609
    socal
    Dorm fridge loaded with beer or cokes
  5. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    346
    Navarre, Florida
    Nick P.
    The best tool I have even purchased and can 100% recommend is the Liftjack 7000TL. If you have a legitimate vehicle lift then disregard. If not, the Liftjack is a really useful tool for getting your car in the air so that working on and under it is easy. The liftjack 5000 is a little cheaper and would work well for your F355. Look for bundle deals at Costco.
  6. audi_328
    audi_328 F1 Rookie
    2,750
    NH
    Audi
    Do you mean Quickjack? Or is this something different?
    I have a Quickjack and until I get a proper lift, I'd agree it's money well spent. A little fiddly to arrange it properly to raise the car correctly, but it works great for a 355. Not trusting most lift devices, I still place a jack stand underneath each platform once it's up.
    Uberpower and Qavion like this.
  7. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,381
    Santa Clarita, CA
    As previously mentioned, buy the specialized tools when you need them. If I’m tinkering with my 430 and need something, I get on Amazon and order it. It’s delivered the next day.
  8. Chindit
    Oct 18, 2008
    346
    Navarre, Florida
    Nick P.
    Oh, sorry. Yes, I meant Quickjack. I went with the 7000TL version so that I could lift my F-150 without worry. I used additional safety jacks at first, but the Quickjack has proven to be extremely strong and stable, so I generally don't use additional safety equipment. Quickjack is extremely heavy (lift with your legs and not your back!) and awkward to position, but I have found a method that works for me and now I think it's pretty easy. A super useful tool purchase if you work on your own cars and don't have room for a proper lift.
  9. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,999
    PA
    Kevin
    * Hill Engineering oil filter socket
    * Hill Engineering wheel hangers (2)
    * Workshop manual
    * Motive Power Bleeder with Euro cap adapter
  10. Qavion
    13,884
    Ian Riddell
    Sticky R X also makes some high quality wheel hangers and spark plug removal tools. I hear Dave Lelonek is now developing polypropylene (?) spark plug removal tools which I imagine will be more gentle on the plug boots than a metal one.
  11. JoeCab
    JoeCab Formula Junior
    370
    Colorado
    Joe C
    I have all of those and a 4-post lift. I feel like I can do most maintenance short of an engine-out service pretty comfortably. Of course, with a pretty extensive collection of mechanics hand tools.
    So far I have done:
    Annual oil/filter changes
    Bi-annual changes of all other fluids
    Swapped wheels
    Replaced failed alarm siren
    Changed rear exhaust Tubi > Capristo
    Repaired or replaced slightly damaged underbody panels
    One tool I would add to the list is a high quality, adjustable heat gun. I used that for so many things. If you don't want to force and/or break things (especially plastic and rubber parts), heat them gently first.
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,399
    San Carlos, CA
    Mitchell Le
    Pin extraction tools for the connectors.
    36mm impact socket with a Milwaukee 1600 ft-lbs impact gun
    Timing belt tensioner rotation tool
    Cam pulley alignment pin extraction pliers
    Degree wheel
    22mm wrench and 17mm wrench bent at the right place and angle
    Throttle plates balancing vacuum gauges
    Very large adjustable wrench for oil line
    High quality allen sockets
    Special 10mm cylinder compression tester fitting from Snapon
    Coolant tank pressure tester along with cap fitting from Snapon
    Airlift
    Digital dial indicator and holding base. Various tips.
    5 lbs slide hammer
    MiG welder
    Fluke DVM
    Oscilloscope
    Compression tester
    Leak down tester
    Ring compressor
    Cylinder Liner extraction tool
    Head nut torque tool and adapter from Hill Engr.
    All 13mm wrenches in all configurations known to mankind
    Large 30mm, 32mm, 36mm wrenches
    A set of Ribe bits
    Timing drive sprocket nut removal tool (4 prong socket)
    CV boot clamps compression tool
    Thin wall 19mm socket
    There is a separate list if you plan on going inside the gearbox.
    Of course, you have to start out with a comprehensive garage full of quality hand tools before any of this.
  13. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,845
    The Cold North
    Tom
    Uberpower and Chindit like this.
  14. RedNeck
    RedNeck F1 World Champ
    12,001
    The CSA
    Me
    I absolutely love my Quickjacks, I bought 2 sets of them and use them often...although for a 355 that requires engine removal, I'm not sure they give enough clearance
    Chindit likes this.
  15. tbakowsky
    Sep 18, 2002
    19,845
    The Cold North
    Tom
    A 2 post is the only option for service work. They are not expensive, just be sure your floor has enough concrete min 6 inch depth reinforced with rebar.
  16. Uberpower
    Uberpower Formula 3
    1,115
    Which 2 post did you go with?
  17. tbakowsky
    Sep 18, 2002
    19,845
    The Cold North
    Tom
    Because of my ceiling hight which is 12ft, I went with an open top hoist from Tuxedo. It's not bad but definitely not the best. But for my space it works well.
