cranks but won't start | FerrariChat
Discussion in '348/355' started by berlinetta f355, Dec 19, 2020.
  1. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    I have a 1995 f355 Motronic 2.1 with one fuel pump. I don't know if this warrants a new thread as I recently posted a thread about changing the bearings on the cambelt drive pulley. Thanks for all your help. The engine is back in the car and it started up flawlessly. I never heard it so run so smoothly. I changed the entire cam drive system including the oil pump chain and tensioner system, all the cam seals and gaskets and had the injectors ultra sonically clean and flow balanced.
    I had finished replacing all the shields and decided to start it up again. It started to stumble and then stalled. The CEL for cylinders 5-8 came on. Now it cranks strongly but won't start. There is no spark, no power to the fuel pump and no pow.er to the crank rev counters. The fuses are all good but there is no power to the fuse for the fuel pump. There is power to the fuse for the ECU.
    The car has a Clifford XL4000 security system installed. I suspected it but everything seems fine from that perspective.
    I checked the voltage to the crank sensors and there is no power to either of them. The camshaft sensor is receiving 12 volts.
    Any ideas????
  2. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Are crank sensors supposed to have power on them?
    I would still check the left bank (bottom) crank sensor wiring. Can you do a wiring check between the ECU and the crank sensor? Pins 47 and 48.
    You may not be able to see the wiring colours, but you should be able to figure out which pin (socket?) on the sensor plug (car side) connects to what socket on the ECU connector.
    It's common for the plugs on the crank sensors to fall to pieces. The plug may be damaged internally. You may have hit the sensor plug or wiring as you were installing the shields.
  3. Qavion
    11,534
    Ian Riddell
    #3 Qavion, Dec 19, 2020
  4. Qavion
    11,534
    Ian Riddell
    When the ECU senses engine rotation during cranking, it activates the ECU relay ("O" or "L" depending on the bank) which provides power to things like the fuel pump relay coil (which in turn powers the fuel pump fuse) and provides (oddly) power back to itself so it can carry out more functions.
    Sorry if I'm teaching granny to suck eggs here :D
  5. Qavion
    11,534
    Ian Riddell
    When you say no power to crank the rev counters, do you mean you get no tacho indications? No (or erratic) tacho indication may be a sign that your left bank (5~8) crank sensor or wiring is inoperative.
    (EDIT: I can't remember if the starter motor cranks the engine fast enough to register on the tacho)
  6. m.stojanovic
    m.stojanovic F1 Rookie
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    I think that by "no power to the crank rev counters", berlinetta f355 means no power to the crank sensors. There is no incoming power to these sensors, they generate "power" (an AC voltage) and send it to the ECU-s.
  7. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    If I understand correctly, it is normal that there is no power to the crank position sensors when the engine is static?
    Qavion likes this.
  8. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    675
    Vermont
    john truskowski
    I'm not sure if you have access to a scan tool (SD1) to read RPM as the ecu reads it. When crank sensors fail, they usually send an erratic signal to the ecu which results in the loss of injector drive and spark. I think Ian has you headed in the right direction with the verification of crank and cam signal wiring (including ECM grounds). I would check ALL of the grounds, and power feed circuits too.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    The crank sensors are PASSIVE. They are not powered ever. They generate a voltage through magnetic induction which the ECU reads. The sensor has a magnet in it wrapped by a coil of wire. The magnetic field around the conductor changes due to the rotation of the toothed wheel on the engine, thus generating the voltage in the coil.
  10. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    For clarification, the WSM electrical diagram identifies 20011 as "sensor for engine revolutions - RH bank and 20005 as "sensor for RH cylinder bank revolutions". Which is for the camshaft and which for the crankshaft? BTW my engine is a 2.1 Motrontic but only has a sensor on the RH cylinder bank..
  11. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    I believe that you mean Motronic 2.7 (2.1 was not used in 355).
    I have a 348, Motronic 2.7, and I believe the sensors on the 355 are the same. There are two Crankshaft Position Sensors (2-pin connectors) next to each other, each related to one bank, under the engine at the connection between the engine and gearbox. No power is supplied to these sensors, they generate electrical signals which are sent to their respective ECU-s.
    There is only one Camshaft Position Sensor and it is mounted at the back of the RH head camshaft. This sensor has a 3-pin connector and it gets power supplied to one of its pins at ignition "on". The sensor caters for both banks, i.e. sends its signal to both ECU-s.
  12. johnk...
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    ??? Crank sensor on a 355 are located at the front of the engine, one to the side and one directly under. They are 3 pin connectors" Signal, Signal ground and shield ground.
  13. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    Thanks. Yes a typo Motronic 2.7. It is confusing because the WSM indicates a sensor on each cam bank. Are the crank sensors identified as items 20002 and 20007 on wiring diagram?
  14. johnk...
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    20002 and 20005 for cars with one cam sensor. I believe early 355s had 2 cam sensors and 2 crank sensors. Don't know the numbering for them.
  15. Qavion
    11,534
    Ian Riddell
    20007 is a thermocouple ECU.
    As JohnK says, 20002 and 20005 are, respectively, the left and right bank crank sensors on the lower front part of the engine. The cam sensors are on the rear upper part of the engine and are 20010 and 20011 (left and right respectively). On F355 2.7 cars, there are two of each. Miro (m.Stojanovic) may be thinking of the F348 2.7.
    JohnK's photo shows the location of the two crank sensors. As shown in my mini graphic in post #5, the crank sensor for the left bank is on the underside of the crank. It is NOT on the left hand side of the engine (as seen from the rear of the engine). Your left bank light is illuminated.
    If you do a resistance check on the left hand crank sensor wiring (with the crank sensor connected) by using pins 47 and 48 of the left hand ECU connector, it might tell you if the wiring and sensor are ok (see post #2). I just checked the resistance of a spare (new) crank sensor and it was around 900 ohms.
  16. Qavion
    11,534
    Ian Riddell
  17. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    Tks for the dgms they are much clearer than those in the wsm. I did check continuity between the crank sensors and pins 47 and 48. On the LH bank I had conitinuity with pin 47, none on pin 48 and on the RH side there was no continuity. I don't believe there are any connectors between the crank sensors and the ECU's. I will remove the engine cover tomorrow to see if there are any obvious problems with the wires s they run over the top of the engine between the banks.
    This is strange as the engine was running beautifully after the major service. The car hasn't even left the lift.
    Qavion likes this.
  18. johnk...
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    Only early 2.7 cars had 2 cam sensors. Later ones, like mine, had only one cam sensor mounted on the rear of the cam cover on the right side of the motor.
    Around 900 0hms is correct for the crank sensor.
    Qavion likes this.
  19. Qavion
    11,534
    Ian Riddell
    Strange. I can't imagine you have problems on both sensors. I wonder if there is an error in the original diagrams (on which my diagrams were based). I have found pin numbering errors in the engine diagrams on the 5.2, but that was a sequence of 70 pins shifted one pin to the left and was easy to identify. Oddly, the same mistake was made on the Ferrari 456M wiring diagrams. If you have time, perhaps you could check the pins adjacent to 47 and 48?
  20. Qavion
    11,534
    Ian Riddell
    #20 Qavion, Dec 21, 2020
    Thanks, John. When you said early cars (earlier), I thought you just meant the 2.7's. I didn't realise there were variations between 2.7's. I'll add a note to my diagrams relating to this.
    Your last photo has confused me even more. Were the crank sensors also moved on some cars or is the image reversed or is it a 348?
    Ferrari 348 engine out...
    https://www.ferrarichat.com/forum/posts/142755093/
  21. Qavion
    11,534
    Ian Riddell
    @berlinetta f355
    I don't know if you're aware, but on one of the diagrams in the WSM, the left and right bank crank sensors are mislabelled. i.e. on page "C9". Elsewhere, the labelling is correct.
  22. johnk...
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    The picture in post #18 is a 348 motor. Don't know what happened to the text that said that. Some times my laptop does strange things with text. I usually catch it but missed it this time, I guess. Sorry. It was supposed to say that 348s also had the crank sensors up front, but positioned differently than a 355.
    Qavion likes this.
  23. Qavion
    11,534
    Ian Riddell
    I sometimes have trouble with FChat depending on which computer device I use. Rob (the moderator) has just told me I "Report"-ed several innocent posts recently. I apologise to the posters (if they were notified). :oops:
  24. m.stojanovic
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    Yes, I screwed-up. Probably because I recently replaced the crank sensor on my Daimler Super V8 which sits at the bellhousing, 2-pin connector.
    The 355 2.7 had, in addition to the RH Cam Sensor ("Phase Sensor"), a similar Cam Sensor on the Left Head but up to Engine No. 38321.
  25. berlinetta f355
    Jan 11, 2015
    48
    Montreal
    Trevor Skutezky
    In the original test I did for continuity of the wire betwen the crank sensor that shoed no continuity was bogus due to a faulty test wire. Now I have continuity on both namks between the sensors and pins 47 and 48 of the ECU connector. I also checked the resistance between pins 47 and 48 and he resistance is about 800 ohms.
    The car cranks, but won't start. There now is a spark but the pump is not operating.
    Any thoughts??
