Cracked electrical connector rubber boots for 456 & 550
Discussion in '456/550/575' started by cwwhk, Dec 2, 2016.
  1. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #1 cwwhk, Dec 2, 2016
    All the Junior Power Timer connector rubber boots in my engine compartment are cracked. Where can I source some correct OEM protection boots with the bellows?
    I want to maintain the correct OEM look but so far can only find non-bellows boot as replacement parts.
    Thanks in advance for your help.
    Regards,
    Wayne
  2. tantumaude
    tantumaude Formula Junior
    972
    Burlington, Canada
    Mat
    Story of my life, I think mine are all in the early stages of cracking. I think the non-bellows parts have thicker walls and this are less prone to cracking anyways.
  3. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Can you give us a source for the non-bellow boots please.
  4. Cribbj
    Cribbj Formula 3
    Wayne, not to sidetrack your thread, but periodically I do Google searches for "silicone Bosch connector boots". Lately, some sources have been turning up in the far east, however after purchasing some samples, they look & feel like the same material as the OEM boots, so I don't believe they're silicone.
    I think the aftermarket is missing a great opportunity here, whether the boots are bellowed or non-bellowed, they should be fabricated in silicone, not the same old compound that the OEM boots were, which don't stand up to underhood temperatures for more than a few years.
    Dave, Eagle Day have a limited selection of the non-bellow boots here: AMP Connectors/Terminals, and Marc Swanson at EFI Express can usually come up with most any boot/pin/connector combinations I need.
  5. fatbillybob
    Aug 10, 2002
    28,625
    socal
    I actually like the non-bellows straight boot because they are stiffer (or at least the ones from SRI were). The rubber on the straight boot is thicker and should take more time to deteriorate. The bellows boot is super thin. The straight boot being stiffer and not so bendable moves some of the pressure off the pin to wire connection (the weakest point) and moves pressure away from the pin and down to the braided wire. There are reasons this can be an advantage. The only disadvantage is lack of OEM look.
  6. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #6 cwwhk, Dec 4, 2016
    John:
    Yes I also found some aftermarket bellows boots, but was hoping for some proper AMP or Bosch parts, but only found non-bellows boots from the usual electronic parts sources.
    In lieu of Bosch and AMP parts I think I'll order some aftermarket rubber boots and post up my result.
    Regards,
    Wayne
  7. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Carl:
    Agree non-bellows boots are probably better functionally, but the OCD part of me would like to keep the OEM look as much as possible.
    Regards,
    Wayne
  8. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Dave:
    Can't remember where I bought my non-bellows boots, but for sure from one of the usual electronic parts vendors such RS Components, Digikey, or Mouser. The same boots are used on Bosch Junior Power Timer or AMP Superseal connector series.
    These are also available from many EFI shops.
    Regards,
    Wayne
  9. fatbillybob
    Aug 10, 2002
    28,625
    socal
    Mine were from SRI. I think I have a couple extras around. Do you just need a few I will send them to you. They may only be 2 pin side. I have to got dig through a box.
  10. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    Last time I checked, Ferrari had the correct "bellow" boots but at about 4 times the price as the "non-bellow" boots. IIRC, the OEM boots have BMW molded on them but I have no reference as to what they fit.
  11. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
  12. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #13 cwwhk, Jan 9, 2017
    I managed to buy some bellows type boot for the MAF 4 conductor plug made by Tyco Electronics. Not exactly the same as OEM but close enough.
    Also bought the correct pin extraction tool from TE, which made the job super easy.
  13. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #14 cwwhk, Jan 9, 2017
  14. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #15 cwwhk, Jan 9, 2017
  15. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Extraction tool part number is 1-1579007-6
    Boots part number 493581-1
    You can buy them from Mouser or Digikey.
  16. Cribbj
    Cribbj Formula 3
    Well done Wayne!
  17. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Awesome!
  18. jagmanv12
    jagmanv12 Karting
    Aug 25, 2010
    236
    Surrey UK
    Mark
  19. Vereeken
    Vereeken Formula Junior
    May 16, 2014
    264
    Belgium
    Thanks. I needed that!
  20. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Thanks John! I'm occasionally useful. :D
  21. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Glad you found the info helpful.
  22. Vereeken
    May 16, 2014
    264
    Belgium
    Not only that. Turns out Mouser ships this stuff a stone trow away from my house.
    I never ever heard of them before!
    And I have to get that info from a guy in Hong Kong with not a single vowel in his name. ;o)
    Good god... the internet.
  23. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Errrhh there are two vowels in Wayne the last time I checked. :D
  24. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #25 cwwhk, Jan 18, 2017
    Received my aftermarket 2 and 3 pin silicon boots from a China vendor on Aliexpress. Installed the 3 pin boot on the throttle position sensor today. See photos. Not exactly same as OEM boot and had to cut off the end nib to fit over the wiring sleeve but close enough. Silicon boot has a shinier finish to the OEM or Tyco Electronic 4 pin boot I installed earlier for the MAF sensor, but silicon is heat resistant. I took a lighter to the silicon material to test and it withstood the flame fairly well. Far from perfect but much better aesthetically than before the repair.
