cracked AC control Knobs | FerrariChat
Discussion in '360/430' started by raywong, Apr 23, 2016.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    #1 raywong, Apr 23, 2016
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    We see broken HVAC dials often and I would be interested but only if as original.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    We are able to repair most cracked knobs we encounter. Just send me a message if you have any issues.
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #4 Dave rocks, Apr 23, 2016
    I've received a couple emails asking if we repair broken parts and the answer is yes, we repair broken part often but in some cases, the parts have missing pieces. See these HVAC dials. And, let's face it - a replaced part would be better than a repaired part if we can get a replacement which is why I am all for getting these if the OP has a source.
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,322
    Honolulu
    Kevin
    I like the look of those aluminum knobs. Are there any pictures of those installed in a 360?
    There are two sizes required for a 360 right?
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Kevin, yes, the center is larger than the ends. Also, the dial fits in a recess. I don't think the ones posted above would work. If we had enough folks interested in aluminum dials, we could design and build them in my shop :)
  7. raywong
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I think 430 knobs can be used on 360. aluminum knobs should look good too. The knobs in the photo above is aftermarket replacement for vw. I don't know the exact diameter.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Correct. The HVAC face plate is the same for both with just different markings / graphics.
  9. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    I have the cracked knob problem as of yesterday. I actually was thinking of replacing them with 430 knobs but can't source just the knobs.
    Does anyone know if the 430 climate control module is plug'n play on a 360?
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The 430 panel has different dials and different graphics form the 360 panel.
    Here is the 430 panel for reference:
  11. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    Thanks Dave - Yes that was acknowledged and known along with the knobs not being available sepertaely, but my question is: "Does anyone know if the 430 climate control module is plug'n play on a 360?" have you or anyone placed that pictured unit in a 360 and it worked without modification?
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Oh, sorry - I misunderstood. The body is the same and I also believe the connector is the same. Can I confirm it would be no problem? No. But, I really don't see why it would. I'm not sure I understand your goal but worst case you could remove the 360 electronics and swap them into the 430 panel.
  13. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    My goal is to replace my 360 knobs since one is broken with 430 knobs and if I can’t source 430 knobs I’ll just buy a 430 unit and swap it out if its compatible (the reason for my compatibility questions).
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The knobs, 360 or 430 are not sold separately.
  15. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Please return and let us know if the swap works. My knobs aren't the best either.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'll also add that the 430 dials are cast aluminum with plastic inserts on the back side.
  17. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    I have a 360 with the 430 A/C pnl installed.
    Its plug & play, no issues & looks great IMO.
    I also have the 430 air vents installed. Similar to the Enzo & CS vents, but have a sliver ring around the black frame.
  18. Sled Driver
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    MountuneMr375, Performify and hessank like this.
  19. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Thank you for your update on fit and function
    Wow SD, I see a glimpse of a yellow tack as well which makes your dash similar to mine.
    Those alum knobs will also go great with the alum knob on my 3 pedal
  20. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    Thanks for addressing the question - I was feeling confident it was compatible as most 360/430 parts are interchangeable. I also swapped my vents with the Enzo/CS vents (Looks much better than OE) since my vents were sticky.
  21. sherrillt
    sherrillt Formula 3
    1,106
    Northern Virginia
    Didn’t mean to hijack your thread - I would be interested in 430 style in a brushed aluminum or OE style.
    What price point are you thinking?
  22. Ali_500
    Ali_500 Rookie
    Nov 3, 2018
    8
    Hi all,
    I brought up this old thread because i'm looking for Ferrari 360 A/C knob.
    anyone knows where i can get it?
  23. kaj750
    kaj750 Formula Junior
    May 9, 2022
    258
    Fresno, CA
    Nobody?
    I see a few people have bumped this thread over time. I've also been trying to find climate control knobs for the 360 / 430/enzo. No luck. I prefer not to pay $900 for a complete used unit just to get one damned knob lol
    If no other options, I'll scan what I have and 3D print a new one, I suppose.
  24. 285ferrari
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    We have them in stock. Replacement knobs
  25. 285ferrari
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
