Coronavirus | Page 37 | FerrariChat
Coronavirus
Discussion in 'Australia' started by Ferraridoc, Mar 21, 2020.
  1. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    news.com.au said 1399 dead yesterday (fake news ?)
  2. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,217
    One of the nice things about that worldometer table, is that you can change the sorting by column. The scariest version is ordered by absolute deaths, which is why the media uses it, but if you sort by deaths per million population, the USA drops below Denmark. 44% of Covid cases are in New York state. Remove NY from the stats and USA drops between Cayman Islands and Iceland.
    Take out New Orleans and the US looks even better. Why the intensity in NY, LA and WA? Consider 20+ years of progressive politics.
    I have not been able to find a graphic of deaths by US City, only infections. Someone will eventually get around to this but I suspect for the moment that the progressive media and websites would rather not draw attention to the results of the most left-wing administrations in the country.
    Steve355F1 and Maranello550 like this.
  3. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,673
    Looking at that chart, the number of cases in Australia of CV 19 seems to have an inverse relationship to the supply of toilet paper. We don't need a vaccine, just more bog rolls.
    m5shiv, Steve355F1, greg246 and 2 others like this.
  4. moretti
    Nov 1, 2003
    59,757
    Australia
    You lost me after "Looking at the chart" :confused::confused::confused::confused::confused:
  5. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Fixed.
  6. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,207
    Gold Coast, Aust.
    Patrick
    OK, was busy last night, so didn't publish the daily update, so thanks Steve, for the morning figures. As at 5pm last night, we had 5552 total cases and 30 total deaths (0.54%). New cases yesterday: 190 - the 5th day in a row they have been less than the day before.
    Steve355F1 likes this.
  7. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    OMG
    Article: Is coronavirus a coverup of deadly 5G technology? | Euronews answers
    https://flip.it/.LNYCW
  8. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,783
    North Qld
    simon klein
    This means you'll have to Gerni the Bobcat again.
    Maranello550 likes this.
  9. AKA
    AKA F1 Rookie
    May 17, 2005
    2,937
    John McCabe
    As we all know, if the headline is a question the answer is "no".
  10. moretti
    Nov 1, 2003
    59,757
    Australia
    If Woody Harrelson says so then it must be true
  11. Ferraridoc
    Jun 20, 2012
    17,207
    Gold Coast, Aust.
    Patrick
    OK, let's do a primer on what all these numbers mean. I'll keep it simple for uneducated idiot trolls with "street smarts", "logic", and a huge chip on their shoulder because they don't have a degree.
    The figures (freely available) are expressed in certain ways that give uniformity across regions, and so can be compared easily. "Confirmed cases" means just that - cases that have been confirmed by testing. There are two main problems: there is a lag time of a few days for the test results to make this list, and there are a lot (at least double) of cases in the community that have not been confirmed. "Total deaths" means death from Coronavirus. Confounding variables are: some deaths may be missed (a very low probability in these times), and some deaths may be from other diseases (the term is "co-morbidities") in a COVID-19 positive patient. If you divide total deaths by confirmed cases, you get the Case Fatality Rate (CFR) - this is the commonest metric when used to express case numbers during the active phase of an epidemic. It's not perfect (as I have explained before), mainly because there is a lag between cases and deaths, but is very good at giving trends, which helps give feedback on whether any intervention is working. The actual CFR changes from day to day, and country to country, and cannot be calculated until the disease has run its course, and there are no more new cases reported, and no more new deaths reported. Even then it's still limited by the variables I mentioned above, and will always be higher than the actual numbers of deaths from the disease because not everyone with the disease will be counted as a confirmed case.
    A far better figure is the Infection Fatality Rate (IFR - which means Steve and Gary are rooted). This is the total deaths from the disease, divided by the actual number of cases with the disease. Again, due to lag, the figure won't be accurate until after the disease has run its course. And (here's the big one), we'll never know that number, unless there is 100% population testing, so it will always be theoretical.
    Another figure often quoted (which Ian alluded to) is the Crude Mortality rate. This is pretty easy - it's the number of deaths divided by the total population. It is also expressed as deaths per million of population.
    So long as you understand what these numbers mean, and their limitations, you can cut through the media hyperbole and monitor it yourself. I final word on what Peter is on about (not that anybody can ever figure out what he's on about). If you focus on "cases with an outcome", you will fall into the same errors that the previously mentioned figures have. We don't know enough about the disease make these calculations. If 1,000 people test positive, and you follow them, at two weeks, you might have 1 death and 19 recovered - that cohort of 20 is called "cases with an outcome" - does that mean the death rate is 5%? At four weeks, you might have 5 deaths and 495 recovered - is the rate now 1%? You can't tell, because you haven't followed the other 500, because that group doesn't have an "outcome". All you've done is circle the group you want and focus on that. That's a logical fallacy, commonly called "The Texas Sharp-Shooter Fallacy". We don't know yet how long people are going to stay positive without an "outcome" - we just don't have the data yet.
    When you're sitting at your keyboard, paranoid that people don't think you're as smart as you pretend you are, and needing to give your brain a little kick of dopamine to make yourself feel better, here's what you do: When you see something that you feel is wrong or needs debate, don't debate it. Instead, throw out an insult, and sit there, smugly waiting for a reply, and then let the fun begin. It doesn't matter whether you're wrong (which you mostly are), all that matters is that most civilised people, with better things to do, eventually give up for the sake of peace and quiet, and you can chalk up another victory in your sad, pathetic life.
  12. Aircon
    100,524
    Peter
    That was a lot of typing to cover up a back pedal and some intellectual snobbery.
    I'm glad to see that you finally agree that your figures are erroneous! Congratulations. That's what I've been saying all along.
    Lots of digs and insults in there, so it's pretty clear it's you with the chip on a his shoulder, but I digress.
  13. simon klein
    Feb 25, 2009
    29,783
    North Qld
    simon klein
  14. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    35,416
    Brisvegas
    Jon
    TLDR
  15. Aircon
    100,524
    Peter
    Make an effort! It's a put down....you'll love it.
  16. FazzerPorscheman
    FazzerPorscheman F1 World Champ
    Jul 28, 2010
    15,286
    Piz Gloria
    EnzoFerdinand
    LOL LOL LOL.
    Mate I’ve got tears in my eyes. [emoji16]
  17. Horse
    Dec 1, 2005
    35,416
    Brisvegas
    Jon
    Ok, I read it.
    I think you two need to get a room.
    I’ve never put that much time into you!!!!
    Maranello550 and DMWC like this.
  18. Aircon
    100,524
    Peter
    I agree. I'm flattered that Pat put in so much effort. I guess I really got under his skin.... Plus he was probably angry with himself for making a stupid post on the first placed.
  19. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,622
  20. Aircon
    100,524
    Peter
    OLIO
    Not my fault (it never is)
  21. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Steve355F1 and FazzerPorscheman like this.
  22. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,030
    Coolum Beach AUSTRALIA
    Karen H.
    Blame the morons who wouldn't play by the 'low level' rules (helped along by all the 'it's nothing, it's a hoax' comments), hence the escalation.
  23. kerrari
    Oct 22, 2004
    24,030
    Karen H.
    So getting close to their annual flu deaths (+/- 35,000 per year over a 20-2 week period)
    These are the important part of the Worldometer page - attachment is for Australia; these datapoints have not been available for USA for about the past week, they were available before... And once again - it's not about the DEATHS it's about the overwhelming of the hospital systems.( I thought Greg was going to explain that to you in the shower the other night?:p)
  24. moretti
    Nov 1, 2003
    59,757
    Australia
    Someone dropped the soap ........ :p
    Its328 likes this.
  25. JCR
    JCR F1 World Champ
    10,891
    H-Town, Tejas
    As of today in Houston, Texas population 2.5 Millions (9 deaths).
    https://www.click2houston.com/health/2020/03/05/man-woman-confirmed-to-be-first-cases-of-coronavirus-confirmed-in-harris-county/
    As for the total deaths in the article, they are counting areas beyond the Metropolitan Statistical Area (7.5 MM) which is only 34 dead.
