Coolant leak-expansion tank overflow tube | FerrariChat
Discussion in '308/328' started by millsj, Mar 21, 2016.
  1. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    I have had a coolant leak start recently and wanted some thoughts from the experts. First a little background-'86 328. Several months ago, I replaced a number of the coolant lines, so I had the system drained. I refilled the system and successfully bled the system. The radiator fans were cycling, engine temp gauge was steady and I had heat on both the driver and passenger side. Everything was fine for a while and then I noticed coolant dripping out of the overflow tube on the expansion tank (the one at the radiator cap). When I first noticed it, there was a solid line of coolant from outside into the garage, so it was more than just a drip.
    After reading on the forum, it sounded like a radiator cap was the easiest first step in troubleshooting. The original cap was still installed. I don't have the make and model handy, but it was the one recommended here on the forum. The leak continued after the installation of the new cap, but not as bad. However, after a drive last night, I had a solid line of coolant up the driveway. I have looked and the leak is coming from the overflow tube. The outside of the tube in dry and the only part that is wet is the very end.
    Some other observations-the engine temp gauge is steady on the mark between 140 and 195. I think I still have heat on both sides. I have opened the bleeder valve on the top of the water pump (with the car running) and coolant instantly seeped out when it was loosened. I think the biggest clue as to what is wrong is that every time I loosen the bleeder screw on top of the radiator (with the car running and up to temp), I get air escaping. I have now done this 3-4 times. The expansion tank is not overfilled. Prior to the drive yesterday, it was about half full.
    Any thoughts? One guess is that there is a loose hose clamp somewhere and as the system cools, it is sucking air into the system, causing the coolant to back-up next time the car is driven.
    My plan of attack was to put a wrench or screw driver on all the hose clamps I recently touched and see if anything jumps out at me. I have not put the car on stands to inspect the hoses, but I don't think there is a leak large enough other than the overflow tube to drip on the floor. That being said, there is an oil soaked piece of cardboard under the rear of the car, so it would be hard to tell if it was a coolant drip or oil drip.
    Any thoughts would be greatly appreciated. I am sort of scratching my head at the moment.
  2. BigTex
    79,321
    Houston, Texas
    Bubba
    Did you go one pressure rating HIGHER with the new cap?
    All the clamps are on the pressurized side of the expansion tank, IIRC the overflow tube is not even clamped, it just pushes onto the tubing flare...it cetainly sounds like your leak is still at the cap, itself, if it is coming from the overflow line..
  3. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    That is by far the easiest part to replace. It had occurred to me that the new cap might have been weak. They are cheap enough, so I might just order a new one. I'll look at the specs tonight and post that information.
    What is the general operating pressure of the system in normal driving conditions?
    I did pressure test the system after the hose replacement and it appeared to hold fine. I am by no means an expert here, but I think it lost maybe 1 or 2 psi over a 24 hour period starting at 15 psi. I figured that was good enough.
  4. Rifledriver
    36,750
    How full is the system? The tank needs to be about half full when cold for there to be expansion space for the water. If there is not enough expansion space it will push coolant out as described until there is enough space.
  5. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    It sounds like normal expansion. How full is the expansion tank?
  6. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    I think it is about half full, but may be lower after yesterday's leak. Something did change since it wasn't leaking and then all of a sudden coolant was leaking from the overflow tube. I had not added coolant after the system was refilled after the hose replacement and it didn't leak for a couple of months.
    I do know that the coolant level has to reach the top of the expansion tank for it to leak, so the question is what is causing it to reach those levels (heat expansion or something else). I'll also check the level tonight in the tank.
    I don't know if this helps, but I pulled up to the garage door last night and left the car running. I opened the bleeder screw on the radiator. At that time, I noticed the line of coolant on the driveway. Once the air bled out, I pulled into the garage and there was only a drip or two in the 20-30' I had to drive to park it. Either letting the air out allowed the coolant level to drop or the car idling did the same.
  7. Rifledriver
    36,750
    There will never not be a small amount of air at the top of the radiator. The bleeder screws get used once, when the system is initially filled. No need to bleed again until the coolant is changed.
  8. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    Thanks for the info on air in the top of the radiator. I had wondered if that was normal.
    I had thought that if the expansion tank was a a little too full, it would eventually self-correct once enough of the coolant had leaked out. So far, it hasn't.
  9. BigTex
    79,321
    Houston, Texas
    Bubba
    As Rifledriver points out, the level (when cold) at the expansion tank is "2/3rds full" or IIRC something like "9 cm." DOWN from the cap.
  10. BigTex
    79,321
    Houston, Texas
    Bubba
    The cap changed from 1.1BAR (OEM) to 1.2 or 1.4BAR, whatever the next stronger spring pressure would be;.
  11. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    My 328 pushes out some coolant via overflow pipe after a service and I noted they bleed it properly when adding new water and coolant, I often see 3x8 doing this after a 'hard ' drive, its normal in my opinion, if there is a little to much water in the expansion tank or when the level rises a little from pressure build-up it pushes it out, this happens on the road without us even realising. I found it stops after a while and will only re-occurr after the next coolant change.
    Regards
    Johnny
  12. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,080
    FRANCE
    Nope Alan: the standard cap is 0,9 bar OEM, athough some people prefer to have 1,1 bar.
    Rgds
  13. nerofer
    Mar 26, 2011
    12,080
    FRANCE
    Per the 328 owner's book, it is 6cm from the top of the neck, which corresponds more or less to the assembly crease between the top and bottom half of the expansion tank.
    Both my cars have exactly that level in their expansion tank, and neither have had any overflow for a very long time.
    Rgds
  14. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    Here is the radiator cap that I currently have installed. It was installed about 6 weeks ago after I first noticed the leak.
    Looks like a 16 psi cap.
    I would guesstimate that the coolant level in the expansion tank is about 25% full. This level was observed last night after the car had been sitting for 24 hours and it was leaking when I pulled it into the garage. No coolant has been added or removed since I pulled it into the garage.
    If I stick my middle finger down into the tank, the tip just touches the coolant. I have small hands, but I looks like the coolant is approximately 7 cm down from the cap.
    Is this the correct pressure cap? Any more thoughts as to what would be causing the coolant level to rise in the expansion tank? I don't think thermal expansion explains that much of a rise. When I filled and bled the system it after the hose swap, I filled the tank to the correct level per the owner's manual. As I said before, there were no leaks for a couple of months after the refill and now it has all of a sudden started leaking.
    Could I idle the car long enough to get it up to temperature with the cap off and observe what is happening in the expansion tank? Not sure exactly what this would tell me, but I could get a sense of coolant flow through the tank and if/how fast it rises. I still would think that if there was air in the system restricting coolant flow through the system, the car would be running warm. Sorry for the rambling thoughts, but I am just thinking out loud.
  15. nerofer
    Mar 26, 2011
    12,080
    FRANCE
    At the risk of writing obvious things, when I wrote that the cap is OEM at 0,9 bar, and that some put a 1,1 bar, I meant the cap of the coolant overflow tank, not the radiator cap.
    As already written, in both of my cars the level of coolant in the said overflow tank with which the cars are happy is exactly at the middle of the tank, where the junction between lower half and upper half is situated. It is no use on my cars to try to top-it further: they will throw the supplement overboard.
    Rgds
  16. Rifledriver
    36,750
    Ferrari changed that spec to 1.1 a long time ago.
    The coolant level can be ambient temp specific. In very hot areas more airspace is often needed.
  17. rkljr
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Just a thought, you might want to check the surface around the tank opening to ensure there is nothing that might be breaking the seal with the cap. A scratch, something stuck on the rim etc. I am running out of ideas on this one.
  18. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    The last couple of time I have driven the car it has leaked. The ambient air temps haven't been above 80 degrees on any of the drives. Sunday, the temps were probably in the upper 60's. 3/4 of an expansion tank should be more than enough room to allow for thermal expansion on a regular drive around town.
    I'll check for anything that might compromise the seal between the cap and expansion tank. I ran my finger around that lip last night and nothing jumped out at me, but I wasn't looking that closely.
    I still don't understand why the coolant level would even be rising that high in the expansion tank. I think If I can answer that question, I will solve the leak issue.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    If you continue to blow coolant out the tank after you have checked the pressure car and have the correct initial coolant level it can be indication that somewhere in the engine you may have a hot spot that is causing the coolant to flash to steam, thus forcing coolant out the overflow. This can happen under idle or low RPM conditions when the coolant circulation is reduced. A cap with higher pressure rating might help, but that can place additional stress on the cooling system.
  20. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    Not sure how often this happen but air could also be trap inside top of the thermostat housing which you can also bleed it from if needed. I believe this is also the highest point of the cooling system.
  21. nerofer
    Mar 26, 2011
    12,080
    FRANCE
    Inside the heaters and heaters' lines also, but I think to have understood from Joe's first post that this has been bled (heater circuit fully open during a drive)?
    Rgds
