430 - Convertible top hydraulic fluid change | FerrariChat
430 Convertible top hydraulic fluid change
Discussion in '360/430' started by LorenzoR, Nov 27, 2022.
  1. LorenzoR
    LorenzoR F1 Rookie
    Im not really sure about this but i thought it would be a good idea to change out the fluid as it most likely been in there for 15 years now. I couldnt find a change out thread for the F430 so here it is but im stuck at the moment as i dont want to force anything. In the pics all the bolts circled in red are removed to give you alittle more access and room to move the unit out. The bolt on the bottom in green secures the unit. Once that bolt is out the unit slides up ( slides are in green). The problem im see is its pretty tight. I can slide it up only so far then i started to run out of room so i stopped. I noticed those slide are bendable but i didnt wanna do that either untill i asked. Has anyone with a 430 removed this unit? Thanks
  2. colorfull
    colorfull Formula 3
    2,280
    Franklin Park, New Jersey
    John Napoli
  3. LorenzoR
    LorenzoR F1 Rookie
    Yes I did but he doesn't really mention how it came out except for a 90 degree tilt. I want to do a visual on the fill screw because 5mm allen seems loose
