Control arm rear outer bushing | Page 2 | FerrariChat
Discussion in '308/328' started by russh, Nov 6, 2020.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Ok you’ll all set then.
  2. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Hi Mike,
    Just wanted to check with you, is there any special way that I will need to press the inner sleeve back into the outer bushing. I finally have everything back from plating.
    Russ
  3. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Putting it back is actually easier, I just used my vise to press the sleeves in until the sleeve is flush on both sides.
  4. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Hi Mike,
    Thank you, I wasn't sure if I needed any outside support on the sleeve when pressing it back into the outer bushing. I used my press, since my vise isn't a very good.
    miketuason likes this.
  5. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    I would like to know if anyone encountered a problem with the inner sleeve being too tight for inserting the inner bushing. I was only able to insert 4 inner bushings into the inner sleeve. The other 4 I couldn't by hand. I suspect that they do not need to be forced into the inner sleeve.
