Control arm rear outer bushing | FerrariChat
Discussion in '308/328' started by russh, Nov 6, 2020.
  1. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Hi, I am going to be replacing all my bushings on 85 308 QV and would like to know what needs to be replaced on the rear outer bushings. Do I need to replace the entire complete outer bushings, or just certain parts like; rubber seals, inner bushings, thrust washers, etc. I already have the inner bushings and wanted to get suggestions on what is needed for the outer bushings. Thank you. Russ
  2. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    You might want to open your own thread. Thanks, Russ
  3. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    379
    PA
    Alex
    Agreed. Deleted.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
  5. Steve Magnusson
    25,123
    miketuason likes this.
  6. Glenn308QVturbo
    Sep 20, 2017
    34
    Glenn Orell
    When I did mine the only thing I changed were the Thrust Washers (9) and the Inner Bush (8). They are coated with PTFE (Teflon) and mine were shot. Unless something else is obviously worn I wouldn't touch them. If your having trouble finding the Thrust washers they are available from Motionindustries.com for $4.03ea the part number is WC20DU. Sounds like you already have the inner bushes but if someone else is looking there available from asb-American Sleeve Bearing (asbbearings.com) for $2.00ea part number ZU MB2025ZU. I agree with Steve if yours are in good shape I would reuse.
  7. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Thank you, I did a search and I didn't find anything related to the outer control arm component replacement. I was thinking of replacing the thrust washers (9) and possibly Inner Bush (8). I will clean up the parts and look for wear. It seems that the inner bushing rubber just ages over time and becomes cracked and worn.
  8. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Does all 308 thrust washer on the rear outer A arm has the PTFE coating on one side and is it important to have that coating?
  9. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    The PTFE coating rides against a polished surface disk. This is a dry lubricant set up and the rubber seal keeps it dry..... just saying. No grease is used on this set up.
  10. Glenn308QVturbo
    Sep 20, 2017
    34
    Glenn Orell
    As far as I know all 308's used the same design and would stand to reason that they all used the PTFE washers and bushes. If the PTFE is worn and the washer and disk are metal to metal your going to end up destroying the other parts. For the price of replacements it was a no brainer for me to replace them.
  11. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    I am considering powder coating the control arms, but I would like to know if the suspension outer bush (4) needs to be removed prior to powder coating. I know that the inner bushings need to be removed prior to powder coating.
  12. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I believe the oven is heated to between 350-450°. You'll want to remove the bushings.
  13. Glenn308QVturbo
    Sep 20, 2017
    34
    Glenn Orell
    I'm not an expert on powder coating but I believe they have high heat tape that they can mask off the metal outer bushings with. Not sure if your going with OEM style rubber inner bushings or going with aftermarket poly urethan bushings. If your using urethan just remove the inner sleeve and rubber and have them mask the inner surface. Birdman's site has a good tutorial on replacing the OEM with poly.
    BLACK HORSE likes this.
  14. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Thank you, I am planning on using OEM inner bushings.
  15. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    On my 1982 308GTSi the answer is yes the outer bushings and sleeves need to be removed. Powder coating would not be good on those surfaces..... just saying.
  16. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Ok, that is what I thought. Thank you.
  17. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
    #17 miketuason, Nov 21, 2020
    Is this correct, the PTFE side is facing this shiny disc just like this pic shows? I also bought the last five thrust washers from Motion Industries and the last three from Applied Industrial Technology. Motion Industries said they can order more but there’s a minimum of 25 pieces and for $3.79 each, it’s still cheap. Image Unavailable, Please Login
  18. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
  19. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,216
    Black Forest Germany
    Martin N.
    Yes. And make sure, that the little pin in the opposite part is still present.
    Best from Germany
    Martin
    waymar and miketuason like this.
  20. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Thanks Martin, and yes they are still present, I think the pin is stuck cause I can’t remove the pin. Image Unavailable, Please Login
  21. Martin308GTB
    Jan 22, 2003
    4,216
    Martin N.
    That's perfect. I am not sure, whether the pins should be a press fit anyway. Mine were stuck as well. Except one, which fell out, while doing the job.
    Best from Germany
    Martin
  22. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    The pins come out with small diagonals. They are available from the disk suppliers. Common part.
  23. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
  24. miketuason
    Feb 24, 2006
    15,534
    Cerritos, CA.
  25. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
