Control Arm Bushing Replacement??? | FerrariChat
Discussion in '360/430' started by m.roberts, Jun 19, 2012.
  1. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    Dealer says that my bushings are bad on my 2008 Scud. They say it isn't covered under my Power Normal warranty and that I have to replace the entire control arm at a cost of near 5k for parts and labor.
    This cannot be right.... anyone???
    TIA
  2. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    16 bushings would not fail at the same time, you have better chances to win the lottery.
    Bushings are a wear item. I would inspect them myself (2 bushings per arm, 2 arms per corner). It is easier to replace the control arm than replacing the bushings, replacing the bushings adds around 2 hours per control arm plus the spare bushings (2), so you end up paying more, better off to get new control arms.
    I remove and reinstall an upper control arm in 10 minutes and a lower one in 15 minutes.
    The quote for $5k to replace the 8 arms + labor is right, but I doubt the 8 arms have worn out bushings. Where did you drive this car? flood damage salvage title? off-roading or rally driving? mileage? parked in the desert for month?
  3. datax
    datax Karting
    Apr 9, 2006
    203
    VA (Washington DC)
    Ken T
    What are the symptoms of wear bushings? My Scud makes a slight knocking noise from the front when driving over drainage holes on the road (Rad, it is very similar knock to 996 GT3's front sway bar bolt lose). Wondering if my bushings need to be checked. And, how much are the control arms? Any place I should look ordering it?
  4. 360 SPI
    360 SPI Rookie
    Apr 28, 2012
    1
    South Africa
    Clive van Kerckhoven
    Sounds like ball joints, the top tend to go first
  5. Ricambi America
    Sponsor Owner
  6. m.roberts
    Nov 2, 2009
    907
    exact same symptoms
  7. m.roberts
    Nov 2, 2009
    907
    I am the second owner, I bought it in November 2011 with 1,600 miles. Zero damage, etc.. I live in Oklahoma, and aside from driving it like it is stolen, it is very pampered. I have asked the dealer to be more specific as to whether it is the bushings or the ball joints.
  8. m.roberts
    Nov 2, 2009
    907
    Daniel - Yes, that is me.... I have emailed the dealer to find out more.
  9. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Daniel,
    Do you guys have an in-house service, so I could ship you my Lower Control Arms or Upper Control Arms and get the ball joints replaced with the Hill Engineering versions?
    I do have different bushings (Delrin) in the connection to the chassis, but I haven't replaced these ball joints ever, and eventually they must let go.
  10. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Lowers tend to go first.
  11. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Don't always assume its the arms. The grease in the front anti roll bar bushes dry out and they get noisy, drop links knock and track rod ends make the same noise. Have it checked properly before spending a fortune on ball joints and. Bushes.
  12. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    There are many sources for the noise you describe:
    1) the plastic spacers top and bottom of the springs tend to crack (I have them removed in my car as I use a different suspension).
    2) bushing attaching the LCA or UCA to the chassis
    3) Ball joint attaching LCA and UCA to upright
    4) wheel bearings
    5) worn out caliper pistons and bouncing brake pads
    6) caliper attachment to uprights
    7) drop links joints
    8) anti-sway bar support to chassis
    9) anti-sway bar bushings
    10) steering rod
    11) loose lug bolts
    Jack it up and check it, the car should be free of noises. One thing I like about the lack of insulation in the Scuderia is to be able to detect maintenance needs sooner rather than later.
  13. Ricambi America
    Sponsor Owner
    We do not have any in-house service capacity.
    The tool for the ball joints is also available in stock here: http://www.ricambiamerica.com/product_info.php?products_id=343682
  14. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
  15. Ricambi America
    Sponsor Owner
    The adhesive is Hysol. We have a bunch on order (like a really big quantity), but its not due to arrive until mid-July. Hysol, while you can often get it in big tubs, is a pain to get in the smaller Sempak tubes (how we'll have ordered it) make the most sense of these ball joints. Hysol, in its normal shipping quantities is for airframe construction, so the sizes can get crazy, for sure.
    Hysol is a date-sensitive product, so we need to keep it refrigerated and ship with special procedures.
  16. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Thanks Daniel. It would be a great addition to the ball-joint replacement kit in the Ricambi website.
  17. m.roberts
    Nov 2, 2009
    907
    My Message to dealer:
    In regards to the issue with the front suspension on the car, could you give me a few more details?
    I spoke to a tech I know, and he was curious whether it was the bushings in the control arm OR the ball joints? He told me that the ball joints are an item very prone to early wear / failure.
    Any additional info you can share would be greatly appreciated.
    Thanks,
    Matt
    _________________
    Their response:
    Matt,
    Great question, but no, the rattling noise is from the bushings in the upper & lower control arms. Most of the expense is for the 8 bushings, plus the labor to remove the 4 control arms, press out the old bushings & install new ones. Not a ball joint issue at all. If you want us to proceed, let me know. The lower bushings are in stock at FNA and have to be ordered.
    Thanks,
    I have a call into FNA to see about this whole deal as I am pretty skeptical based on what everyone here has said....
    let me know if anyone has other suggestions
  18. datax
    datax Karting
    Apr 9, 2006
    203
    VA (Washington DC)
    Ken T
    Interesting. I would double check with independent shop before going ahead with the dealer if I were you. Please post the update with which route you decide to take for fixing it. I'm taking the car on a lift this weekend and plan to diagnose on my own at least. Noise is *very* similar to sway bar lose bolt on my ex GT3 so I'm starting from there first. Also, it only happens occasionally and only when you drive over manholes.
    EDIT: Did a quick search and found this, http://www.ferrarichat.com/forum/showthread.php?t=329479&highlight=knocking+noise
  19. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    My 360 has some knocking sounds up front too, nothing bad and since I had never driven another 360 I almost thought it was normal. Dealer said something is wrong up front but did not research what as they were working on something else.
    I have a lift at home (both a 4-post and 2-post, I got the 2-post only because I was looking at a 355 that needed its engine out, 2 days after the lift is here, I found my 360). I am mostly a mechanical kind of guy and try to do it all myself, how do I identify if the noise is from the bushings or ball joints ? I saw the Ricambi tools for swapping out the ball joints and have a press so that is no issue but how do I identify where the problem is ? I assume that it wont be that obvious as too look for slop somewhere since the car drives fine.
    I have done bushings on Dino's and 308's, the 308's are a pain since you have to grind the factory weld off to get the bushings out and then tackweld the new ones but those bushings after 40 years were obvious to see what was wrong, on my 360 I assume it will look/feel fine. By the way my 360 has 54,000 miles and no records of front end work.
  20. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    +1. Those bushes (flanblocks is the Ferrari description) just do not rattle. They creak, they have excessive deflection due to rotted rubber, but they do not rattle. Ball joints, track rod ends, drop links and anti roll bar bushes rattle......
  21. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Just to throw something else into the mix - I *think* there was a revised bolt produced by Ferrari that secures the front shock and drop link to the wishbone. They revised it because the old style can cause a creaking sound!
    In any case, just to re-iterate Eddie's point - worn flanblocs do not cause a knocking sound. If it were my car I'd have it up on a ramp and would test each componant for play and replace as needed. Don't forget to use something like a transmission jack under the wheel to simulate a load through the suspension when testing.
  22. steelej
    steelej Formula Junior
    Jan 15, 2007
    433
    Balljoints are actually covered by the power normal warranty, looks like the dealer is trying it on with you, my ball joints going had exactly the same symptoms you describe, all front wishbones were replaced under warranty.
    John.
  23. m.roberts
    Nov 2, 2009
    907
    I appreciate all the help and advice from everyone.
    Still waiting to hear back from FNA today.... I'll keep you updated.
  24. m.roberts
    Nov 2, 2009
    907
    Talked with FNA.
    They are unwilling to assist with the cost. They also feel very confident in the assessment by the tech that looked at the car and diagnosed the issue.
    After talking with Daniel at Ricambi and a tech at another dealer, neither of them seem to think that the bushings discussed are the issue.
    I have declined to repair this issue. I was assured that it would not impact saftey in any way.
    I will have an independent shop look at the issues when it returns to Tulsa. Based on what they will say, I will make a decision at that point.
    I am EXTREMELY disppointed with FNA on this deal. It is enough that I am pondering selling my vehicle upon its return to town. I believe in taking care of customers and standing behind your product. I don't feel that either of those is being done in this case.
  25. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Spot on voicey. There was indeed a revised bolt. The shock lower joints also knock. It sounds like a poor analysis has been done on the op's issue.
