connecting battery tender to dino | FerrariChat
Discussion in '206/246' started by vrooom, Jan 21, 2020.
  1. vrooom
    vrooom Formula Junior
    Jan 29, 2007
    448
    i want to connect a battery tender (DELTRAN ) to my dino , as the battery is not easy to get at and has the cover as well as the spare tire above it i would like to know how others are making the connection. charger comes with "ring terminals" to make connection to the posts - i'm just not sure about "pinching " the harness under the battery cover as it runs into the front compartment. thanks for any tips ! dan
  2. Bluebottle
    Bluebottle F1 Veteran
    7,710
    Newbury, Berkshire, England
    Mine is wired in to two of the terminals in the fuse box. I can't tell you which without going to check, but I am sure it will be obvious.
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,649
    Southern California
    I run mine from the battery terminals and feed/sandwich it between the battery cover and compartment floor. I have the wire pop up through my spare tire. Never any issues. Still the original Interstate battery that was in the car when I bought it in 2010! I’ve used Detran chargers for years on my cars.
  4. vrooom
    Jan 29, 2007
    448
    thanks, guess i will do the same. in the 40 years i've owned the car i have not used a battery tender -always made a point of taking it out for a spin at least every couple of weeks.
  5. UroTrash
    UroTrash Three Time F1 World Champ
    Jan 20, 2004
    38,916
    Purgatory
    Clifford Gunboat
    Mine runs out of the bottom and dangles just below the floor pan.
    It is convenient since the car is parked on the upper bunk of a 4 Post car lift, eye level.
  6. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    I use a CTEK charger. I attached their fused extension directly to the battery terminals and routed the wire down to one of the holes beneath the nose. This is convenient for me as the charger sits on the floor. I do have to get on the floor to o plug the charger to the extension.
    Andres
  7. dgt
    dgt Formula 3
    Jan 14, 2011
    1,283
    Northeast, USA & Oz
    Andrew
    +1
    I use a CTEK also with the same location, saves leaving something open if the car is in storage.
    I have a kill switch for the earth under there next to it also.
  8. ENZOSON
    ENZOSON Formula Junior
    659
    Erie, Colorado
    PIETRO
    No battery tender here. Just a kill switch for the clock. No issues with battery holding charge.
    Pietro
