Coilovers for F355 | Page 2 | FerrariChat
Coilovers for F355
Discussion in '348/355' started by jeffdavison, Jan 19, 2020.
  1. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,171
    NYC, USA
    Phil
    How will you address the stock shock adjuster motors that recenter the stock valves when you start the car and switch between comfort and race modes? Won't the ECU throw a dashlight thinking something is broken? Are you going to remove all stock components or just ignore the light?
  2. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    stock shock motors are not used, removed when OEM shocks removed. Not sure if the shock light comes on or not, but I have removed the bulb. I believe it's on a dedicated circuit and it won't throw a C.E.L on the main ECU, so there is no issue here to worry about other than having a sport mode switch on the console that doesn't do anything..... I'll probably use that switch or fit another switch in its place that will work the front lifter.
    OCKlasse likes this.
  3. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,171
    NYC, USA
    Phil
    Great approach, I'm very interested in how this all turns out. Thanks for posting this project.
  4. coolzeal1
    coolzeal1 Rookie
    Feb 28, 2016
    1
    what are your driving impression on the coilover, how do they compare to stock in term of street use?
    sherpa23 and Cole_ve like this.
  5. Longtime355fan
    Feb 24, 2020
    34
    Atlanta, GA
    Update please.
    Steve Dekorte likes this.
  6. Steve Dekorte
    Steve Dekorte Rookie
    Jun 22, 2019
    12
    California
    Steve D
    Any word on when this 355 kit can be ordered from MCS?
  7. Ferrarista98
    Ferrarista98 Formula Junior
    258
    Jason L
    Wyatt at MCS is a joy to work with. Responsive and knowledgeable. Don’t know about the 355 setup but he helped me a lot with my 964 and it’s now setup perfectly thanks to him.
  8. ruey220
    ruey220 Formula Junior
    312
    Sf bay area
    RM
    What did you do with the factory motors on top of the bilstein shocks when you went with the aftermarket setup? Did you just disconnect them? Did you also remove the ECU?
    I'm thinking of doing the same, but was wondering the implications of the other components like the Suspension ECU module, and on the F1 the sport switch is connected to the F1 tranny ECU, so I'm wondering if removing the bilstein one would affect the tranny as well.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    SoCal LA/OC/New Mexico
    Tim Dee
    I like the new bouncy bouncy thingys
    On my Christmas list :)
  10. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Unfortunately, we don't have full wiring diagrams for the F1 car. On the non-F1 cars which have a shock absorber symbol warning light on the dash (not a SPORT light), the Bilstein Suspension ECU seems to be providing an earth to do 3 things:
    Putting on the (soft) suspension light.
    Completing the switch backlighting circuit.
    Sending an earth to pin A-3 on the Bilstein Suspension ECU to put the suspension into soft mode.
    On the F1 car, the switch internals could be different, the switch wiring could be different and the result of pulling back on the switch is definitely different. Why not just pull the plug on the Suspension ECU (yellow plug) and see what happens to the SPORT light? Does it still work? Does the switch backlighting still work?
  11. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    528
    London, UK
    Thibaut A.
    My car modified and the electronic suspension replaced with traditional one. As it was done for racing (it’s a challenge) I can’t really comment on comfort vs standard set up.
    But it clearly can be done and no cel or anything.
  12. ruey220
    312
    Sf bay area
    RM
    I will definitely it try it when I get around to it. But my main interest was 1) what to do with the red motors on the factory suspension if I go with aftermarket. Should I just disconnect those motors and leave the wires hanging?
    2) if I'm not using the bilstein setup, can I remove the suspension ecu? Just disconnect and leave the wiring harness there?
    If I can deal with the first two and have no errors or malfunctions then I will deal with what I can put in the sport switch space or just use that to control the setting for the f1 tcu.
  13. ruey220
    312
    Sf bay area
    RM
    Did you leave the bilstein ecu module there?
  14. Qavion
    11,534
    Ian Riddell
    That's up to you, but why would you leave the motors sitting in the engine bay rattling around and looking out of place? They are valuable. The Bilstein ECU puts on the fault light when there is a fault, so removing the ECU entirely should prevent the light illuminating. However...
    That's what you have to prove yourself (by disconnecting the plug/s). Even if the F1 behaves normally, you still want the SPORT switch to control the F1 system and not look dark when your sidelights/headlights are on. You have to prove that the Bilstein ECU does not supply an earth on the F1 car (for proper switch operation). I think at worst, you would have to simply provide a substitute earth on the (disconnected) Bilstein connector.
  15. Mark HT
    Mark HT Rookie
    39
    Mark HT
    Any updates Jeff? MCS and Ramlift looks like a very good combination.
  16. OCKlasse
    OCKlasse Formula Junior
    644
    Newport Beach, CA
    Brandon K
    I am using a combination of Nitron and KW HLS. Besides a slight modification to the lower spring, it was almost essentially bolt in. I was looking into Ramlift, but a few videos of it in action scared me off.
    ShineKen and Mark HT like this.
  17. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,545
    LA
    Kevin
    Hopefully the OP Jeff has some updates
  18. radback
    radback Formula Junior
    525
    France
    What is the problem with Ramlift system? Leaks?
  19. OCKlasse
    644
    Newport Beach, CA
    Brandon K
    This vid says it all.
  20. radback
    525
    France
    Obviously something is wrong with the pump.
    It doesn't mean the lift system is no good.
    I'm searching an aircup system that fit on a 355. Air is faster (and cleaner in case of leak) than hydraulic.
  21. OCKlasse
    644
    Newport Beach, CA
    Brandon K
    I know you’re looking for air cups, but honestly, the KW system has been great. Zero leaks, whisper quiet, extremely reliable.
