CNG-Compressed Natural Gas as a Fuel? | FerrariChat
Discussion in 'Technical Q&A' started by pastmaster, Sep 11, 2008.
  1. pastmaster
    pastmaster Formula Junior
    Feb 5, 2006
    890
    Alma, Michigan USA
    HI Everybody :D
    I would like to open a discussion on the likelyhood of using CNG as a fuel for our Ferrari's. I am considering converting some of my older cars, that I don't drive that frequently, because of the Winter climate in Michigan, as one of the reasons, and time and my health, as the others.
    I am thinking of the older V12, Weber Carb. engined cars primarily, but also the current modern era Ferraris, too, as using CNG. The fuel is much cleaner in combustion, and higher octane in it's nature. Storing cars with it as a fuel, will be better because it should keep it's quality for a longer time, than gasoline or diesel. The cost of the fuel is about $1.50 a gallon equivalent. I don't know about the cost of conversion or if you can use your houses supply, with the suitable pumping and safety equipment? Yes, listening to T. Boone Pickens, gave me the idea.
    What do you think?
    Ciao...Paolo
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,288
    Edwardo
    #2 350HPMondial, Sep 11, 2008
    Paolo,
    Propane is cheaper, safer and easier to use....
    CNG = BOMB.
    I am going to go with E85 in my Ferrari within 5 years..
    See photo of a CNG Honda,,....!
    Do you see any chance that the driver survived...?
    Ciao,
    Edwardo
  3. fatbillybob
    Aug 10, 2002
    28,565
    socal
    Not sure why propane bomb would be safer than CNG bomb? But the cool thing that could make your idea happen would be if there was an easy way to compress your home NG as it comes out of the wall to a CNG in a tank for your car. As far as running a car on it that would be an easy conversion IMO.
  4. 350HPMondial
    5,288
    Edwardo
    LPG = 150 psi
    CNC = 3600 psi
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #5 2NA, Sep 11, 2008
    You might be on to something.
    Converting an older carburettor equipped engine to run on CNG would be an interesting R&D project and something I've been considering as a Winter project here when things slow down.
    It appears that there isn't much in the way of ready-made systems that can be installed on older vehicles. This doesn't mean that it can't be done however.
    The natural gas infrastructure for refueling isn't very extensive yet (none in Minnesota) and in the Midwest, the ethanol lobby has gobbled up all the public dollars available to fund their folly. I expect that before long E85 will be phased out as it's an inefficient fuel that without public subsidy would be more expensive than "foreign oil".
    Home systems for refueling are available from FuelMaker Corporation. The system costs a few thousand$ and fills the tank overnite.
    As to safety, it's true that the stored pressures for CNG are much higher (like a Scuba tank) but natural gas is lighter than air and doesn't tend to "pool" in low areas (like much heavier Propane) and seek out pilot lights. Natural gas is generally regarded as being safer.
  6. 412monzaindy
    412monzaindy Formula Junior
    Mar 8, 2005
    876
    Ontario Canada
    PBI
    Having some experience in this, I would say no. One company I used to work for was using propane to operate their bucket truck.
    There were some advantages such as the following.
    Cleaner burning
    Cleaner OIL
    Cheap to fill
    Lower pollution.
    Higher Octane.
    Against:
    Storage tank in the vehicle
    How long does the tank last before replacement
    How far do you want to drive to fill up
    Less power, so advance the timing
    Refit the carbs, you shouldn't use your existing carbs,
    Higher maintenance on the control components
    Valves and rubber components can leak and they do wear out.
    It make great engines fires
    It is harder to start the engine in colder climates.
    Certification is required by qualified personel
    You can smell it, but you can't see it, when it leaks
    shall I go on?
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    CNG is Compressed Natural Gas
    Propane is Liquified Petroleum Gas
    They are quite different.
  8. glasser1
    glasser1 Formula Junior
    Sep 2, 2006
    510
    Oregon
    As others have said you want to use propane, not CNG. I had a truck that ran off propane. The prohibiting factor is the large cylindrical tank. No place to put it in a small car.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Perhaps you weren't paying attention.
    CNG is Compressed Natural Gas = American source, lighter than air
    Propane is Liquified Petroleum Gas = Foreign Oil source, heavier than air
  10. pastmaster
    Feb 5, 2006
    890
    Alma, Michigan USA
    #10 pastmaster, Sep 11, 2008
    Guys,
    Great discussion! It is educating me, as well as others to the good and bad of such a conversion.
    As stated, there are many variables for each application, that I was unaware of.
    Up here in Michigan, the Schwantz Food trucks operate on LPG, I think, and have since the first fuel crisis, in the 1960's. The drivers I have talked to, don't have many bad things to say about it and are in favor of it, for a big delivery truck. I have seen it in widespread use in Sydney, N.S.W. OZ, on their busses and commercial vehicles, within the city.
    More posts please! Maybe we can come-up with something useful for daily use. We also can find the "Devil," in going this route, particulaly in Ferraris and cars of this type. How about motorcyles, with their limited space and high output/revs engines?
    Let's open the question up to Hydrogen too, and Coal in all it's forms, for energy uses. If we are going to "blow-up real good," may as well include Hydrogen, etc. I have read that a gallon of gasoline, has the explosive power of 6-sticks of dynamite? Engineering will have to overcome the safety and fire problems, before anything happens on a grand scale. The manufacturers, will be the ones to re-engineer the carbs and safety systems, for them to compliment and not conflict, with one another. We need to begin someplace, to compliment our petroleum needs, if not eventually replace it, because of political and economic realities.
    We put a man on the moon, with an electric car, and we should be able to this with world wide efforts. It may mean going back to a Mule and Wagon, for local travel and deliveries, in order to conquer Space and our Economy.
    Ciao...Paolo
  11. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    The immediate problem I see is the huge pressures the methane must be at in order to have enough fuel to go a reasonable distance. Here are the heats of combustion for the fuels:
    n-ocatane 1303 Kcal/mole C8H18 - 114 grams
    propane 526 C3H8 - 44 grams
    methane 211 CH4 - 16 grams
    Roughly, as far as heat of combustion is concerned, they are in the same ballpark on a per gram basis. Methane has the highest value.
    Given that, one has to compress methane to very high pressures to get it anywhere near what n-octane or propane possess on an energy per volume content. The density of liquid propane is about 31 lbs/ft**3. At 5000 psi, the density of methane is about 14 lbs/ft**3.
    I don't see how to contain it given how frequently cars are smashed.
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #12 2NA, Sep 11, 2008
    A properly engineered pressure vessel (or several smaller ones), thoughtfully located in the vehicle shouldn't be any less safe than the 20+ gallons of gasoline that cars currently carry in thinwall metal or plastic tanks.
    The point of the "Picken's Plan" isn't that CNG is the ultimate fuel, only a less expensive "bridge" to whatever is. It's available here, now and conversion of a vehicle is a feasible proposition.
    Other fuels like hydrogen and coal (no idea what you would do with that) are possible but have their own engineering obstacles that prevent any short-term use.
    Just to restate it, Propane (LPG) is just another distillate from crude oil like gasoline. We are buying it from countries that are screwing us on the price and we need to stop.
  13. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    True, and this raises another advantage of CNG over Propane... CNG is lighter than air, and so dissipates readily if there's a leak. Propane is heavier than air, and so can pool in the bottom of a trunk (for instance), rather than dissipating. Our utility used many propane forklifts with the tank on top of the vehicle, so that wasn't a concern. We also tested some CNG Cavaliers, borrowed from the local nat. gas utility. I've seen film of tests of CNG tanks, and IIRC, they have even been tested to withstand pistol cartridges. At the very least, they are tested to withstand almost any conceivable car accident scenario. Leaks are another issue, though, and I'm not sure of any record of CNG tanks actually failing, if they've been properly maintained and inspected during their service life.
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Running upwards of 3000 psi, I wonder if the tanks need to be removed and be Hydro-tested every 5 or so years like the scuba tanks? I suspect they would require that running these pressures.
    Pistol round safe or not, I sure would want a stout roll tube structure around one of those tanks with the valve facing sideways. Those TV ads have me thinking about an experiment in the future as well.
    Dave
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The tanks would require periodic re-certification just like other pressure vessels. In addition, the fueling equipment from FuelMaker is expected to be remanufactured after 5 years (can be done twice). This isn't cheap, this is really just a stop-gap system until someone develops a better one.
  16. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    Then why did the NHRA outlaw on-board compressed air tanks decades ago? (guys got the idea to inject air from scuba tanks into the carburetor for a "turboless" turbocharger effect) NHRA outlawed it because of fear that the tanks would explode during a crash.
    I wouldn't want to be anywhere near some ratty car powered by a 3000PSI CNG tank.
  17. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    NHRA rules are written by lawyers.
    No "real world" knowledge required.
  18. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    I recall a guy that ran NHRA a few years ago on natural gas..the car was called "Natural Gasser". I don't recall his name, (Jose Melendez or something like that?) but ran the car successfully for years. Not sure if he's still running it or not. NHRA didn't outlaw compressed air tanks decades ago,(maybe outlawed them injecting it into the engine) there's still cars that use air shifters, we used them on Pro Stock cars up until the mid-nineties, when they said "shifting had to be a direct mechanical function of the driver".
    But I'm fairly sure air shifters are still allowed in the sportsman classes.
  19. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    I don't have access to my old Hot Rod magazines, but somebody wrote a letter asking about the feasibility of directing compressed air into the carburetors as an alternative to supercharging. They replied that it had already been done and showed a picture of a rail dragster with compressed air tanks mounted between the front frame rails. Then they indicated that it was later outlawed for fear of crash explosions. That's just what I read in the magazine.
  20. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Can't answer for NHRA, and not trying to be a Gas Industry proponent. But I'm sure CNG tanks are over-designed, to hold pressure required and also withstand impacts from crashes. But I agree that I'd also want extra structure to help protect the tank.
  21. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Here's a Powerpoint presentation that presents design and testing of CNG tanks. Also shows a gunfire test starting at slide 29. I can't tell from this if the gunfire test is required by codes, though, as part of the test standard.
    http://www.cleanvehicle.org/technology/CNGCylinderDesignandSafety.pdf
  22. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    They're going to have to rewrite a lot of laws if anybody goes the CNG route. Propane tanks going through tunnels are regulated. http://www.travelriver.com/forum/viewtopic.php?t=1076 and other links. Imagine a propane or CNG tank exploding in a tunnel. A perfect oven.
  23. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Kind of like a gasoline tank truck? ;)
  24. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    gas and propane tankers are in fact forbidden from some routes.
  25. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    huh? there are already many CNG vehicles.
