Clutch master / slave cylinder oil seals 512BBi | FerrariChat
Discussion in 'Boxers/TR/M' started by pshoejberg, Dec 2, 2017.
  1. pshoejberg
    pshoejberg Formula 3
    1,784
    Denmark
    Peter H
    Anyone that know a source for the oil seals in the clutch master- and slave cylinder for the 512BBi ?
    Thanks, Peter
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,403
    romano schwabel
    just go to a hydraulic specialist who is rapairing brake cylinders. if he is good he has such parts in stock, normal sizes, nothing special ( was told to me when I needed about 7 years ago )
  3. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
    Slave : Seems the same as for mondial
    Ferrari Part #111275
    Fits: Ferrari 512 BB, 512 BBi, Mondial 3.0 QV (1984), Mondial 3.2 QV (1987), Mondial 8 (1981)
    #111275: Seal ring
    Those 3 seals (donut inclusief) you can find at http://redbaycars.com/remanufactured/ferrari parts.html
    but master has other number....if you have the diameter we can compare if those are the same as for mondial.
    seems also to fit mondial and tr.
    Ferrari Part #175211
    Fits: Ferrari 288 GTO, 348 (2.7 Motronic), 348 TS (1993), 355 (2.7 Motronic), 355 (5.2 Motronic), 456 GTA, 456 M GTA, 512 BB, 512 BBi, 512 M, 512 TR, 550 Barchetta, 550 Maranello, 575 Superamerica, 575M Maranello, F50, Mondial 3.0 QV (1984), Mondial 3.2 QV (1987), Mondial 3.4 t Coupe, Testarossa (1985), Testarossa (1990)
    #175211: Clutch master cylinder
    Guido
  4. pshoejberg
    1,784
    Denmark
    Peter H
    Thank you both. Prefer to get my hands involved, so I will take the troublesome and sometime more expensive, but funnier route of repairing it myself. Hence need to dismantle the cylinders, measure the dimension, order the seals via Guido's link above and hope they fit. I will be back with an update later.
    Best Peter
  5. pshoejberg
    1,784
    Denmark
    Peter H
  6. theunissenguido
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
    Hi, Peter,
    External diameter new seal is 17.7 mm for donut and seal with lip...so that fits.
    For the slave seal 22 mm. Dont forget it has to be a little bit more new than used !
    I do use them myself on my mondial. The slave seal I change evey 2 years (a 20 minit job) to avoid moisture inside the slave cilinder.
    For the master its more a pain in the .... Those (donut+seal with lip) seals are 4 years in the master and they work great.
    Guido
  7. pshoejberg
    1,784
    Denmark
    Peter H
    Thanks Guido your input is much appreciated....I will give it a try.
  8. theunissenguido
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
    Peter,
    Gjort med glaede, det er det faellesskabet er for !
    Guido
    pshoejberg likes this.
