Clling on the brotherhood - a 348 Gerbox problem... | FerrariChat
Discussion in '348/355' started by Marco Bussadori, Jul 31, 2008.
  1. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    #1 Marco Bussadori, Jul 31, 2008
    FBB, Ernie, No Doubt, Plugz and all,
    A couple of weeks ago I thought I had an implosion pending (slight whine). I had it transported to QV London (very reputable race preparers, who maintain Marco Pullen's Formula Pirelli f'cars)... I KNOW I have a flywheel greasing issue...
    Their finding was VERY positive and made me feel I was overly paranoid, they said I'll probably need a new release/flywheel bearing, but that there was no noticeable whine, and thus I was OK re. the gearbox.
    I used if for two weeks and I started getting a nagging whine again, when at very low wheel RPM, eg. when setting off and at very low speed. The whine is getting progressively more noticeable so much so that my 5 year old remarked on it tonight when we went out for a spin.
    Car has a total of 24,000 miles since 1989, I did about 7K in the last 12 months. Lots of city driving, a few daytrips to Paris (500 mi. return) and a single trip to Denmark (2000 mi in 3 days). Gearbox oil using Redline 75W90NS,and 75W90 in a 5:1 ratio. 6 months /3K miles ago, and Castrol 75W90 prior to that.
    I noticed the following symptoms:
    1) Whine at very low RPM which changes pitch as one accelerates.
    2) When the car is rolling up the incline to my garage in first gear at snail's pace, I can almost feel a VERY slight regular vibration, almost as if driving over vibration strip markings on the road at 3 MPHmaybe 2 per second at 2/3 MPH. My paranoia is suggesting gear teeth meshing just slightly closer to the crown as opposed to the face.
    3) When I'm at 4-5K RPM in fifth (a bit too fast, I know) but take the foot off the accelerator to the point of perfect coasting (where you can go off and on gear without using the clutch) I can feel a discerning vibration cum banging in the shifter, which gets worse when at the bottom right corner of the gate, but gets better when moving the shifter towards the middle about 5-7 millimeters. If the noise and feel is noticeable at "100%" and the window is 5-7 millimeters when in fifth, doing the same in 4th does the same at 10% of the volume with window of movement of 1-2 millimeters. In 3rd, 2nd it is not noticeable and I can't reproduce it in 1st.
    4) When stationery, when the engine is idling with the clutch pressed, there is absolutely NO gearbox noise (as expected), so I'm wondering if the flywheel bearing is thus OK.
    5) When stationery and with the gear in neutral, I release the clutch (no noticeable sound/vibration while engaging/disengaging the clutch), and there is a very faint whirring sound from the gearbox, the SAME whirring sound the car has done since I got it, I'd say normal except that I never heard a "normal" car. There is a slight ticking/tapping sound coming from the clutch bellhouse though. This means that with 1/2 the gearbox rotating, the clutch release bearing, pinion, drop, bevel and mainshaft gearing and bearings must be OK?
    6) If you are in start stop traffic, in 1st, doing 2-3 Mph, then take your foot off the gas so the car "drops" against the engine RPM, I can sometimes hear a metallic "clank" from the gearbox, but ONLY in this situation - Are my layshaft splines going?
    7) All the gears shift as per normal, but when in any gear and moving then the whine starts.
    8) Took the magnetic plug out, just black peach fuzz, nothing large...
    What have I got going on here? I'm REALLY paranoid now and suspecting the mainshaft gear bearing in the oil filter housing being well underway... Economy means the budgets are tight. The cheapest quote for labor I found is GBP 2.5K / USD 5K and I don't even have that budget. Do the bearings on that side self-destruct simultaneously or can they do so separately? Are we talking about something very deep? or does it sound plausible is it the side bearings?
    What size ring-nut(s), what torque do they need to be tightened at, ring-nut tool and other specialized tooling do I need to "get in there", and finally can one "open and pop" these off the side, or is it a "deep" dive in the innards of the GB?
    Got to admit I'm losing the bite of the F'car story, despite coming from Modena in Italy...
    Marco
  2. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    Marco-
    It's a good time to take off the inspection cover in the bottom of the tranny and look inside. Is the noise strictly road speed (varies only as speed increases or decreases) or gear speed (changes pitch or disappears with gear change)? Some gears, not others? You describe it in detail but my attention span is too short. :)
    I have most of a tranny in a crate if you need parts.
  3. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Kind of both... It is most audible in gear and at very low speeds< 30mph. I can only really check it in 1,2 and 3rd gear, as otherwise the engine near stall rumble deafens it. in the 1,2 and 3rd gear, the whine changes from a low tone whine increasing in pitch as the sped picks up. I tried coasting back down and the whine is a lot lower in terms of volume, but changes pitch back down as the car slows in gear.
    In 5th there is a grinding sound when the engine RPM, matches the wheel rpm and speed *eg. the very narrow bnd where you can shift in and out without using the clutch), it is only there in 5th...
    I may come back to you re the parts especially if, once I work up the guts to take it all apart, I find that more than the bearing is shot...
    Marco
  4. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    If you have to take it out, be brave. Keep the manual near at hand, and remember, it's only a transmission, just Italian, therefore overcomplicated, but it's not smarter than you, so you CAN fix it!
  5. Kevinbag
    Kevinbag Karting
    Apr 6, 2007
    57
    Cape Town
    Kevin
    Marco sorry to hear about this problem. Sounds very much the same as what happened to mine. The ring nuts inside work their way loose and many things got trashed inside. Cost me a new gearbox! Have a look at this thread started by me about my gearbox problem "348 gearbox problem" There is a lot of helpful advice there.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #6 No Doubt, Aug 2, 2008
    There's not a budget way out, sadly. Sure, drain the tranny fluid and examine for metal...but don't eat prior to doing this because your stomach might get a bit uneasy if large chunks of bearing race start plopping into your drain bucket.
    On the 2% chance there's no metal in your tranny fluid, pop a cold one and drink hardily. Celebrate. Then turn off your amp and stereo because it was faking you out with a radio whine instead of gear whine!
  7. davem
    davem F1 Veteran
    9,995
    Stepford, Connecticut
    dave m
    Is it possible to do a pre-emptive modification to the ring nuts to prevent this? Just curious
  8. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Loosen the ring nuts, DROWN the ring nut threads in Loctite 222, then re-tighten the ring nuts FT (f*cken tight). :D:D
  9. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    How tight is F***en tight? Have you got a torque setting? Also what size are the ring nuts? I want to go get a spare set before I go at it.
    What does a worn clutch bearing sound like (I assume noise when clutch engaged and thus cannot be causing my problem)?
    My plan is (after draining the gearbox oil)
    1) lift the car on its right side
    2) Put 2 tonne stands under front and rear jacking points and stabilize/block right side wheels
    3) Remove left rear wheel
    4) Remove internal wheel fairing/splash guard
    5) Remove the exhaust manifold
    6) Remove gearbox oil pump housing
    7) Loosen/remove ring/nut(s) on lay and main shafts
    8) Remove bearing brace
    9) Replace bearings
    10) Clean plastic oil filter, check for overall "health" of area
    11) Reassemble in reverse order, drowning the super-cleaned ringnuts in Loctite 222 and tightening them F****ing tight (or whatever the right torque setting is)
    12) Let Loctite dry for specified time
    13) Refill with 80% Redline 75W90NS and 20% 75W90
    Pray and go for a drive looking for the same symptoms as before
    If I get them, then go off and spend $7000 / sell car as scrap - I would have had enough!
    Marco
  10. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,849
    Cape Town,SA
    Jacques
    Welcome Kevin....heard about your gearbox issue.
    Marco, I say this under correction but perhaps would it not be worth trying a differant tranny fluid to see of that quitens the noise at all?
    If there is no noise with the clutch released the release bearing is fine and thats a good thing at least.
  11. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Changed the fluid from a 6 month old 3000 mile Castrol 75W90 to 80:20 Redline 75W90NS and 75W90. The latter has been in for 8 months and had 4000 miles on it (no garage queen here...). It has worked perfectly until about 5 weeks ago when I started noticing the whine, which has got progressively louder... Can't see how the fluid could have caused that...
    Marco
  12. plugzit
    plugzit F1 Veteran
    7,744
    Redondo Beach, CA
    Bruce Bogart
    A whine is usually misaligned gears-in this case maybe caused by the side bearings you're goiing to check-kinda hope so, 'cause if it is, you may be able to get away with a simple (and I use the term loosely) bearing change. I kinda thing that changing those bearings may be a good major service addition. Sounds like you've got the procedure nailed.
  13. fatbillybob
    Aug 10, 2002
    28,538
    socal
    maybe you should make an acurate diagnosis before you panic. Based on your posts i don't really understand what is happening and I am not sure you could make an Fchat diagnosis but you sure could get an fchat guess at possible problems. If you guess wrong it will be expensive so guess right. Nowhere in your post was a mechanic's stethescope used. I could not make a diagnosis on your box without one unless it was a really obvious problem. I have seen owwners fooled by gear whines which were simply out of ajustment shift cables making rattles at specific rpm's. For a DIY'ER like me the cost of that fix is free! So again make the right diagnosis. And if you crack the box open use 271 loctite. I do not know what 222 is. WSM says 242 but IMO that is worhtless. Torque is 150 ft/lbs using a good airtool and very clean shaft threads. If you are going to do this, change the end bearings don't just try to tighten them. If these are truely loose you make have a galled ball or race and the bearing will eat itself soon enough anyway. The box will have to come off the car and it will easily if you pull the clutch pumpkin off. This is a good idea beacuse this way you can remove the clutch shaft to inspect those gears. I know of 5 boxes where these gears have come loose by poor staking of the clutchshaft lockring.
  14. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    I'm handing it over to Rardley's - a great independent. Depending on cost, I'll keep or sell the car and quit the dream...
    Thanks to all. They will let me take pictures so I can post the findings for the good of the brotherhood. The bottom end is USD 1500 and the top end USD 6000 (more if there is serious damage). At the bottom end I'll keep the car, at the top end I'll sell it, cover costs and go get a turbine rating for my pilot's license (got jet, but I want a turboprop twin)...
    Marco
  15. Ricambi America
    Sponsor Owner
    Obviously, I'm hoping it's something simple, cheap, and easy so you can get back on the road an enjoy your car. My gearbox, when it blew, was 2x your 'high number'...
  16. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Thanks,
    FYI. Eurospares has a Mondial t Cabrio box from '90 with 23,000 miles which "drives" for GBP 3750 (3000 for an exchange). He has a CH version from a swiss 348 from '93 (different mountings than the '90 one) for just under GBP 4000.
    I'll go for that before spending 12K US...
    Marco
  17. Ricambi America
    Sponsor Owner
    Marco - Ensure there is some type of warranty on the new/exchange box. Before you install it, open the inspection plate and beat the living daylights out of those ringnuts.
  18. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    There is only a "voluntary" warranty, eg. a few days etc. If I do "go there" then I will ABSOLUTELY take the back plate off it as well as the inspection plate. I want to make sure there is no corrosion as it has been hanging about for 4 years. I will also remove the bearing housings and checking all four bearings quite closely for pitting etc... In fact, if I do go there, good old Mike Lester at Rardley will do a full health check on it before we buy it as he will be doing the work...
    Thanks for the suggestion...
  19. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    #19 ernie, Aug 3, 2008
    Hey Marco,
    Sorry for getting to the party late.
    Time for my nickels worth.
    I seriously suggest that you DO NOT start or drive the car. Again DO NOT start the car. Why? Because it could very well be the oil pump bearing ring nut that has struck, yet again. IF you do not have the clutch disengaged the gears in the transmission rotate. SO unless you are gonna sit in the car with your foot pushing down the clutch the whole time D O N ' T start the car. If that ring nut comes loose it allows the main shaft to wiggles back and forth because all the parts are not held tight = gear whine. If it continues to allow the shaft to move = outer oil pump bearing cage gets destroyed = metal bits from the cage getting into gear box = gear box get ruined = BIG bucks to rebuild it. Fatbillybob and I had argued about the cause of the bearing failure. I was sure it was because of crap bearings, and chubby was sure it was because of a loose ring nut. Fatbillybob was correct. If you are handy with a wrench you can pull the box yourself and save some big time money.
    Here are some threads for you to read about other cars with the same problem:
    http://ferrarichat.com/forum/showthread.php?t=174226
    http://ferrarichat.com/forum/showthread.php?t=157349
    This thread tells you how to take the gear box out yourself. Sorry no pictures for this one :( http://ferrarichat.com/forum/showthread.php?t=124766
    You posted a picture last year http://ferrarichat.com/forum/showthread.php?t=172515 of your bottom inspection plate being off and I saw a pretty good size chip out of one of the gears. I say it's the oil pump bearing failure/ing, due to a loose ring nut. You may get lucky and only have to replace the outer bearings and ring nut, but you really won't know until to pull the gear box. You can have the gear box out of the car in a Saturday.
    If you wanna talk about removing the gear box, drop me a private message with your phone number and I'll call you. Yes I know your are in the UK, and yes I'll still call you...........if you want.
    But what ever you do DON'T start the car! :D
  20. ernie
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Mine being one of them. ;)
  21. Ricambi America
    Sponsor Owner
    And mine.
  22. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Thanks to all...
    I took it to Rardley's and after seeing them rebuilding a 512 Boxer engine, putting in a rebuilt Daytona V12, and 2 magnificent 348's, a spider and a TS, I begged him to help me remain addicted. He confirmed the whine is the main shaft bearing, but as the car was driving and shifting well, he suggested we should be OK with a bearing replacement. I brought him 2 new SKF bearings, (the superseded ones) and he was impressed I paid only GBP 38.00 (USD 75) for each of them.
    What I am surprised about, is the fact that I have brought this "whine" to the attention of Verdi's (9 months ago) and QV-London (3 weeks ago), both telling me it was nothing... OK it has got worse as we went along, but I'm on my first Ferrari, they must have seen a bunch... Maybe they hoped that a bearing replacement would turn into a box rebuild...
    I was shocked to find out my '89 Mondial t with 25,000 mi on the clock was valued at "only" GBP 10K USD 20K for a trade-in. I was considering the TS for a second, but don't fer that I want to upgrade my repair cost from GBP 3000 / USD 6000 to replacing the car for another GBP 15K / USD 30K.
    I was disappointed my car devalued over GBP 9000 / USD 18000 over 12 months and 8000 miles... even taking the dealer markup out of the equation, that's quite the drop...
    I'll let you all know what we find as things go on... I'll keep pictures of the bearings for the collective knowledge...
    Marco
  23. fatbillybob
    Aug 10, 2002
    28,538
    socal
    you are going to need all FOUR bearing at a minimum...don't be cheap! It will cost you later. Once you got the box together I would prusian blue the main bevel gear to insure proper gear mating. Did anyone use a stehescope or just wack the throttle?
  24. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    NEWS - part good, part bad...
    The Main shaft ringnut was loose, but as Mike put it, is was only a little loose and was caught in time. He has already changed the bearings. The layshaft one was fine, and he tightened it all up. So we were well on the way to a blow-up, but it was caught in time. There was no damage at all on the main/lay shafts, or gears.
    The part that is bad, is that the pinion is worn... n in his words it was due to wear and tear... The car did a verifiable 26K miles, with me in it for the past 9K. No childish driving or burn-outs on my side... What can it have been, the dreaded ring-nut on the pinion loosening up too?
    He suggested the looseness in the box (occasional clank when taking the foot off the accelerator when at snail's pace in 1st) is due to the play between the clutch shaft and the pinion gear.
    I can't find a pinion gear anywhere for the life of me, any ideas?
    He also suggested that changing one of those, will wind up being "cost of exchange box territory" due to the set-up costs...
    FU*K me, but everytime something is fixed something else pops up.... I also noticed thewire going from the fuse box area to the AC system is overheating and browned the plastic on the connector...
    The market is collapsing - I wonder if setting fire to it is a cheap way out...
    Marco
  25. Ricambi America
    Sponsor Owner
    #25 Ricambi America, Aug 5, 2008
    Marco -
    I had the same 'thunk' in my box too. I had the old style thick-splined shaft, and there was significant wear between the shaft at the gear. See attached picture. I opted to repair it about 18 months ago -- and it held fine, until the rest of the transmission blew.
    My new transmission has the later (F355 style) thin splines, and I'm confident it was a vastly improved design from Ferrari.
