Cleaning the aluminum suspension components
Discussion in '360/430' started by CoreyNJ, Apr 14, 2025.
  1. CoreyNJ
    CoreyNJ Formula 3
    2,373
    New Jersey Shore
    So what do you guys use to make them look brand new again? How do you remove any dirt and oxidation? I have been googling and seems there are specific products out there (that are acidic) and then there is using WD40 and a scrub pad. I really want to avoid anything that can damage the car, so avoiding acid-based solutions or even vinegar w/water seems like a good rule of thumb.
    What are you guys using when detailing underneath the car?
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,988
    East Bay, California
    Joe
    I think anything aluminum specific has some sort of acid to it, otherwise it just won't get the stains out. Best bet is engine cleaner I would imagine for just a quick clean. The aluminum brighteners are not terrible, but you can't let them sit. Basically, spray on, brush immediately, and then rinse off quickly within a few minutes. Not harmful enough to damage anything that way and no worse than getting brake clean on parts if it's sitting for a bit.
    KC360 FL likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,686
    Central NJ
    Dominick
    I would look into
    Simple Green Extreme Aircraft and Precision Cleaner but WD40 with elbow grease works well too
    Jbar2002 likes this.
  4. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,583
    San Jose
    dc
    I use simple green. There are companies that can clean the parts using dry ice machines.
    colorfull likes this.
  5. GogglesPisano
    2,988
    Joe
    I can't wait until this technology becomes cheap. Need a Central Machinery dry ice blaster :D
    colorfull and MaranelloMark like this.
  6. MaranelloMark
    MaranelloMark Formula Junior
    429
    Bay Area, CA
    Has anyone used simple green in an ultrasonic bath? I recently tried cleaning a Porsche (Bosch) throttle-body in an U/S bath with recommended cleaning agent for aluminum and the TB became dark almost like it oxidized. I was pretty bummed and it took me days of work with Emery cloth and buffing wheels to get it somewhat back to the way it was before I put it in. <-regrets. :(
  7. GogglesPisano
    2,988
    Joe
    I've had similar effects with similar degreasers in ultrasonic baths. You really have to be picky when selecting ultrasonic cleaning agents and aluminum. I don't know the chemistry behind it. If the part is off, I like using a medium glass bead on it if it has no components I can damage (rubber/plastic/etc). I've also used. Star Brite aluminum cleaner on bare parts or areas where I'm not worried about it getting in touch with delicate components.
    MaranelloMark likes this.
  8. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,583
    San Jose
    dc
    The machines are fairly reasonable as well as the dry ice. It is the dry/clean air at 100+ PSI @ 150 CFM that makes it pricey. The air compressor is like 25hp multi-phase power.
    GogglesPisano and MaranelloMark like this.
  9. MaranelloMark
    429
    Bay Area, CA
    Yeah, a bead-blast setup is on my shopping list. And soon. I just need to find a place for it. Or, leave it outside, covered. Like a cheap disposable Harbor Freight tool. :D The TB has some very small ports, but they are probably easily covered to avoid media/debris getting in there.
  10. MaranelloMark
    429
    Bay Area, CA
    Yeah, that's what I noticed when I started looking at the dry ice systems. It's not easy (or cheap) to find high CFM+High Pressure air compressors. It's all about the specs on those and easy to be fooled if you don't read closely.
  11. CoreyNJ
    CoreyNJ Formula 3
    2,373
    New Jersey Shore
    Ok back to cheaper solutions than dry ice. Has anyone tried purple power aluminum brightener on the suspension components since they are cast aluminum and not polished or should I just stick with simple green aircraft or wd40?
  12. MaranelloMark
    429
    Bay Area, CA
    And keep us posted on the results!
    Willl and colorfull like this.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,918
    Isle of man- uk
    Just be sure you dont use caustic soda- goes off like a bomb
  14. CoreyNJ
    CoreyNJ Formula 3
    2,373
    New Jersey Shore
    Will do. I may get to it this Saturday or next Saturday depending on when it shows up.
    jerbear27 likes this.
  15. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    I use a green pad with a vacuum cleaner. I purchased my 2002 7 years ago, so the aluminum was quite dirty. I would remove wheels each week if I drove more than 40 miles, and for therapy! Now I don't drive it as often because I purchased an FF. Once cleaned, it's easy and quick to make it look great.
  16. MaranelloMark
    429
    Bay Area, CA
    I just bought a Vevor bead blast setup from Amazon and several different sizes of media. Going to try that and post back here for everyone. It's pretty cheap on Amazon, so I figure if I use it for the summer and it rusts away by next year, it still paid for itself.
  17. GogglesPisano
    2,988
    Joe
    Word of caution about using any media blaster on parts which are on the vehicle...the media goes everywhere when not enclosed in a cabinet. It will fly and embed in almost any greased joint or sticky surface.
    flash32 likes this.
  18. MaranelloMark
    429
    Bay Area, CA
    For sure. I couldn't imagine blasting away inside the engine bay. It is a blast cabinet.
    GogglesPisano likes this.
  19. kestrou
    kestrou Formula 3
    1,440
    Danville, IL
    Kevin E. Stroud
    Gang,
    I have more than a little experience at bead blasting and oily aluminum (Harley big twin cylinder jugs).
    Keep in mind the oil is seeping into the pores of the aluminum - if you’re bead blasting (yes, in a cabinet) enough to “get the oil off”, you’re taking off a few mils of metal.
    On some stuff that doesn’t matter, on other stuff it does - so BE CAREFUL what you blast. ;)
    Kevin
    MaranelloMark and GogglesPisano like this.
  20. MaranelloMark
    429
    Bay Area, CA
    Yep. I assume we are all talking about cosmetic purposes. Degreasers to degrease and bead-blasting to clean up oxidation and deeper 'stains' on (removable) exterior surfaces (suspension components) as OP started with.
  21. CoreyNJ
    CoreyNJ Formula 3
    2,373
    New Jersey Shore
    OK, Here is only 5 minutes with the Simple Green Aircraft and a grey Scotch-Brite. I will do some more scrubbing after work today, as you can see in the results pic there are some areas which still need more cleaning; I just need to figure out a better way to rinse the area I'm working on with water without getting it all over the lift (i.e pickup a cheap oil change tray to put under the suspension). Oh, and yes, this is OCD. I am also currently working on treating and refinishing all the undertray bolts/washers one at a time.
    Before...
    and after 5 minutes...
  22. CoreyNJ
    CoreyNJ Formula 3
    2,373
    New Jersey Shore
    And here is about 5 minutes more of cleaning each side. I think it's good enough... My wife walked away, head shaking, when she asked what I was doing, and I said I was cleaning my suspension...
    67bmer, MaranelloMark, Willl and 5 others like this.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,686
    Central NJ
    Dominick
    Looks great !
    Mel Spillman likes this.
