cleaning 458 engine area between the two red valve covers? | FerrariChat
Discussion in '458 Italia/488/F8' started by Jason B, Jun 8, 2020.
  1. Jason B
    Jason B Formula Junior
    Apr 7, 2006
    397
    Hbg, PA
    What's the best way to clean this off in the middle? Someone once mentioned to me ball polishing? Grabbed this pic off of a youtube video where a guy spent a long time cleaning the inside but didn't touch this area. See how it looks splotchy? Many 458's I see are like this in the middle area and a friend of mine wants to clean it somehow.
  2. 3POINT8
    3POINT8 F1 Rookie
    4,432
    i've always just used soap and water so far so good
  3. RayJohns
    RayJohns F1 Veteran
    7,402
    West Coast
    Ray
    You can use a tooth brush and either Bon Ami or Bar Keepers friend. Bar Keepers has oxalic acid in it, which usually cleans up aluminum really well.
    Soap and water also should work fine.
    Ray
  4. flifer
    flifer Karting
    Mar 3, 2016
    160
    Miami
    I know it sounds goofy but many people on this forum have had success with scrubbing bubbles bathroom cleaner. I've been wanting to try that method as it seems pretty easy and the before/afters posted on the forum looked pretty impressive.
  5. padebus
    padebus Karting
    Mar 22, 2014
    68
    try the dry ice process, cleans to factory look and is not abresive .
    Gesendet von iPad mit Tapatalk
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Spray the area with scrubbing bubbles. Let it do its job for about 10 minutes, then wipe it down clean and dry.
    Take a before and after photos and kindly share results. You will be amazed.
    Need4Spd likes this.
  7. flifer
    flifer Karting
    Mar 3, 2016
    160
    Miami
    You just wipe dry without rinsing?
  8. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    You can rinse but if it's only a small area you are trying to clean you can just wipe it dry.
    Then spray it with Griots Garage engine bay dressing.
    It will look brand new.
