Clean512 ..360 coupe project | Page 11 | FerrariChat
Discussion in '360/430' started by clean512, Jun 3, 2020.
  1. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    What part for air bag light ??
  2. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    What part for air bag light randy .. don't get the ?
    The hub came with a resistor and there is no light on.
  3. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    Completely deleted air bag ecu and passenger side air bag and air bag cables, airbag light is on.
    Would like to find out how to turn off airbag light ?
    No need for airbags strap in harnesses never going to touch airbags in a collision any way.
    Factory roll bar and factory 4 point harnesses and welded all mounting brackets supplied with roll bar .
  4. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    Oh you did alot. I'll begging that soon.baby steps.
  5. duck.co.za
    duck.co.za Formula Junior
    Jan 9, 2007
    980
    Cape Town South Afri
    Dave
    360Trev needs to confirm , but that is one of the things he can delete completely in the ECU I think . One of the many options and one I want to do .
    clean512 and RANDY6005 like this.
  6. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    I should have decided that or talked about that with trev when he did my tune
    duck.co.za likes this.
  7. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    So my best friend who does amazing things with his company kenmontes.com also owns two other companies phase5 and agency6.
    On too the cool stuff I made the mold for the tranny fliter that you need to usually remove the bumper to gain access. Yes I have seen just a hole with a groment. Well a full access carbon fiber sheet sounds cooler. He will make more since he kept my part for the mold.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Caphill, duck.co.za and RANDY6005 like this.
  8. duck.co.za
    Jan 9, 2007
    980
    Dave
    Vacuum bagging awesome
  9. AndreB
    AndreB Karting
    Jun 8, 2018
    237
    HTX
    Ndr
    Ok that is cool. How many more parts can he make :)
  10. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    Well my friend has a fullcnc shop and pretty much has it all. I worked for him back in the day and we are very much similar the way we think.
    AndreB likes this.
  11. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,252
    Gibraltar
    360trev
    The airbag delete is not related to the Engine Management ecu. Its related to the Dashboard ecu.
    Yes its possible to delete it software (its just software) in the dashpod itself but actually its far easier to simply put in-line a resistor that matches the resistance of the normal airbag's and the lights will go out (this way it will illuminate in the usual way before going out).
    *or*
    ... simply remove all the airbag wiring, airbag ecu and cut the power track on the instrument pod with a sharp stanley knife. Obviously the light will never illuminate then but it won't annoy you! Depends on if you need the light to come on and go off for regulations crap or not.
    remfrs and duck.co.za like this.
  12. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    That is what I did trev with a resitor and works just fine.
  13. duck.co.za
    Jan 9, 2007
    980
    Dave
    The obvious question is can we remove the entire airbag system for weight saving yet still get the dash light to work as it should ?
  14. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    But what is the point of that. If you remove something completely why would you even want the light.
  15. duck.co.za
    Jan 9, 2007
    980
    Dave
    Because you want the light to work as it should . Come on and then go off , just me being pedantic .
  16. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,252
    Gibraltar
    360trev
    Even without resorting to modifying the firmware in the dash you can do this quite easily..
    Search on ebay something like LM555 Timer Monostable (One-Shot).
  17. duck.co.za
    Jan 9, 2007
    980
    Dave
    Thank you
  18. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
  19. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    Wheel specs finally got back to me as I put my build order on my new wheels.maybe 4 more weeks of waiting.
  20. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    Did you finish the brake setup?
    Sent from my SM-G996U1 using Tapatalk
  21. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    I'm gonna start soon. Been working on the door panels
  22. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
  23. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    duck.co.za and 360trev like this.
  24. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
    RANDY6005, duck.co.za and 360trev like this.
  25. clean512
    clean512 Formula 3
    2,026
    Josh @jtcarprojects
