Clack, Clack noise on cold startup | Page 2 | FerrariChat
Discussion in 'Mondial' started by 88MONDIAL, Nov 18, 2016.
  1. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    Here is another video. Can hear the crackling sound better when bay closed. Any thoughts?
  2. ronfrohock
    ronfrohock F1 Rookie
    3,935
    MA
    Ron Frohock
    I’m guessing ac belt.
    Cadillacbart likes this.
  3. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Change the A/C belt.
  4. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    simple test is to carefully spray some belt dressing on that AC belt, noise goes away it confirms thats the problem and you go from there. Can also perform that test on H2O belt while you are in there. Belt dressing is not a long term answer but will quickly put the mind at ease.
  6. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    #31 Kay3.2, Mar 24, 2021
    Thank you and will do. Belt dressing suggestions? WD 40 autmoitve range?
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    If you are asking if you'll find it near the WD40, yes in that general area of the parts store. Simple spray can probably about $10.
    Kay3.2 likes this.
  8. moysiuan
    moysiuan F1 Rookie
    3,644
    Canada
    As noted, you are best to just use water and spray on the belts to see if that quiets the noise. If so, change the belt, or adjust the tension. Belts do not appreciate being coated in oil and solvents/carriers.
  9. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    Thank you!
  10. djs308
    djs308 Formula 3
    1,100
    Long Island, NY
    David S.
    My engine was making a very similar sound to this. Wasn't able to upload my movie file though...
    Today, being a warmer day than the last time I drove it, of course the engine started just fine—no belt noise at all!! I brought my car in to my mechanic anyway. He didn't even look at it. Told me that it might very well be that the issue goes away when the temps go up, so I may be good for the next few months.
    However, he advised me to change the AC belt to properly take care of it, rather than adjust it again (which he had done in December), and also change the other 2 belts at the same time. According to my records, I had them all changed out 4 years ago, so that's probably in the range for replacement. I now have some belts on order.
    Kay3.2 likes this.
  11. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    To access the belt for a 308 and Mondial you just need to take the Wheel and then the fender liner off correct?
  12. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    yes. on the Mondial its a little easier because they made it into a couple more manageable pieces.
  13. spicedriver
    Feb 1, 2011
    3,859
    All around better designed car.
    moysiuan likes this.
  14. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    100% and more people can enjoy it at once ;)
  15. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    329
    My belt issue a few years ago was a slap/snap noise.
    Your noise on the video sounds serious to me. It is not similar to my belt noise. Sorry, but that’s what I think. SG
  16. Jeka
    Jeka Formula 3
    1,176
    Rotterdam
    Johan
    It's similar to my belt noise. It ticks more when cold, the number of 'ticks' decrease first and stops completely after 1 or two minutes. Just spray some water or WD40 when you hear the sound, when it disappears just change the belt(s). If not, look further.
  17. DavidB
    DavidB Rookie
    Mar 14, 2009
    14
    David Barnes
    I can tell you for sure that your problem is dry belts.
    Just the little ones not the timing belt.
    You can do it yourself in an hour.
    Took me a while to diagnose this in my car because it was intermittent on start up
    however just by luck one day at the garage it happened and the mechanic was
    right there and job done.
    DavidB 1988 Mondial 3.2 Sydney Australia.
  18. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    The noise is gone. Was a loose bearing that needed changing. Discovered during belt change job. See video
  19. Kay3.2
    Kay3.2 Rookie
    Mar 22, 2021
    17
    Kay
    My noise is gone since changing out a bearings during a belt change. See video
  20. 83Mondialqv
    83Mondialqv Formula Junior
    May 18, 2021
    326
    New York
    Vito L
  21. 83Mondialqv
    May 18, 2021
    326
    New York
    Vito L
    My 83 qv did the same thing and it was the AC pulley all I did was remove the belt.
    ronfrohock likes this.
