cibe headlights | FerrariChat
cibe headlights
Discussion in 'Boxers/TR/M' started by ago car nut, Feb 1, 2011.
  1. ago car nut
    ago car nut F1 Veteran
    5,266
    Madison Ohio
    David A.
    Will the Cibe 5 3/4" headlights fit better than Hella lights? The Hella lights project out about a 1/2"and have a flat face. The Cibe lights look more like Stock curved light. Any body have any experience with Cibe?
    Ago
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,780
    Always been a big fan of Cibie.
  3. notenuphstuph
    notenuphstuph Formula Junior
    Apr 29, 2008
    273
    Lossiemouth,Scotland
    Ivor Hewjun
    + 1;)
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,116
    Mel
    But... do they fit ? Any foto's around ?
  5. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    #5 JIMBO, Feb 11, 2011
    I replaced the headlight lenses with Cibie units, the bulbs with Osram HIRs and had a custom wiring harness with relays built for all above to get full power to the lights and take any significant electrical draw away from the headlight stalk.
    I ran this setup for 6 months and then upgraded to 90 watt bulbs. I own the night. I akso upgraded the driving/fog lights at the same time.
  6. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    Jimbo could you please post a schematic/wiring diagram and maybe a parts list showing how and where you spliced in the new headlight relays.
    Not bright Me
  7. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Kerry:
    I would if I could. I got the entire harness custom made from Daniel Stern who got it made by Susquehanna Motorsports. The bulbs were purchased through candlepower inc.
    Daniel Stern's website is very informative and all the parts were superior quality. The improvement in headlight output is amazing. It took a few hours to install neatly in the 512TR. All pieces fit without modification (hacking) of the original harness.
    Click here: Susquehanna MotorSports - High Performance Vehicle Lighting and Competition Accessories
    http://www.candlepowerinc.com
    www.danielsternlighting.com
  8. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Susquehanna:
    www.rallylights.com
    I'll try to get a parts list together this weekend. The Cibie lenses are no longer available apparently.
  9. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Excellent site........Great info and appears to have very fair pricing. Thanks for the effort Jimbo!!
    Seeing the light Me
  10. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    #10 JIMBO, Feb 12, 2011
  11. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    So with just a phone call to Daniel with a detailed desciption of what one wants and where....he can provide a complete "add-in" wiring harness to install? If so, that's great!
    Not wiring Me
  12. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Exactly. He is very wise in the ways of lighting, but sometimes hard to get hold of. By contrast, Candlepower and Susquehanna Motorsports are there whenever you need and stand behind their products 100%.
    Make sure they understand you have a US version Ferrari, as the Euro wiring connectors are different. The harness is custom made to plug into your existing harness with no splicing, hacking, etc and the connectors are way better than OEM parts. The harness is heavier gauge wire and the whole modification is undetectable when installed (except you can actually see where you are going at night). It also saves the headlight stalk electricals, as minimal current flows through it after installation.
    There is a lot of good info on Daniel Stern's site regarding the difference between HID and HIR lighting options.
  13. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    I consider Daniel Stern the "Dave Helms" of lighting.
  14. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
    Looks like another fun project to add on my list of things to do for the TR.
  15. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    I finally found the info from March 2009:
    The wiring harness from Susquehanna Motor Sports (through Daniel Stern) was $168. Totally worth the $$$. It is beautifully constructed, custom for your vehicle, includes relays and fuses and is a plug-in with no cutting.
    The lenses were Cibie CSR (Complex Surface Reflector) units that fit in the original hi and lo beam housings with no fuss. They supposedly "focus" the light reflected to the side back in front of the car. They were expensive, like ? $55 each (x 4)
    The fog lights were H3 Osram Night Breaker +90 Ultra High output 55w. They plug in without modification (the fog lights in the 512TR are already on a relay). $53.61 for both (shipped).
    The Hi beams are Narva Rangefinder (HIR) H1 +50 Super High Output 55w. $31.50 for 2 bulbs.
    The Lo (dipped) beams are Osram Nightbreaker (HIR) Hi +90 Ultra High Output 55w. $41.18 for 2 bulbs.
    My headlights are crazy bright, way, way bettter than stock GE bulbs. These replacements are HIR (Halogen Infrared Reflector) technology, and NOT "Xenon" (more properly HID - High Intensity Discharge), which would require extensive rewiring and fabrication for not much more output.
    I hope this helps. I do not believe the Cibie CSR lenses are available anymore - there is an improved replacement.
  16. Testarossa1
    Testarossa1 Karting
    Jun 15, 2007
    229
    Clive
    +1
    Great thread
  17. Jrrrrr
    Jrrrrr Rookie
    Jan 11, 2020
    3
    10 years later Jim was there any adverse affects to the Cibie CSR using 90 watt Bulb?
  18. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    Flawless performance, now over 67,000 miles.
  19. Jrrrrr
    Jrrrrr Rookie
    Jan 11, 2020
    3
    Jim are your lights are composit body with glass lens Correct?
    Does your lights have a 55 watt Max label?
    And 90 Watt bulb didn't hurt it Correct?
    Example of label in pic
  20. JIMBO
    JIMBO Formula 3
    1,321
    Bradenton, Florida
    Jim DeRespino
    That was 12 years ago. I haven't got a clue. Sorry.
  21. Jrrrrr
    Jrrrrr Rookie
    Jan 11, 2020
    3
    Ok, Thank you for answering my Post and getting back to me
    Have a Good Weekend
  22. ago car nut
    5,266
    Madison Ohio
    David A.
    55w . max would be to keep it legal in USA I presume?
  23. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    90 W in germany is illegal for street use, may be for boats ok
    but 35 more W means more than 60% amps, so need stronger fuse and may be also then stronger wires
    and 90 W makes a lot of heat, so not sure if the reflector will last long before get colored?
  24. ago car nut
    5,266
    Madison Ohio
    David A.
    Run the higher wattage bulbs direct from battery with heavy wire. Switch heavy wire with extra relays.
