check engine light and changing clutch | FerrariChat
Discussion in '360/430' started by Epwerkz, Aug 20, 2011.
  1. Epwerkz
    Epwerkz Formula Junior
    Oct 12, 2010
    275
    Jakarta,Indonesia
    FXL
    #1 Epwerkz, Aug 20, 2011
    just drove back from family dinner and suddenly there is a check engine lights pop out.
    Im not sure about it..is it engine oil or something else?
    as for the clutch,how do we know if the clutch is almost out?took the car to the ferrari authorize dealer and they told me that my clutch left 20%..and I asked them,how do u check ??they told me " we have the tools like barometer to check the thickness of the clutch"..Is that true??And lastly I found out when i drove the car quite hard last weekend for cruizing...the gear suddenly jumps to N..is that the symphtom???
    please advice guys
    thnx
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,439
    Charleston, SC
    Curt
    You can go to a mechanic with an ODB2 reader and have them plug it into the connector under the steering wheel and see what "code" comes up. This will hint at what may be what caused your check engine light to come on. I have a manual so I'll leave the transmission question to the guys with an F1.. but there is a sensor by the clutch on F1 cars that can tell how worn the clutch is.. I've heard when this gets dirty it can prompt a low clutch reading. A worn clutch can cause the car to pop into neutral.. An SD2 reader at the ferrari dealer can definitively tell you the cause of the light.. good luck!
  3. Epwerkz
    Oct 12, 2010
    275
    Jakarta,Indonesia
    FXL
    thnx again for the inputs.definately will bring to the dealer asap
  4. Epwerkz
    Oct 12, 2010
    275
    Jakarta,Indonesia
    FXL
    guys,
    is that true that if we change the F1 Clutch and we have to reset and re allign ???
  5. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    Was that after we met up at Mulia?
  6. Epwerkz
    Oct 12, 2010
    275
    Jakarta,Indonesia
    FXL
    Rob, Yes it is..pop out while driving back home...i talked to the local dealer and they asked me " the check engine pop out after u fill up the fuel?" and i told him " 1 day before"...might go there tomorow morning
  7. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    Yeah after the clutch is changed you have to re adjust the software in the car that handles the engagement of the clutch.
