430 - Cheapest odb reader that can read clutch life? | Page 5 | FerrariChat
430 Cheapest odb reader that can read clutch life?
Discussion in '360/430' started by goto35march, Apr 4, 2020.
  1. jag-oo-r
    jag-oo-r Formula Junior
    423
    '06 F430 Spider.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    Are you using the 131e non ev08 selection ?
    Sent from my moto g(7) using Tapatalk
  3. jag-oo-r
    423
    Yes, correct.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    All the number you show here I believe look healthy .. gear engagement numbers ( can't see 5th or 6th) look good ..pump on is around five percent ..
    I think the decimals and signs are off for the two clutch wear figures ..one is the wear ..42 percent and the other is the clutch index which seems low but that is a good thing ..should be a little over 3000 but over 4000 is bad
    I am guessing on the numbers decimals and sign and taking a leap on the last two ..just thinking it is donating the right numbers wrongly
  5. Ferrari8403
    Ferrari8403 Rookie
    Dec 4, 2015
    16
    The Nederlands
    With great interest I have been following this topic, so much it convinced me to buy the AP200. Today I have received it and immediately connect the Bluetooth scanner to my 06 F430. After the initial connection I had some struggles with connecting the scanner to my iPhone, but all that is under control now.
    I get all the data as mentioned in this topic, but there is one thing I don't understand yet. On the Live data the 'Clutch wear index (percent)’ it shows -1.880 % with a range between: -2 and 0. I assume a percentage should normally be between 0 and 100.
    Funny enough when using the formula (with the 5.6) it returns the correct same percentage as I have received from my dealer. No big problem, but can anyone help me with this issue because I can’t update the range to 0 - 100
  6. CoreyNJ
    CoreyNJ Formula 3
    2,023
    New Jersey Shore
    I have the AP200 and my clutch wear is listed as 0%. I have to use the 5.6 formula manually. My car is a 2009 so I’m guessing the AP200 is getting an error reading it so it just defaults to 0.
  7. vr4henry
    vr4henry Karting
    Jan 21, 2019
    56
    Henry
    Does anyone know which (if any?) of these tools can do a Steering angle reset on a 430? I tried a foxwell 624 or something (new one in 2021) but it didn’t have any reset functions from what I could tell. (I did update it).
    Thanks!
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    It is listed for a x431 ...
  9. vr4henry
    vr4henry Karting
    Jan 21, 2019
    56
    Henry
    Yikes. Those aren’t cheap. I did find a different Foxwell (630Plus) that also specifically lists SAS functionality versus the one I originally ordered. For $100 I’ll try it and report back, if not an x431 might be in my future. Thanks!
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    The mini pro can sometimes be had for around 600 ..not cheap but still reasonable
    If you post where you live ..city and state ..maybe someone who has one will reset it for you
  11. Ray Smith
    Ray Smith Formula Junior
    851
    Costa Mesa, CA
    Raymond Smith
    I have the X-431 Torque from Launch Tech USA in Ontario, CA. Price was $1,400.
    I have used it to flush and bleed the F1 systems (there are two bleed valves) and flush and bleed the brakes.
    It reads clutch wear and clutch PIS.
    They have a newer model model called the X-431 Throttle but I do not believe it does more for a 430 that the Torque.
    Ray
  12. vr4henry
    vr4henry Karting
    Jan 21, 2019
    56
    Henry
    Just closing loop on the steering angle reset... the Foxwell 630plus did in fact work. So for $120 not bad since I didn't need other stuff right now.
    flash32 likes this.
  13. CoreyNJ
    CoreyNJ Formula 3
    2,023
    New Jersey Shore
    Does it do any other ferrari specific functions like checking clutch usage or F1 bleed/relearn?
  14. TomNbk
    TomNbk Rookie
    Apr 13, 2021
    6
    Just ordered the AP200 for my 360.. keen to keep an eye on clutch wear and the fact it can fault read the entire 360 is a bonus!
  15. vr4henry
    vr4henry Karting
    Jan 21, 2019
    56
    Henry
    Only other advertised bits were ABS bleeding but I didn’t verify. No Clutch or F1 as far as I could tell.
  16. CoreyNJ
    CoreyNJ Formula 3
    2,023
    New Jersey Shore
    Just curious, why did you need to set the steering angle? Did you tighten up your steering knuckle under the dash?
  17. vr4henry
    vr4henry Karting
    Jan 21, 2019
    56
    Henry
    Yep! That fixed up a 1/8” of steering play I had but triggered the CST error
  18. dom1172
    dom1172 Karting
    Mar 26, 2005
    140
    Sarasota, FL
    Dom
    What was the ultimate verdict on this? Seems like the AP200 can do MOST of what the x431 does but at a better price point? Thanks for the guidance…
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    For a reader yes ..but if you want to do functions like bleed , self learning , activation ..probably the best buy is the launch thinkdiag
    dom1172 likes this.
  20. dom1172
    dom1172 Karting
    Mar 26, 2005
    140
    Sarasota, FL
    Dom
    Hadn’t heard of that one, thanks!
  21. Mario Andretti
    Mario Andretti Formula 3
    Aug 9, 2020
    1,385
    Boston
    For 50 bucks ap200 is tremendous value.. it gives you the clutch wear directly in percentage now with latest firmware... read it in 3 min.
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,669
    Central NJ
    Dominick
    #123 flash32, Sep 16, 2021
    So in summary
    Reader ap200
    Bi directional thinkdiag
    Pro level entry level . X431 mini pro for coding modules
    brogenville likes this.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    How does this ... "normal" Launch X431 compare to the $800-900 Launch X431 Pro / Pro Mini?
    Latter is significantly more expensive. Can that cheaper version also do all the relearn / bleed / activation / etc. stuff? Anyone have any experience?
  24. Mario Andretti
    Aug 9, 2020
    1,385
    Boston
    I would also like to know the answer on the question above... thanks
