430 - Cheapest odb reader that can read clutch life? | Page 2 | FerrariChat
430 Cheapest odb reader that can read clutch life?
Discussion in '360/430' started by goto35march, Apr 4, 2020.
  1. MKTViper
    MKTViper Karting
    205
    Swan Point MD
    If this really does read clutch life plus a plethora of other codes it'd be a "must have". Even the additional $16 to add my MB might be worth it since I wrench that car too.
    Just to be clear, we're talking about the AP200, not the MK808TS. Both are advertised in the eBay link.
    A followup question... what the cheapest DIY device to actually set the PIS? Launch X431 or is there something even more fundamental? I really only need to read clutch life, adj PIS and (maybe) drain F-1 fluid. If we're talking $150-200 range worth it for me.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,679
    Central NJ
    Dominick
    The least expensive solution is the x431 pro mini which is around 400 450
    Sent from my moto g(7) using Tapatalk
    Skidkid likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,679
    Central NJ
    Dominick
    There is a newer device called thinkdiag that costs 120 get one free brand for one year .. it may do all the same functions as the pro minii but after one year I think you can't use it .. where I believe the pro mini just won't allow updates but still can be used
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I e mailed them to ask if it measured clutch wear, could not pin them down to confirm. On the 808 the. updates are mega money. Not convinced unless someone can confirm for sure
  5. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    The x431 proX will not only read the clutch but allow you to write a new PIS value, allow you to recalibrate the F1 actuator, bleed brakes by each corner, bleed F1 pump, and see other dealer-level functions. Cost is $330 w/ Bluetooth OBD2 adapter and 1 year updates.
    Install is easy and works well on a $42 Amazon refurbished Fire8HD
    Not to mention it comes with access to just about every other car manufacturer known to man kind.
    Flea7 and Apollo 11 like this.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    The x431 mini pro sells for £623 in the uk, is that the same one ?
  7. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Not sure about the mini. If it’s the same software I would imagine so but I don’t know if it is
  8. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Yes. Launch mini does all of those functions.
    Kevin
  9. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,441
    Taxing Jersey
    what is cheapest for manual cars?
  10. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    $330 isn’t cheap enough to have near dealer level diagnostic? It does a lot more than F1 gearbox and clutch. You can log whatever sensor you want live and save it for later viewing, correctly bleed your brakes, check engine management codes, etc.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Out of interest, why do you need a scanner to bleed brakes.
  12. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    If you want to bleed the entire system including ABS.
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Never tried on the 430 and my old toyota is not that high tec. Something new learned
  14. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Just about any car with abs needs the abs pump activated to 100% bleed the brake system. There are creative ways to do this without a diagnostic tool but it varies from manufacturer to another and with the x431 you can just tap a button to turn pump on and off.
  15. CoreyNJ
    CoreyNJ Formula 3
    2,027
    New Jersey Shore
    Well. The AP200 got delivered early.
    I plugged it in and started the car in the garage, but I didn’t drive it. On my 2009 430 it reads 0 for clutch usage if I choose 430 (F131E) and N/A if u use 430 EV08. Not sure which is the right one for my car but either way I know it shouldn’t be 0 unless I have to drive the car for it to get a read. I only started it up. Anyone have an idea what I should be doing so I can get a clutch read?
    See pics...
  16. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    I don't know the answer to this, but is the 430 different from the 360 with regard to determining clutch wear?
    I didn't think there was any device that actually gave the percent wear. I thought it was necessary to derive the wear utilizing the CCP values and a formula? (Different formula for 360 and 430)
    Kevin
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,679
    Central NJ
    Dominick
    Corey
    Take more screen prints and post here ..those closed position ..new closed position ...etc and we probably can get you an answer
  18. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Exactly. That is assuming the CCP New was set correctly the last time the clutch was changed.
    Kevin
  19. CoreyNJ
    CoreyNJ Formula 3
    2,027
    New Jersey Shore
    Not sure what you mean I should do here. Can you explain?
    As for the value being set the last time the clutch was changed. I’m not sure if the car has had a clutch done(it is low mileage car) but when it was read using a real ferrari computer about a month ago it said about 20% used.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,679
    Central NJ
    Dominick
    Find something that looks like this and take a screen print and post here Image Unavailable, Please Login
  21. CoreyNJ
    CoreyNJ Formula 3
    2,027
    New Jersey Shore
    does the car need to be running to get this "live" data or can I simply leave the key in the on position?
    Thanks,
    Corey
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,679
    Central NJ
    Dominick
    Key on should be fine for those specific.. but of course other live data like rpm , air flow etc
  23. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    If the car hasn't had a clutch change, then the CCP values will be accurate. Thus, you will be able to derive clutch wear from these parameters.
    Kevin
    G4200cc likes this.
  24. CoreyNJ
    CoreyNJ Formula 3
    2,027
    New Jersey Shore
    OK, I have attached a screen shots. The interesting part is that there are multiple 430's and not knowing which one to use I took a guess at using 430 (F131E) and 430 EV08 (F131E EV08), hoping the second one is for 2008 or newer since we know the software is different for the F1 transmission. I think that was a good choice, because the plain 430 was giving numbers like 44.764mm for Clutch Position closed from new and 48.385 for clutch position closed. Wear index is 0 no matter what 430 version I choose, maybe that's why the percentage calculation reads 0.
    For the F131E EV08, I get a couple of extra measurements that weren't available such as "Self-Calibrated index for Clutch wear" and "Clutch Position closed from new 2". But get a Clutch Position Closed of 18.425mm and a Clutch Position from New of 17.119mm
    How do you calculate clutch wear % from that?
    Thanks,
    Cheers,
    Corey
  25. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    How would you calculate this data in clutch wear and percentage used?
