How do I check if they are correct for the car? Is there a production register of Chassis and Engine Numbers that I can check against? FF
Firstly they should tally up with your documentation, the chassis number is easy to see on the right but the engine number is hidden down between the inlet manifolds, there is a list of numbers that tell you what year they are, I have it in a book somewhere but if you do a search on here or check Google you should find them easy enough
