char on steak? | Page 2 | FerrariChat
char on steak?
Discussion in 'Drink, Smoke, and Fine Dining' started by Edward 96GTS, Mar 13, 2015.
  1. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    I agree - brown, crusty, and tasting yummy; not black and tasting like bitter carbon.
    As for the "black & blue" crowd, I get it, but that's just not how I like my steaks. The best result in my opinion is browned and crusty on the outside, medium rare (red, yet warm) on the inside. The flavor of cold beef is too subtle, especially when overpowered by the strong taste of a bitter, charred exterior.
  2. darth550
    Jul 14, 2003
    60,966
    In front of you
    BCHC
    El Wayne, I sense a steak night might be coming up?
    Whatcha think?
  3. Dom
    Dom F1 Veteran
    Nov 5, 2002
    8,489
    Bingo. That's what I mean. A good brown crust is delicious. But, oftentimes I've been served something that I would call burned.
    I am sensitive to bitter tastes, so maybe that's the problem on my end, but I love a good crust as long as it's not over done (bitter).
    Browned and Crusty, to quote El Wayne.
  4. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,047
    DFW, Texas
    Tom C
    That's a great route route for hanger steak....T
  5. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    I think I like the way you think. :)
  6. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,071
    LA
    Todd
    And dry so there is no steam to prevent the sear.
  7. spirot
    spirot F1 World Champ
    Dec 12, 2005
    14,943
    Atlanta
    Tom Spiro
    I think steak can taste great with a burnt exterior but the key is that its very thick and you get all the layers ... the "charr" hast to be thin, then the under caramalized portion, then a moist yet coagulated protein side, then a rich deep pink - red meaty center.
    I use my grill - gas grill, turn it on 20 min before - high heat all burners. dry the beef after having rested at room temp for 1 hour. ( covered / sealed.) However this is contrary to all health and safety warnings about food borne illness. dry the meat quickly then pepper and salt the exterior and place on grill. close the grill and wait for the heat to recover.
    dont keep opening it... leave it for 8 -10 min ( depending on thickness. ) I usualy dont grill anything under 1". Saute is better for thin meat.
    after 10 min turn the meat, and close wait - 5 min. take the steak and place on clean warm plate and cover with foil, but dont completely close if off.
    let it rest for 10 min. a full 10 min. keep it in a NON cold part of the kitchen.
    when it relaxes the juice is then brought back in to the meat - and it gets rehydrated. you will have some juice at the bottom but that is just a side product. the longer you let it rest the more flavor you will have.
    salting the meat more than 3-4 min before you grill, brings all the moisture to the surface of the meat, eventually drying out your steak. only put salt on when you can quickly sear it - then the salt acts like a crystal barrier to charring excessively - since it absorbs moisture. as the meat heats up the salt crystals melt - releasing salty juice on to the surface helping with the sear. some charr on the outer parts is desireable - fat will blister and char quickly ... which usually gives meat is smoky charred flavor. its like anything - it takes practice to master.
    WHAT EVER YOU DO - DO NOT USE A FORK - use tongs to pick up the meat before and after cooking it. puncturing the meat with a fork just lets out all the juices... same with burgers - dont smash them down - you are just pushing out the juice / flavor.
  8. V-TWELVE
    V-TWELVE Formula 3
    1,800
    Vancouver, BC
    I go for a dark mahogany colour as you get the best flavor IMO. Charred or burnt is a bitter taste and couldn't care less about grill marks. It is better to convection cook in the BBQ with the steak sitting over a non-lit burner as this will reduce the flare up. I sear at the end for colour and caramelization.
  9. darth550
    Jul 14, 2003
    60,966
    In front of you
    BCHC
    All true except pepper can get bitter while cooking too. I add it after.
  10. spirot
    Dec 12, 2005
    14,943
    Atlanta
    Tom Spiro
    use coarse grown pepper and it will work great. fine grown - the oils get burned and all you have is the pepper husk.
  11. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    I am CERTAIN your steaks come out to perfection, but this description baffles me.
    I run my grill at about 750 F, and for most meats, use a flat cast iron grate that reaches temperatures much hotter than that. If I leave anything in that environment for more than a minute per side - it will not only be seared, but will overcook to a depth of at least 1/4 to 1/3 inch per side...
  12. spirot
    Dec 12, 2005
    14,943
    Atlanta
    Tom Spiro
    I take your point - you have to know your grille. i did a steak the other tday and it only took about 4 min. ... so I amend my comment from 8-10 min... to 3-4 min ( depending on the heat your grille cranks out....
  13. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    #38 texasmr2, Mar 23, 2015
    I have never used cast iron (that 25% still in use) but a steak should be broiled or grilled over high heat, cooked fast. The "char" is the love yet achieving said char should not mean a steak will be overcooked.
    Cooking is not spelled "rocket science".
    And one island keeps abusing a common language, TX vs WI.
    See what I did?
  14. David_S
    11,260
    Mountains of WNC...
    David S.
    Ah! Thanks for the clarification.
    With my grill, the cast iron grate would still scorch a red potato wedge in under 3 minutes AFTER the gas had been completely shut off for almost half an hour. :) (off topic, but the chicken breasts, herbed potatoes, and asparagus I was cooking got big raves from the wife.)
  15. texasmr2
    22,232
    Houston
    Gregg
    Heat retention is cast iron's success and flaw.
    As soon as Painter (my dog) gets tired of kissing (licking me) I am going to look for a steak!!!
  16. David_S
    11,260
    Mountains of WNC...
    David S.
    No doubt! I've literally shattered a cast iron skillet with a steak (think Lodge 15" pan/skillet). Haven't even managed to warp or crack my 1/4" grate/plate so far. LOVE it!
    p.s.: I don't sear my meats to the point of a black/burnt outer crust - I use VERY high heats & just seconds to achieve that rich, crunchy caramelization (shy of carbonization), but only at the VERY surface - keeping things below at just the desired level of doneness. Will have to photograph some tuna sometime just to show that the layer between seared/crunch & raw is razor thin. :)
  17. texasmr2
    22,232
    Houston
    Gregg
    Crap now I want/need a steak!
  18. tomc
    Apr 13, 2014
    26,047
    DFW, Texas
    Tom C
    Gregg... Just make sure you buy a steak big enough to give painter his share!....T
  19. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,868
    Dallas, TX
    Jim E
    Go buy an infra red outdoor grill. Not one of the Home Depot crap pieces, get a quality full infra red unit. Mine gets to 1200 degrees and puts a crust on a steak you wouldn't believe. The high end restaurants cook with it, you should too.
  20. texasmr2
    22,232
    Houston
    Gregg
    LOL!
  21. tomc
    Apr 13, 2014
    26,047
    DFW, Texas
    Tom C
    Jim.... What brand do you own?....T
  22. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    And while we're on the subject of steaks, see if you can get your butcher to sell you the cap (deckle) off of the ribeye. Best cut ever! It won't be cheap, of course.
  23. darth550
    Jul 14, 2003
    60,966
    In front of you
    BCHC
    Wayne, I get the sirloin cap aka Picanha from the local Brazilian butcher. And yes, the Ribeye deckle is the best. I usually save that for last.
  24. texasmr2
    22,232
    Houston
    Gregg
    Did anyone catch the "Bizarre Foods" episode when Andrew was shown a steak that is hidden thus never recognized? I cannot find the episode on YT.
  25. tomc
    Apr 13, 2014
    26,047
    DFW, Texas
    Tom C
    Do you get the deckle if you buy an entire rib roast?
    I like picanha on the rotisserie, but this rib eye deckle is news to me.....T
