Changing oil weight from 5w-30 to 0w-40???
Discussion in '308/328' started by PassionIsFerrari, Jan 24, 2006.
  1. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    I have always put 5w-30 in my 348 since I have had it....Doing an oil change this weekend (crossing my fingers not to strip the plug!) and I am going to switch to 0w-40. I'm in FL so on warmer days the oil temps get close to 210 and at idle the oil pressure seems pretty low....I figure a heavy wieght oil will bump it up a little...
    What do you all think....good move? bad move?
    What negative effects will I have by going with a heavier weight oil? Increased engine wear?
    Thanks,
    Aaron
    P.S. - I use Mobil1 synthetic
  2. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Judging from the data i have with 5W-30 and 0W-40 on the 308GTS Qv here, you made a GREAT move. The 0W will lower startup in <cough> cold Florida weather. The 40 weight will be good to bring up the hot pressure. i also use Mobile 1 and played around with various oils over a few month period. For Florida daily driving and maybe a touch of spirited 0W-40 is fine (but not for pure track use).
  3. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    Use 0w-40 Mobil 1 in both 348 and 308. No problems.
    User manual calls for 10w-40 anyway. May run cooler and better oil pressures with 0w-40 than 5w-30.
  4. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    What weight do you use for track?
  5. MJT328GTS
    MJT328GTS Formula Junior
    Mar 30, 2005
    374
    St. Louis
    MJT
    I recently switched to Mobil-1 0-40W. Originally I tired to use a 5-30W when I bought the car last year but it was too thin for my 88 328 GTS. Burned up a couple of quarts very quickly. Went to the 40 weight and it's been great. No problems!
  6. Ferrari348turbo
    Ferrari348turbo Karting
    Nov 22, 2005
    208
    Florida
    Just to note 5w30 and 10w40 are probaby one of the worse oils you can use in conventional oils. The reason is that in order to get the wider (30 point) viscosity difference they use polymers. The polymers are what cause break down and cause sludge. The same would be true about 20w50 but since it already starts at a heavier weight it doesnt require as much polymers to get to that weight. I have always used 20w50 in all my performance cars, new engines or old. Infact some new cars void the warrenty if you use 10w40 just for this reason.
  7. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I switched from Mobile1 15w50 to Castrol TWS 10w60 for my BB512i and immediately noticed that the engine ran quieter. The TWS is hard to fine, but well worth the effort IMHO...
  8. Ferrari348turbo
    Nov 22, 2005
    208
    Florida
    using oil with a 50 point split is probably the worse switch you could of done
  9. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Just to chime in here also. Are you referring to new normal cars?? The new cars we have here,for the last few years only reccommend using the 5-30,10-40 and 15-50 weight oils. Engines these days are built with tighter machined tolerances and they need the "lighter" viscosity engine oils to protect the engine. And to help with fuel economy also(2nd most important thing these days they reckon? :( ) Im not saying that you cant put any "thicker" oils in your enigne,cause you can and it will not pose a problem. Maybe get a small increase in fuel economy,but thats about all really. :)
  10. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    I'm assuming he's referring to non synthetic oils.
  11. Ferrari348turbo
    Nov 22, 2005
    208
    Florida
    Thinner oils are fine for new cars the problem is with the way oil is made. In order for oil to have a wide span of viscosity they have to use polymers. Nothing wrong with polymers in small amounts such as in 20w50, but with 10w40 they have to use alot more. lets take 5w30 as an example, this oil is really just a 5 weight oil. Then they add polymers, when the oil is cold the polymers curle up and allow the oil to flow in its normal state, when the oil heats up the polymers unwind in long connected structures, this causes resistence making the oil thicker. Great idea but polymers are not oil. Polymers can burn, tear, wear, shear, and melt, and this is where the problems begin, and why you shouldnt use it any performance engine
  12. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Qucik case in point,we used to work on a low mileage 2000 Subaru WRX and conducted our own little oil experiment! Hehe We used to use Shell ECO-10 (10-40w) recommend by Subaru.After taking an oil sample, we changed the engine oil and oil filter and refilled with Shell Helix Standard (20-50w) We let the owner take it away on holidays for 2 weeks,covered around 6000km in that time. He brought it back,we took an oil sample and then changed the engine oil,again using the 20-50w. We sent him on his way and we sent both oil samples to Shell Australia and they "annalysed" the oil samples. For a cost of $30 each. I forget the exact technical words that Shell used in the oil sample report, but it showed that both oil samples had around the same amount of "wear" particles in the oils ect......... alll that crap and that it would reccommend either oil the WRX. LOL And it did use a little more fuel on the highway than normal he said,but nothing to get excited about. After the 2nd oil change with 20-50w,we went back to the ECO-10 oil. Now that ive bored ya's with this oil crap,please continue! LOL :)
  13. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Thats why you use fully synthetic oils in performace engines.Im sure them guys will be using fully synthetic oils when they made the swap? :)
  14. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Amsoil 20W-50 Synth 2000, but the oil temps get high at over 115C on warm track days! Viscosity is also a function of temperature so the higher 50 weight is MUCH thinner at higher temps than at cold startup.
    i can;t believe we are getting into another oil debate guys...
    Anywho, will be removing the stock oil cooler for a B&M with built-in fan that kicks in at 160F to lower those temps and may try 10-40 if i feel confident about keeping temps below 100C or so at the track event.
    But i am sure others here will yell at me for doing this and say i am going to blow up the engine, etc etc. My car, my engine, car will never be for sale...
  15. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    The local Motul tech is trying to convince me to try their 0W-20 race oil. It's what they run in the WRC. Having started with 15W-60, I'm not prepared to make such a big jump, but he insists it will be perfect on the track, along with freeing up some extra power.
  16. PAP 348
    Dec 10, 2005
    100,199
    Pap
    It wouldnt be much of a power increase would it stephens? :) Maybe get a few oil leaks instead?? ;) hehe
  17. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    LOL!!
  18. brm
    brm Karting
    Apr 26, 2002
    183
    Tampa, FL
    Bruce R. Morehead
  19. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Have you read it all? :)
  20. PAP 348
    Dec 10, 2005
    100,199
    Pap
    I havent got a spare 10 hours to review that. Maybe you can elaborate for the boys? :) That looks like a lovely colour on your 348 by the way ;)
  21. PassionIsFerrari
    Aug 15, 2004
    2,454
    I have read almost all of it and while I understand most concepts of oil, I wanted to know from other Ferrari owners what there experience was...what oil temps they were running, what the outside temp was where they lived, what they were using, and what their thoughts were....
    God bless Ferrarichat and EVERYONE else! ( Head of State - Chris Rock)
  22. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    On my BB512i the oil temp seems to run at a little below 100c regardless of the outside temp., although it does take it 30+ minutes to get up to that temp. The water temp on the other hand will run 85c or so during the winter and 90c to 95c during the summer depending on how hot it is and whether I am in stop and go traffic or on the highway. My oil temp did drop a little once I started using the Castrol TWS 10w60 as compared to what it was doing with the Mobile1 15w50 I was using.
  23. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I thought Hass's post claimed lighter oil would remove more heat. I have always been a fan of heavier weight oils, and everything I have ever read said heavier would run cooler. Thats why they run 70 weight in F1 cars. And anyone who thinks different should go do some searching. I read one article where they hooked up an oil heater to the Ferrari F1 car and transfused it with warm oil before starting the engine.
  24. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Oh gosh, i already typed this in the oil thread a few months back. Please use SEARCH function. Thanks.
  25. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Where can you buy Castrol TWS 10W-60 beside the BMW dealer?
    -Peter
