Ceramic Brake Disc life
Discussion in '360/430' started by stancheng, Dec 11, 2013.
  1. stancheng
    stancheng Rookie
    Dec 11, 2013
    3
    I am considering getting the 05/430, it has 17,000km on it,
    and it is equipped with ceramic brake.
    I would like to know the life of the pair of disc and brake pad respectively.
    Thank you very much for responding this.
  2. blackbolt22
    blackbolt22 F1 Veteran
    5,794
    Boca Raton, FL
    Mr. Anderson
    From what I understand on this site the CCBs will last basically the lifetime of the car in normal driving conditions. Track conditions are a completely different story.
    Price to replace all four corners with rotors and pads plus labor equals approximately $25000 USD.
    I have them on my car.
  3. HH11
    HH11 F1 Rookie
    3,338
    Assuming no track time (even a little won't change the equation much) A car with 17k KMs or 10k miles should be as good as new under normal driving conditions, as stated by blackbolt.
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,851
    The Cold North
    Tom
    Don't drive on unpaved roads. You don't want a stone/gravel to jam up in there and ruin a brake rotor. I just had to replace a set on a Porsche because of this exact issue. $$$$$. Customer is now selling the car, and replacing it with another Porsche without the fancy expensive brakes.
    Unless your running lemans on the weekends, you don't need them...at all.
  5. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    But they look coooooool :D
  6. crinoid
    crinoid F1 Veteran
    9,881
    LaCrinoid
    The local McLaren dealer told me that the CCB are actually heavier than the steel brakes. I hadn't looked at the weight and was surprised by this.
  7. mountainman3520
    mountainman3520 Karting
    Nov 11, 2013
    202
    Silicon Valley, Cali
    Dan Gilley
    Really? Could someone post side-by-side photos of the standard and carboceramic unobtanium brakes?
  8. 308mash
    308mash Formula Junior
    May 20, 2009
    534
    MA
    Joe
    #8 308mash, Dec 12, 2013
  9. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    I find this hard to believe. One of the main benefits of carbon-ceramic brakes is less rotational mass.
  10. Labman
    Labman F1 Rookie
    3,799
    Long Island, NY
    Steve
    Maybe the calipers are heavier but no way are the rotors heavier.
    I have them on my car as well. Rotors are supposed to last the lifetime of the car but as stated, tracking the car changes that. Also no brake dust on your wheels!!!
  11. vrsurgeon
    vrsurgeon F1 World Champ
    16,449
    Charleston, SC
    Curt
    The CCB pricing is truly obnoxious.
    If I have a car with CCB's on it and they crack or break or get trashed... I'm just going to replace the rotors with steel. One CCB rotor is 14,000 euros and 4 steel rotors are 1,200 euros. Even at 4 changes of rotors in the cars lifetime, one CCB rotor is still more expensive. I don't see the ROI quite frankly..
    Yeah I know what I'd do...
  12. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    I don't have pics. The ceramic rotors are noticeably bigger. Besides better braking, an additional advantage of the ceramics is that they don't generate brake dust thus making it easier to keep your wheels clean. I have them on my 05 430.
    I have also heard that the price of replacing the rotors is coming down a bit, still quite expensive.
    Sent from my SGH-I747M using Tapatalk
  13. redcaruser
    redcaruser Formula 3
    2,426
    switzerland
    daniel
    Change your supplier! This summer I replace the two CCB rear rotors for Euro 6'600.- (original Ferrari rotors for a Scuderia). Expensive but worth the money.
  14. Tim1137
    Tim1137 Formula Junior
    Aug 16, 2011
    817
    Providence - Boston
    Tim
    The Corvette ZR1 carbon rotor rings should be a direct replacement and the extremely small diameter difference should not effect anything. At somewhere around $2,000usd per rotor ring from your local GM dealer, its quite a bargain compared to the Ferrari part.
  15. anxpert
    anxpert Formula Junior
    Mar 4, 2008
    970
    Oceanside, CA
    Enrique Mar
    #15 anxpert, Dec 12, 2013
  16. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    I will keep this in mind, thanks for sharing.
  17. vrsurgeon
    16,449
    Charleston, SC
    Curt
    Eurospares website. :(
  18. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Just discovered Eurospares. Do they ship to the U.S.? Their prices are a lot less than Ricambi's. For example, a scud cooling fan is listed as $1580 on Ricambi's site, but only $655 on Eurospares' site.
  19. vrsurgeon
    16,449
    Charleston, SC
    Curt
    I've ordered from them before. Shipping takes a little longer...
  20. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    When I went back to the site I realized that these are used parts they are selling. That explains the huge price differential. Good to know of another source for parts though.
  21. Quilty
    Quilty Karting
    Mar 1, 2005
    199
    Pasadena, CA
    Christian
    I had no idea that they did not generate brake dust. I was wondering why my Scuderia's wheels were staying so clean. This is great news!
    I only got the car a month ago.
  22. stancheng
    stancheng Rookie
    Dec 11, 2013
    3
    To all the Ferrari lovers who had responded.
    Thank you so much for your input.
    So if ceramic disc can stay for lifetime on normal use, do the brakes pads still have to change from time to time???
  23. mountainman3520
    Nov 11, 2013
    202
    Dan Gilley
    So which parts are different comparing standard brakes to carbon ceramic and in what way?
    Rotor is clearly different, made of a different material and with a different pattern of holes. This seems like the main difference.
    How about the caliper?
    Brake pads? If the brake pads are the same as standard brakes, then I don't understand why carbon ceramic brakes would not create brake dust since the dust is from the pad being eroded and that same process occurs on the CC brakes. Isn't the life of the brake pads similar between standard and CC? If so then the same amount of brake pad material is being eroded. Its the lack of rotor overheat, associated warpage, and therefore no need to machine them flat, that are the key differences for CC brakes.
    Anything with the brake control system, anti-lock system, computer controls of the brakes for stability assist, etc? If these items have any difference between standard and CC, then people better not swap them out without somehow making the other adjustments.
    Thanks for educating me.
  24. stancheng
    stancheng Rookie
    Dec 11, 2013
    3
    How ofern do we have to change the brake pads with ceramic brake disc???
  25. redcaruser
    2,426
    switzerland
    daniel
    depending on your braking style, a general statement makes no sense, but not more often than with a steel disc.
