catalysts temp sensor fault | FerrariChat
Discussion in '612/599' started by Salmank, Jan 31, 2014.
  1. Salmank
    Salmank Rookie
    Jan 31, 2014
    1
    Dubai
    Salman
    Hi Guys,
    Can anyone suggest if below message is something i should be worried about.
    (catalysts temp sensor fault)
    someone told me it could be cause of carbon emission and needs cleaning.
    please suggest.
  2. vaderinc
    vaderinc Formula Junior
    Jul 6, 2010
    656
    Cyprus
    Mario
    Get it checked out.
    Normally a cleaning of the sensors would do the trick but if they are a bit worn out they may need replacing which can be a bit costly. Not checking them out might cause the car to get wrong temperature readings and assume that the catalytic converters are overheating. The ECU will then cut power to the engine and ask you to pull the car over which is a major inconvenience.
  3. Rucksack1898
    Rucksack1898 Rookie
    Nov 18, 2021
    9
    Hey, i know this thread is quite old - i just got this reading on my 599 - what was the outcome?
  4. tazandjan
    39,019
    Seven years ago, one post, so nobody knows.
  5. Rucksack1898
    Rucksack1898 Rookie
    Nov 18, 2021
    9
    Suspected as much.
  6. George Vosburgh
    George Vosburgh F1 Rookie
    But please post when you figure it out!
  7. Rucksack1898
    Rucksack1898 Rookie
    Nov 18, 2021
    9
    brogenville and George Vosburgh like this.
  8. tazandjan
    39,019
    Yup, that will compromise operation. Nice to find a simple fix, though. At worst, replace the sensor.
    Rucksack1898 likes this.
  9. Rucksack1898
    Rucksack1898 Rookie
    Nov 18, 2021
    9
    Yeah I was pretty happy it was something "easy".. I've contacted the dealer and let them know i may need a new sensor or two - in case it doesn't work after being dragged along the gorund!
